Proving a thermodynamic relationship
In summary, the homework statement is trying to find an equation for the change in pressure over time when a material is forced into a smaller space. It seems that the person is having trouble with the cyclical rule, but they are unsure of what to replace P with.
Potatochip911
318
Prove that ##TdS = C_vdT + \alpha T / \kappa dV##
##T dS = dU - pdV##
##\alpha = \frac{1}{v}\left(\frac{\partial v}{\partial T}\right )_P##
##\kappa = -\frac{1}{v}\left(\frac{\partial v}{\partial P}\right)_T##
The ##C_vdT## part is quite easy since for a constant volume process ##dU = C_vdT## but I can't seem to figure out how to get the second part of the expression. After multiplying by forms of 1 I end up with $$-pdV = \frac{\alpha\left(\frac{\partial v}{\partial P}\right)_T}{\kappa \left(\frac{\partial v}{\partial T}\right)_P}PdV$$, now using the cyclical rule here doesn't seem logical since that would introduce a negative so it seems like I need to replace the pressure P with something although I'm not sure what relation I can use to do that.
You've probably figured it out over the past few days, but for one thing, you've got a sign problem: ##T\,dS=dU+p\,dV## because ##p## is compressive stress.
Likes Potatochip911
Your mistake is that dU is not equal to ##C_vdT##. That is only correct for an ideal gas. In general, $$dS=\left(\frac{\partial S}{\partial T}\right)_VdT+\left(\frac{\partial S}{\partial V}\right)_TdV=\frac{C_vdT}{T}+\left(\frac{\partial S}{\partial V}\right)_TdV$$
From one of the Maxwell relationships, $$\left(\frac{\partial S}{\partial V}\right)_T=\left(\frac{\partial P}{\partial T}\right)_V$$Therefore, $$dS=\frac{C_vdT}{T}+\left(\frac{\partial P}{\partial T}\right)_VdV$$So, $$TdS=C_vdT+T\left(\frac{\partial P}{\partial T}\right)_VdV$$
Likes Potatochip911
At constant volume, ##dU=C_V\,dT## for all materials, as Potatochip911 noted.
Likes Potatochip911
But the problem statement does not say anything about constant volume. In fact, it explicitly indicates that the volume is not considered constant.
Likes Potatochip911
FAQ: Proving a thermodynamic relationship
1. What is a thermodynamic relationship?
A thermodynamic relationship is a mathematical equation that describes the relationship between different properties of a thermodynamic system, such as temperature, pressure, volume, and energy.
2. Why is it important to prove a thermodynamic relationship?
Proving a thermodynamic relationship is crucial for understanding and predicting the behavior of a system. It allows scientists to make accurate predictions and design efficient systems.
3. How do scientists prove a thermodynamic relationship?
Scientists use experimental data and mathematical models to prove a thermodynamic relationship. They conduct experiments under controlled conditions and analyze the data to determine the relationship between different properties.
4. Can a thermodynamic relationship be disproved?
Yes, a thermodynamic relationship can be disproved if new experimental data is found that does not fit the existing relationship. In this case, scientists must revise the relationship or come up with a new one.
5. What are some real-life applications of thermodynamic relationships?
Thermodynamic relationships have many real-life applications, such as in the design of engines, refrigeration systems, and power plants. They are also used in the study of weather patterns and in the production of materials and chemicals.
