Julio1
- 69
If $a,b\in \mathbb{R}^{+}.$ Show that $a>b\implies a^{-1}<b^{-1}.$
Hello, any idea for the proof? :) Thanks
One question, exist other form of proof?
To prove an inequality involving real numbers, you need to show that one side of the inequality is always larger or smaller than the other side. This can be done by using algebraic manipulations, properties of inequalities, or mathematical theorems.
The properties of inequalities in real numbers include the transitive property, which states that if a < b and b < c, then a < c. There is also the additive property, which states that if a < b, then a + c < b + c. And the multiplicative property, which states that if a < b and c is positive, then ac < bc.
Yes, substitution can be used to prove an inequality involving real numbers. You can substitute one expression for another as long as they are equivalent. This allows you to simplify the inequality and make it easier to prove.
Some common mistakes when proving an inequality involving real numbers include not following the correct order of operations, forgetting to flip the inequality sign when multiplying or dividing by a negative number, and assuming that an inequality is true without proper justification.
Some tips for proving an inequality involving real numbers include starting with the side that is easier to work with, using the properties of inequalities to simplify the expressions, and carefully checking each step in your proof to avoid making mistakes. It can also be helpful to look at examples and practice solving similar problems to improve your skills.
