MHB Proving an inequality with square roots
The discussion revolves around proving two inequalities involving square roots and their application to a summation. The first inequality, \(2(\sqrt{n+1}-\sqrt{n})<\frac{1}{\sqrt{n}}<2(\sqrt{n}-\sqrt{n-1})\) for \(n \geq 1\), has been successfully established. The user then attempts to derive the sum inequality \(2\sqrt{m}-2<\sum_{n=1}^m\frac{1}{\sqrt{n}}<2\sqrt{m}-1\) for \(m \geq 2\) but struggles with the right side. A suggestion is made to replace the incorrect inequality \(\frac{1}{\sqrt{1}}<2(\sqrt{1}-\sqrt{0})\) with \(\frac{1}{\sqrt{1}}\leq 1\), which would help in completing the proof. The conversation highlights the importance of careful inequality management in mathematical proofs.
Ragnarok7
This is problem 13 from section I 4.7 of Apostol's Calculus Volume 1:
Prove that $$2(\sqrt{n+1}-\sqrt{n})<\frac{1}{\sqrt{n}}<2(\sqrt{n}-\sqrt{n-1})$$ if $$n\geq 1$$. Then use this to prove that $$2\sqrt{m}-2<\displaystyle\sum_{n=1}^m\frac{1}{\sqrt{n}}<2\sqrt{m}-1$$ if $$m\geq 2$$.
I have proved the first inequality, and using that I took $$n=1,2,\ldots,m$$ to get the following inequalities:
$$2(\sqrt{2}-\sqrt{1})<\frac{1}{\sqrt{1}}<2(\sqrt{1}-\sqrt{0})$$
$$2(\sqrt{3}-\sqrt{2})<\frac{1}{\sqrt{2}}<2(\sqrt{2}-\sqrt{1})$$
$$2(\sqrt{4}-\sqrt{3})<\frac{1}{\sqrt{3}}<2(\sqrt{3}-\sqrt{2})$$
$$\vdots$$
$$2(\sqrt{m+1}-\sqrt{m})<\frac{1}{\sqrt{m}}<2(\sqrt{m}-\sqrt{m-1})$$
Adding them, I get
$$2(\sqrt{m+1}-\sqrt{1})<\displaystyle\sum_{n=1}^m\frac{1}{\sqrt{n}}<2\sqrt{m}$$
and, since $$\sqrt{m+1}>\sqrt{m}$$, this implies
$$2\sqrt{m}-2<\displaystyle\sum_{n=1}^m\frac{1}{\sqrt{n}}<2\sqrt{m}$$
so that the left inequality is the desired one. However, I'm unsure how to get the right side. Does anyone have any hints? Thank you!
Mathematics news on Phys.org
$$2(\sqrt{2}-\sqrt{1})< \color{red}{\frac{1}{\sqrt{1}}<2(\sqrt{1}-\sqrt{0})}$$
$$\vdots$$
Adding them, I get
The inequality in red, $\frac{1}{\sqrt{1}}<2(\sqrt{1}-\sqrt{0})$, says that $1<2$. You could improve that if you replace it by $\frac{1}{\sqrt{1}}\leqslant 1$. Then when you add the right inequalities, you should get what you want.
Ah! Very nice. Thank you!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
