MHB Proving an Infinite Number of Integer Points on a Level Surface
The function f(x,y) = x² + y² - 6xy + 8y defines a level surface where f(x,y) = 1, which contains infinitely many integer points (x,y). To prove this, one can start by rewriting the equation as (x - 3y)² = 8y² - 8y + 1. Finding integer values for y that make the right side a perfect square leads to integer solutions for x. Specifically, the equation can be transformed to n² = 2(2y - 1)² - 1, prompting the search for integer solutions that satisfy this condition. This approach suggests a connection to Pell's equation, indicating a pathway to proving the infinite integer solutions.
Elize88
Given is the function f: R2 -> R, with f(x,y)=x2+y2-6xy+8y.
The level surface f(x,y)=1 contains infinitely much points (x,y) where x and y
are integer.
How can I prove this?
I see that it is true with some examples, but how can I prove this.
Do I need to use the gradient? Or tangent planes? Or linear algebra?
Mathematics news on Phys.org
are integer.
Hi Elize, and welcome to MHB!
You want to find integer solutions to the equation $x^2 - 6xy +y^2 + 8y = 1$. I would start by completing the square and writing the equation as $(x - 3y)^2 = 8y^2 - 8y + 1$. If you can find an integer value of $y$ making the right-hand side of that equation a perfect square, say $8y^2 - 8y + 1 = n^2$, then $(x - 3y)^2 = n^2$. So $x = 3y\pm n$, giving you two integer values of $x$ to solve your equation.
But $8y^2 - 8y + 1 = 2(2y-1)^2 - 1$. So we want to find integer solutions of the equation $n^2 = 2(2y-1)^2 - 1$. In other words, we are looking for squares that are equal to twice a square minus $1$. That should get you thinking about http://mathhelpboards.com/math-notes-49/pell-sequence-2905.html.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
