Proving area theorem within semi-circle
In summary: The two points will have the same $y$-coordinate when they approach one another because they will both be moving towards (1,0).
Milly
The question is attached in the attachment below.
Mathematics news on Phys.org
Hi Milly! Welcome to MHB! :)
The area of a full circle is $\pi^{} r^2$.
If we take a segment out of it with angle $\theta$, its area is:
$$\text{Area of segment with angle }\theta = \pi^{} r^2 \cdot \frac \theta {2\pi} = \frac 1 2 r^2 \theta^{}$$
Can you find the area of the segment $POC$ using this formula?
And how about the area of the shaded area between $P$ and $A$?
The area $A_1$ of the sector $POB$ is:
\(\displaystyle A_1=\frac{1}{2}r^2\theta\)
Now, the shaded area $A_2$ will be the area of sector $POA$ minus the area of triangle $POA$.
Can you use the formula for the area of a sector and the area of a triangle (where 2 sides are known along with the angle subtended by those two sides) to give an expression for $A_2$?
But the angel POA is pi - theta which i have to then convert into degree to find area of triangle.
The area of the triangle is:
\(\displaystyle \frac{1}{2}r^2\sin(\pi-\theta)\)
Can you think of an identity for the sine function to simplify this?
I thought for sin (pi - theta) the angle should be in degrees but the angle given is in radians.
If the angle $\theta$ is in radians, then we use for the supplementary angle \(\displaystyle \pi-\theta\).
Ya but I don't know how to separate the ($/pi$−θ) in sin function
You could use the angle-difference identity, or simply use the identity:
\(\displaystyle \sin(\pi-\theta)=\sin(\theta)\)
Think of the unit circle...we have one point at (1,0) and one point at (-1,0). Now these two points begin moving along the top half of the circle at the same speed, towards one another...do you see that their $y$-coordinates will always be the same?
FAQ: Proving area theorem within semi-circle
What is the area theorem for a semi-circle?
The area theorem for a semi-circle states that the area of a semi-circle is equal to half the area of the circle that has the same radius as the semi-circle. In other words, if the circle has a radius of r, then the area of the semi-circle is equal to πr²/2.
How can the area theorem for a semi-circle be proven?
The area theorem for a semi-circle can be proven using basic geometric principles and formulas. One approach is to divide the semi-circle into smaller, known shapes (such as triangles or rectangles) and then use their known area formulas to calculate the area of the semi-circle.
What is the significance of the area theorem for a semi-circle?
The area theorem for a semi-circle is significant because it allows us to easily calculate the area of a semi-circle without using more complex methods. It also helps us understand the relationship between the area of a semi-circle and the area of a full circle.
Can the area theorem for a semi-circle be applied to other shapes?
No, the area theorem for a semi-circle specifically applies to semi-circles only. It cannot be applied to other shapes, such as triangles or squares.
Are there any real-world applications for the area theorem for a semi-circle?
Yes, the area theorem for a semi-circle has various real-world applications. For example, it is used in engineering and architecture to calculate the area of semi-circular structures, such as arches and domes. It is also used in physics and mathematics to solve problems related to circles and semi-circles.
