Proving Axioms and Definition: a/b + c/d = (ad + bc)/bd | Axiomatic Approach 2
  • MHB
  • Thread starter solakis1
  • Tags
    Approach
In summary: (bd)^{-1}d(bd)^{-1}bd= (bd)^{-1}(db) by axiom 3=(db)^{-1}(bd)^{-1} by axiom 3=(bd)^{-1}(db)^{-1} by axiom 3=(d^{-1}b^{-1})(d^{-1}b^{-1}) by axiom 3=d^{-1}b^{-1}d^{-1}b^{-1} by axiom 4=d^{-1}(b^{-1}d^{-1})b^{-1} by axiom 4=d^{-1}(db)^{-1}b^{-1} by axiom 4=d^{-1}b^{-1
solakis1
422
Given the following axioms:
For all a,b,c we have:
1) a+b = b+a
2) a+(b+c)=(a+b)+c
3) ab = ba
4) a(bc) = (ab)c
5) a(b+c) =ab+ac
NOTE,here the multiplication sign (.) between the variables have been ommited
6) There ia a number called 0 such that for all a,
a+0 =a
7)For each a, there is a number -a such that for any a,
a+(-a) = 0
8)There is a number called 1(diofferent from 0) such that for any a,
a1 = a
9)For each a which is different than 0there exists a number called 1/a such that;
a.(1/a)= 1.
And the definition: a/b= a(1/b)
Prove,based only on the axioms and the definition stated above the following:
A) a/b + c/d = (ad + bc)/bd if b and d are different from zero
B) (a/b)/(c/d) = (a/b)(d/c) if b and d are different than zero.
In trying to prove A the following result is shown.
1) \(\displaystyle a\neq 0\)......assumption
2)\(\displaystyle b\neq 0
\).....assumption
3) bd =0 ......hypothesis for contradiction
4) (bd)1/d = 0(1/d)...by multiplying both sides by 1/d
5) 1/d(bd) = (1/d)0.....by axiom 3 (commut)
6) [(1/d)d]b = 0.....by axioms 3,4 and the theorem A0= 0
7) 1b = 0......by axiom 9
8) b=0......by axioms 3, 8
9) \(\displaystyle b\neq 0 \) and b=0 ...contradiction
10) \(\displaystyle bd\neq 0\)
11) (bd)(1/bd) =1......axiom 9
(a/b +c/d) =
= (a/b+c/d)1=.......by axiom 8
= (a/b+c/d)((bd)(1/bd))=....by axiom 9
=[(a/b+c/d)(bd)]1/bd=.....by axiom 4
=[((a(1/b)) +(c(1/d)))(bd)]1/bd =.....by the definition
=[(bd)(a(1/b) + (bd)(c(1/d))]1/bd=...by axioms 3 and 5
=[(a(1/b))(bd) + (c(1/d))(bd)]1/bd=.....by axiom 3
=[((a(1/b))b)d + ((c(1/d))d)b]1/bd=.... by axioms 3 and 4
=[(b((1/b)a))d + (d((1/d)c))b]1/bd=....by axiom 3
=[( (b(1/b))a)d +((d(1/d))c)b]1/bd= by axiom 4
=[ (1a)d + (1c)b]1/bd=......by axiom 9
=[ad + cb]1/bd=.......by axioms 3 and 8
= (ad + cb)/bd ......ny definition
Can perhaps somebody show a shorter proof?
For B I have not try yet
Re: axiomatic approach 2
Axiom 1 is wrong, so I didn't bother reading anything else.
What do you mean that axiom 1 is "wrong"? Unless I have made a mistake I would have:
$\frac{(ad+bc)}{bd}=(ad+bc).\frac{1}{bd}$ by the definition.
$(ad+bc).\frac{1}{bd}=\frac{1}{bd}(ad+bc)$ by axiom 3.
$\frac{1}{bd}(ad+bc)=\frac{1}{bd}ad+\frac{1}{bd}bc$ by axiom 5.
$\frac{1}{bd}ad+\frac{1}{bd}bc=\frac{ad}{bd}+\frac{bc}{bd}$ by the definition.
$\frac{ad}{bd}+\frac{bc}{bd}=\frac{a}{b}+\frac{c}{d}$ as required.
Last time I checked, a + b = b + c is only true when a = c.
Oh right I read it as (and I just assume that it is supposed to be) $a+b=b+a$.
I suppose that could still be an axiom, just says everything is equal though.
By what axiom you conclude that :$\frac{ad}{bd}=\frac{a}{b}$ AND
$\frac{bc}{bd}=\frac{c}{d}$ ??
$\frac{ad}{bd}=ad.\frac{1}{bd}$ by the definition the using the inverse axiom
$=ad.\frac{1}{d}\frac{1}{b}=\frac{a}{b}$ hence result
Is the inverse axiom ,axiom No 9 ??
By what axiom you conclude that:
$\frac{1}{bd} =\frac{1}{b}\frac{1}{d}$ ?
In trying to prove problem B i could go as far as :
(a/b)/(c/d)=
=$\frac{a}{b}\frac{1}{\frac{c}{d}}$= ......by using the definition
=$\frac{a}{b}\frac{1}{c\frac{1}{d}}$......by using again the definition
That is as far as i can go
Can anybody help??
Hint: (Actually a rewritten form of your question)
Show that [tex](bd)^{-1} = d^{-1}b^{-1}[/tex]
To start: What is [tex](bd)^{-1}d[/tex]?
-Dan
-Dan
You mean [tex](bd)^{-1}bd[/tex],because i cannot see what is :
I apologize. I was working on the idea that this is a linear vector space and it doesn't appear to be (unless you want the vectors to act as the scalars as well, which is a construction I don't have a lot of the details for. I know I know..an example of this is the Real number system. Hey, I'm a Physicist. (Tmi) )
What I was going for is this:
\(\displaystyle (bd)^{-1} = d^{-1}b^{-1}\)
I can prove that there is no contradiction with the Axioms you posted, but I can't seem to actually prove it. I know I've seen a proof of this somewhere though.
Sorry for the bad hint! (Doh)
-Dan
Addendum: It's easy enough to prove that -(a + b) = -b + -a by using the distribution axiom. Maybe there is a generalization you can get to work based on it.
(a/b) = (a/b) 1 1 = (a/b) c(1/c) d(1/d) = (a/b) c(1/d) d(1/c) = (a/b) (c/d) (d/c)
(a/b) (1/(d/c)) = (a/b) (c/d) (d/c) (1/(d/c))
(a/b)/(d/c) = (a/b) (c/d)
Sorry, didn't look up all the axiom numbers.
Your solution is a great example of what generaly happens in nearly all branches in mathematics
Proofs with statements which are not justified.
It has been nearly half an hour ,and yet i cannot make out whether your proof is correct and which are the axioms that it is based.
Please be so kind to help me by citing the appropriate axioms involved in your ptroof.
let c and d be different from 0
(a/b) = (a/b) 1 1unity for multiplication
(a/b) = (a/b) c(1/c) d(1/d)existence of multiplicative inverse
(a/b) = (a/b) c(1/d) d(1/c)associativity + commutativity of multiplication
(a/b) = (a/b) (c/d) (d/c)definition of fraction
multiply both sides by (1/(d/c))
(a/b) (1/(d/c)) = (a/b) (c/d) 1multiplicative inverse
(a/b) (1/(d/c)) = (a/b) (c/d)unity for multiplication
(a/b)/(d/c) = (a/b) (c/d)definition of fraction
Actually, I haven't proven the existence of 1/(d/c), since (d/c) might be 0.
Perhaps you can prove that?
(a/b) = (a/b) 1 1
Thanks
Now i can follow
But there one or two steps that should be explained in more details
Do you agree that the following step in your proof:
should be :
(a/b) =(a/b)[(c(1/c))(d(1/d)]
If you do,then how do you apply associativity and commutativity of multiplication to come up with:
solakis said:
Thanks
Now i can follow
should be :
Strictly speaking you are right (if you add another closing parenthesis), but it's usually not considered necessary for an operation that is associative.
Since multiplication is associative, parentheses can be generally left out.
if parenthese are left out you have no associativity,because in the axiom.a(dc)=(ab)c it is the parentheses that show associativity.
But if you mean associativity and commutativity, then it is a different story.
But then this must be proved.
For example for three variables we must show that:
abc =acb = cab= bca=bac
In our case the variables are five and the story is longer.
For any No of variables the proof must be impossib;le.Once this is proved can be used as theorem in any subsequent proof.Hence in your proof you cannot drop out parentheses because we have not proved yet the above theoremOtherwise the proof is not based only on the axioms stated ,as the OP demanded
I only meant associativity.
Commutativity is an entirely different matter.
Associativity means that for any a,b, and c: (ab)c=a(bc).
If this is the case we can also simply write abc instead.
In a non commutative multiplicative Group with identity element 1 and inverse of $a^{-1}$ ,how would you prove that:
$b^{-1}a^{-1}=(ab)^{-1}$ without using parentheses
In this case you need parentheses.
You can leave parentheses out for a single type of operation that is associative.
If another type of operation is involved, you may need parentheses.
Why we cannot have the following proof without using parentheses??
$b^{-1}a^{-1}$= $b^{-1}a^{-1}ab(ab)^{-1}$=
=$b^{=1}1b(ab)^{-1}$= $1(ab)^{-1}$=$(ab)^{-1}$
Sure you can.
This is correct.
Note that you did leave out a couple steps with 1's.
But that's okay, since there is only one unity of multiplication and it is also commutative for multiplication.
I like Serena said:
Sure you can.
This is correct.
Why ,then, all the books i have gone thru ,in the above proof or similar proofs,use parentheses??
Heh.
Do you have references for that?
To be honest, I'd use one extra set of parentheses myself.
Not because they are mathematically necessary, but to make it more clear what I'm doing.
That's an entirely different situation, I like Serena is simply saying that if we have associativity and $a(bc)=(ab)c$ then we may simply write $abc$ in this situation as the parenthesis are irrelevant.
I like Serena said:
Heh.
What is mathematically necessary
FAQ: Proving Axioms and Definition: a/b + c/d = (ad + bc)/bd | Axiomatic Approach 2
What is an axiom?
An axiom is a statement or principle that is accepted as true without needing to be proven. It serves as the foundation for a mathematical system and is used to derive other theorems and definitions.
Why is it important to prove axioms?
Proving axioms is important because it ensures the validity and consistency of a mathematical system. It also allows for the development of more complex theorems and definitions based on these foundational principles.
What is the difference between an axiom and a definition?
Axioms are statements that are accepted as true without proof, while definitions are used to assign meaning to mathematical terms. Axioms are used to prove theorems, while definitions are used to clarify the meaning of terms used in mathematical statements.
How is the axiom approach used to prove mathematical statements?
The axiom approach involves starting with a set of axioms and using logical reasoning to derive theorems and definitions. Axioms are used as the starting point for proofs, and any new theorems are then added to the set of axioms for future use.
Can axioms and definitions change?
Generally, axioms and definitions are considered to be fixed and unchanging. However, in some cases, new axioms may be added or existing ones may be modified or refined. Definitions may also change over time as new ideas and concepts are introduced in mathematics.
