Proving $b^2-4ac \leq \frac{1}{8}$
  • MHB
  • Thread starter Albert1
In summary, the discriminant inequality $b^2-4ac \leq \frac{1}{8}$ is significant in quadratic equations as it helps determine the nature and number of roots. To hold true, the coefficients of the equation must satisfy the condition that $b^2-4ac$ is less than or equal to $\frac{1}{8}$. This can be proven using the quadratic formula or the properties of quadratic equations. The implications of proving this inequality include gaining information about the roots of the equation. It can also be extended to higher degree polynomials, but the form of the inequality will vary.
Albert1
1,221
$b^2-4ac$ is a real root of equation :$ax^2+bx+c=0,\,\, (a\neq 0)$
prove :$ab\leq \dfrac {1}{8}$
Mathematics news on Phys.org
My solution:
Multiply the equation of $ax^2+bx+c=0$ by $4a$, we get:
$4a^2x^2+4abx+4ac=0$(*)
We're told that $b^2-4ac$ is a real root of the equation $ax^2+bx+c=0$, this tells us:
1. $4ac$ is a real number.
2. And we can, in this case, substitute $x=b^2-4ac$ into the equation (*), to get:
$4a^2(b^2-4ac)^2+4ab(b^2-4ac)+4ac=0$
Rewrite the above equation as another quadratic equation in terms of $4ac$, we see that we have:
$(4a^2)(4ac)^2-(8a^2b^2+4ab-1)(4ac)+(4a^2b^4+4ab^3)=0$
Since $4ac$ must be a real number, so the discriminant of the above equation must be greater than or equal to zero, thus this yields:
$(-(8a^2b^2+4ab-1))^2-4(4a^2)(4a^2b^4+4ab^3)\ge 0$
Expanding and simplify we get:
$-8ab+1\ge 0$
$\therefore ab\le \dfrac{1}{8}$
very good you got it !
here is my solution :
$ax^2+bx+c=0---(1)$
solution of (1):$x=\dfrac {-b\pm\sqrt {b^2-4ac}}{2a}=b^2-4ac$
let :$\sqrt{b^2-4ac}=y----(*)$
from(*) we create two new equtions
$2ay^2\pm y+b=0----(**)$
since (**) have real solutions
$\therefore 1-8ab\geq 0$, or $ab\leq \dfrac {1}{8}$
FAQ: Proving $b^2-4ac \leq \frac{1}{8}$
What is the significance of proving $b^2-4ac \leq \frac{1}{8}$?
The inequality $b^2-4ac \leq \frac{1}{8}$ is known as the discriminant inequality in quadratic equations. It is important because it helps determine the nature of the roots of a quadratic equation, whether it has real or imaginary roots, and how many distinct roots it has.
What are the conditions for $b^2-4ac \leq \frac{1}{8}$ to hold true?
In order for $b^2-4ac \leq \frac{1}{8}$ to be true, the coefficients of the quadratic equation must satisfy the condition that $b^2-4ac$ is less than or equal to $\frac{1}{8}$. This means that the equation must have a small or zero discriminant, which leads to certain properties of the roots.
How can one prove $b^2-4ac \leq \frac{1}{8}$?
There are several ways to prove the discriminant inequality. One approach is to use the quadratic formula and plug in the coefficients to show that the discriminant is indeed less than or equal to $\frac{1}{8}$. Another approach is to use the properties of quadratic equations and their roots to show that the inequality holds true.
What are the implications of proving $b^2-4ac \leq \frac{1}{8}$?
The implications of proving the discriminant inequality are that it gives us information about the nature of the roots of a quadratic equation. For example, if $b^2-4ac = 0$, then the equation has a double root and if $b^2-4ac < 0$, then the equation has imaginary roots. It also helps us determine the number of distinct roots the equation has.
Can the inequality $b^2-4ac \leq \frac{1}{8}$ be extended to higher degree polynomials?
Yes, the discriminant inequality can be extended to higher degree polynomials. However, the inequality will have different forms depending on the degree of the polynomial. For example, for cubic equations, the discriminant inequality takes the form $c^2-4bd \leq \frac{1}{108}$ where $c$ and $d$ are the coefficients of the cubic equation.
