Proving Binary Relations: R & S
In summary: No, we cannot have $aRb$, because $aRb$ would mean that $a\le b$, which is false.Since $1R9$ does not exist, it seems that $R$ is not symmetric.No, we cannot have $aRb$, because $aRb$ would mean that $a\le b$, which is false.Since $1R9$ does not exist, it seems that $R$ is not symmetric.So $R$ is not symmetric.Since $1R9$ does not exist, it seems that $R$ is not transitive.It is not the case that
andrew1
Hi,
I'm currently stuck on a few questions regarding binary relations as I'm unsure on how to prove their properties.
R is defined on N by aRb if and only if a <= b and b <= a+5
Is R reflexive, symmetric, antisymmetric, transitive?
S is defined on Z (union) {x + 1/2 : x is an element of all integers} by aSb if and only if a - b is an even integer.
Is S reflexive, symmetric, antisymmetric, transitive?
Is $\le$ reflexive? Why? What can you say about reflexivity of $R$?
Also why do you use LaTeX commands but do not surround formulas with dollar signs or [math] tags?
Sorry about the latex commands thing, not sure how it works :S
In regards to R, would a + 5 be treated as just a? therefore it isn't reflexive?
Even after I said that you can surround formulas with dollar signs?
$a+5$ is almost never treated as $a$; these are two different numbers. I suspect you don't know what "reflexive" means. Please review your textbook or Wikipedia and feel free to ask questions if you don't understand the explanation.
reflexivity is just aRa so I guess it would be reflexive since if I use any natural number for a it will be related to itself
Yes. More accurately speaking, $R$ is reflexive if $aRa$ holds for all $a$.
Yes. How to explain this in more detail? If $a\in\Bbb N$, then by definition of $R$, $aRa$ means $a\le a\le a+5$, which is true for any $a$. Now try proving reflexivity of $S$.
Concerning symmetry of $R$, what happens when $a<b$?
By the way, you can click the "Reply With Quote" button to see how formulas are typed.
Well when $a<b$ won't be related to a since 4 < 5 for example doesn't mean 5 < 4, but now the anti-symmetric property part of the question confuses me because if I take a as 4 again and b as 5, 4 $\ne$ 5. Would it also be sufficient to say that the relation isn't transitive as well since 1R5 for example and 5R11 but 1 isn't related to 11?
Let's say it precisely. The expression $a<b$ cannot be related to $a$ because $a<b$ is not a number, and $R$ is a relation on numbers. Only a number can be related to another number via $R$. Further, 4 < 5 does not indeed imply 5 < 4, but so what? What does it have to do with $R$, which involved two inequalities (and both of them non-strict)? You have the right idea, but you need to say it precisely.
But is it the case that $4R5$ and $5R4$? If not, then this example does not violate antisymmetry.
It is not the case that $5R11$, but you are right that $R$ is not transitive.
This is what I suggest:
Choose $a$ and $b$ from the set $\{1,2,3,4,5,6,7,8,9\}$.
This isn't all of $\Bbb N$, but it will give you an idea of which number-pairs are related.
For example, do we have $1R9$? Let's check:
Is $1 \leq 9$? Yes, so we passed the first test.
Is $9 \leq 1+5$? no, so we failed the second test, and thus the pair $(1,9)$ is not in $R$.
You might try to eliminate certain "kinds" of pairs at one fell swoop. For example, if $a > b$, can we have $aRb$?
FAQ: Proving Binary Relations: R & S
What is a binary relation?
A binary relation is a mathematical concept that represents the relationship or connection between two sets of objects or elements. It is typically denoted by R or S and can be thought of as a set of ordered pairs (x,y) where x is related to y in some way.
How can we prove that a relation R is reflexive?
To prove that a relation R is reflexive, we must show that for every element x in the set, (x,x) is a part of the relation. In other words, every element in the set must be related to itself. This can be shown by using a logical argument or by providing specific examples.
What is the difference between a symmetric and an antisymmetric relation?
A symmetric relation is one where if (x,y) is a part of the relation, then (y,x) is also a part of the relation. In other words, the order of the elements does not matter. On the other hand, an antisymmetric relation is one where if (x,y) is a part of the relation, then (y,x) cannot be a part of the relation unless x and y are the same element.
How do we prove that a relation R is transitive?
To prove that a relation R is transitive, we must show that if (x,y) and (y,z) are both part of the relation, then (x,z) must also be a part of the relation. In simpler terms, if x is related to y and y is related to z, then x must also be related to z. This can again be shown through logical arguments or by providing examples.
Can a relation be both symmetric and antisymmetric?
No, a relation cannot be both symmetric and antisymmetric at the same time. This is because in a symmetric relation, the order of the elements does not matter, while in an antisymmetric relation, the order does matter. Therefore, a relation can only be one or the other, not both.
