Proving convergence given inequalities of powers
In summary, the problem requires showing that the given integral is convergent given the conditions a>-1 and b>a+1. The attempt at a solution involves bounding the integral and using the fact that any integral of the form ∫1/x^p when p>1 is convergent. The solution also involves using the binomial theorem to expand (1 + x^b)^{-1} in powers of x^b or x^{-b}.
anniecvc
28
Show that if a>-1 and b>a+1 then the following integral is convergent:
∫(x^a)/(1+x^b) from 0 to ∞
x^-1 < x^a < x^a+1 < x^b
x^-1/(1+x^b) < x^a/(1+x^b) < x^a+1/(1+x^b) < x^b/(1+x^b)
I also know any integral of the form ∫1/x^p when p>1 is convergent (from any number t to ∞)
Honestly not sure how to attack this problem. I'm trying to bound it but not sure how to show the parameters.
You need to show that both
[tex]
\lim_{\epsilon \to 0^{+}}\int_\epsilon^1 x^a(1 + x^b)^{-1}\,dx
[/tex]
and
[tex]
\lim_{R \to \infty} \int_1^R x^a(1 + x^b)^{-1}\,dx
[/tex]
converge. Since [itex]b - 1 > a > -1[/itex] we have [itex]b > 0[/itex], so [itex]0 < x^b < 1[/itex] if [itex]0 < x < 1[/itex] and [itex]0 < x^{-b} < 1[/itex] if [itex]x > 1[/itex] so you can use the binomial theorem to expand [itex](1 + x^b)^{-1}[/itex] in powers of [itex]x^b[/itex] or [itex]x^{-b}[/itex] as appropriate.
Thank you!
FAQ: Proving convergence given inequalities of powers
What does it mean to prove convergence given inequalities of powers?
Proving convergence given inequalities of powers refers to using mathematical techniques to show that a sequence or series of numbers will approach a specific value or limit as the number of terms or iterations increases.
How do you determine if a sequence or series is convergent?
To determine if a sequence or series is convergent, you can use various methods such as the comparison test, ratio test, or the root test. These techniques involve comparing the given sequence or series to a known convergent or divergent sequence or series.
Can you prove convergence using only inequalities of powers?
Yes, it is possible to prove convergence using only inequalities of powers. This technique involves manipulating the given inequalities to show that the sequence or series is bounded and monotonic, and therefore must converge to a specific value.
What are some common mistakes to avoid when proving convergence given inequalities of powers?
Some common mistakes to avoid when proving convergence given inequalities of powers include using incorrect inequalities, not considering the behavior of the sequence or series for large values, and not justifying each step of the proof clearly.
Is proving convergence given inequalities of powers important in real-world applications?
Yes, proving convergence given inequalities of powers is important in many real-world applications, especially in fields such as physics, engineering, and economics. It allows us to make predictions and analyze the behavior of systems with changing variables.
