Proving Definite Integral: \(\ln x/\sqrt{x(1-x^2)}\)
In summary, the integral of \(\int_0^1 \frac{\ln x}{\sqrt{x(1-x^2)}}dx\) can be evaluated using a substitution and the result obtained in a previous post. By putting specific values for the variables, \(\Gamma\) and \(\psi\) functions can be used to obtain the value of the integral, which is \(-\frac{\sqrt{2\pi}}{8} \left(\Gamma\left(\frac{1}{4} \right)\right)^2\).
sbhatnagar
87
Prove that
\[\int_0^1 \frac{\ln x}{\sqrt{x(1-x^2)}}dx=-\frac{\sqrt{2\pi}}{8} \left(\Gamma\left(\frac{1}{4} \right)\right)^2 \]
\(\Gamma (x)\) is the Gamma Function.
Mathematics news on Phys.org
Here's a Hint.:)
Differentiate the identity,
\[ \int_0^1 x^{a-1}(1-x)^{b-1}dx=\frac{\Gamma(a) \Gamma(b)}{\Gamma(a+b)}\]
with respect to the parameter \(a\).
\[\int_0^1 x^{a-1}(1-x)^{b-1}\ln x \ dx = \frac{\Gamma(a) \Gamma(b)}{\Gamma(a+b)} \left( \psi(a)-\psi(a+b)\right)\]
where \(\psi(x)\) is the Digamma Function.
I will post the solution now. In the integral,
\[ I=\int_0^1 x^{a-1}(1-x^c)^{b-1}\ln x \ dx\]
substitute \(t=x^c\), and obtain
\[ I=\frac{1}{c^2}\int_0^1 t^{\frac{a}{c}-1}(1-t)^{b-1}\ln t \ dt\]
This integral can be evaluated using the result obtained in my previous post.
\[I=\frac{\Gamma(a/c) \Gamma(b)}{c^2\Gamma(a/c +b)}\left( \psi(a/c)-\psi(a/c+b)\right)\]
If we put \(a=1/2,b=1/2,c=2\), we will obtain
\[\int_0^1\frac{\ln x}{\sqrt{x(1-x^2)}}=\frac{\Gamma(1/4)\Gamma(1/2)}{4\Gamma (3/4)}\left( \psi(1/4)-\psi(3/4)\right)\]
From the reflection rule of gamma function, we have
\(\displaystyle \Gamma \left(\frac{3}{4} \right)=\frac{\pi}{\sin(\frac{\pi}{4})\Gamma(\frac{1}{4})}=\frac{\pi\sqrt{2}}{\Gamma(\frac{1}{4})}\)
Also, \(\psi(1-x)-\psi(x)=\pi\cot \pi x\). Therefore
\(\psi(1/4)-\psi(3/4)=\pi \cot(3\pi/ 4)=-\pi\)
From all these we obtain
\[ \int_0^1 \frac{\ln x}{\sqrt{x(1-x^2)}}=-\frac{\sqrt{2\pi}}{8}\left( \Gamma \left ( \frac{1}{4}\right)\right)^2\]
FAQ: Proving Definite Integral: \(\ln x/\sqrt{x(1-x^2)}\)
What is the purpose of proving definite integrals?
The purpose of proving definite integrals is to find the exact numerical value of a definite integral, which represents the area under a curve between two given points on the x-axis.
How do you prove a definite integral?
To prove a definite integral, you need to use mathematical techniques such as substitution, integration by parts, or partial fractions to simplify the integrand and then evaluate the integral using the fundamental theorem of calculus.
What is the integrand for the definite integral of ln x/sqrt(x(1-x^2))?
The integrand for this definite integral is ln x/sqrt(x(1-x^2)).
What are the limits of integration for this definite integral?
Since this is a definite integral, it has specific limits of integration, which are typically denoted as a and b. In this case, the limits of integration are a = 0 and b = 1.
Can you explain the steps involved in proving this definite integral?
To prove this definite integral, you would first use algebraic techniques to simplify the integrand. Then, you would use substitution to rewrite the integral in terms of a new variable. Next, you would apply the fundamental theorem of calculus to evaluate the integral. Finally, you would substitute the original limits of integration back into the solution to find the exact numerical value of the definite integral.
