Proving Divergence of \sum\frac{1}{2n+1}
  • MHB
  • Thread starter suluclac
  • Tags
    Divergence
This leads to the conclusion that the series in question indeed diverges.In summary, we can prove that the series $\sum \frac{1}{2n+1}$ diverges by using the comparison test or the integral test. By comparing it to the harmonic series or by evaluating its integral, we can show that the series diverges.
suluclac
40
Prove that \(\displaystyle \sum\frac{1}{2n+1}\) diverges.
I understand that \(\displaystyle \sum\frac{1}{n}\) i.e. the harmonic series diverges (I say this because of the comparison test, that is, \(\displaystyle \frac{1}{2n+1}\leq\frac{1}{2n}\leq\frac{1}{n}\)).
However, this doesn't correctly imply that 1/(2n + 1) diverges.
Then I decided to use the integral test! WLOG, let the lower limit be even prime.
\(\displaystyle \int_2^\infty\frac{dx}{2x+1}=\frac{1}{2}\int_2^\infty\frac{2dx}{2x+1}=\frac{1}{2}[\ln{(2x+1)}]\Big|_2^\infty=\infty\)
Therefore, since the integral diverges, the series diverges.
Is this correct?
Hi suluclac,
Your work is correct, although one would technically have to justify (or just point out) that the sequence in question decreases to $0$ in order to apply the integral test.
Direct comparison test works here, too. For all $n \ge 2$, $2n + 1 \le 2n + (1/2)n = (5/2)n$. Therefore
$$\frac{1}{2n+1} \ge \frac{2/5}{n}\quad (n \ge 2)$$
Since the harmonic series diverges, so does $\sum \frac{2/5}{n}$; by direct comparison the series $\sum \frac{1}{2n+1}$ diverges.
Although mathematically sufficient, it amazes me the fact that the inequality reverses as we multiply 1/n by 2/5!
