Proving equality of mixed second order partial derivatives
In summary, the conversation discusses the partial derivatives of a scalar function ##f(x,y)##. It is shown that the first order partial derivative with respect to x is equal to the limit of the difference quotient as h approaches 0. Similarly, the second order mixed partial derivatives are equal to the limit of the difference quotient as h and k approach 0. The proof also requires the continuity of the mixed partial derivatives for it to be valid.
PWiz
695
116
Let ##f(x,y)## be a scalar function. Then $$\frac{∂f}{∂x} = \lim_{h \rightarrow 0} \frac{f(x+h,y)-f(x,y)}{h} = f_x (x,y)$$ and $$\frac{∂}{∂y} \left (\frac{∂f}{∂x} \right ) = \lim_{k \rightarrow 0} \frac{f_x(x,y+k)-f_x(x,y)}{k} = \lim_{k \rightarrow 0} \left ( \frac{ \displaystyle \lim_{h \rightarrow 0} \frac{f(x+h,y+k)-f(x,y+k)}{h} - \displaystyle \lim_{h \rightarrow 0} \frac{f(x+h,y)-f(x,y)}{h}} {k} \right ) = f_{yx} (x,y)$$
Similarly, $$\frac{∂f}{∂y} = \lim_{k \rightarrow 0} \frac{f(x,y+k)-f(x,y)}{k} = f_y (x,y)$$
and $$\frac{∂}{∂x} \left (\frac{∂f}{∂y} \right ) = \lim_{h \rightarrow 0} \frac{f_y(x+h,y)-f_y(x,y)}{h} = \lim_{h \rightarrow 0} \left ( \frac{ \displaystyle \lim_{k \rightarrow 0} \frac{f(x+h,y+k)-f(x+h,y)}{k} - \displaystyle \lim_{k \rightarrow 0} \frac{f(x,y+k)-f(x,y)}{k}} {h} \right ) = f_{xy} (x,y)$$
Now if we use the fact that $$\lim_{\mu \rightarrow \sigma} (g(\mu)) ± \lim_{\mu \rightarrow \sigma} ((h(\mu)) = \lim_{\mu \rightarrow \sigma}
(g(\mu) ± h(\mu))$$
then $$f_{yx} (x,y)= \lim_{k \rightarrow 0} \left ( \lim_{h \rightarrow 0} \left ( \frac{f(x+h,y+k)-f(x,y+k) - f(x+h,y) + f(x,y)}{hk} \right ) \right )$$ and $$f_{xy} (x,y) = \lim_{h \rightarrow 0} \left ( \lim_{k \rightarrow 0} \left ( \frac{f(x+h,y+k)-f(x+h,y) - f(x,y+k) + f(x,y)} {hk} \right ) \right ) $$
I'm just one short step from establishing the symmetry here (since the expression in both cases is the same), but I'm stuck. How do I justify interchanging the order of the limits? I don't think the answers obtained by applying the limits in a different order should in general commute.
Additionally, it is quite easy to see from above that this proof will be valid only if all the mentioned partial derivatives are defined (namely ##f_x(x,y)##,## f_y(x,y)##, ## f_{xy}(x,y)## and ##f_{yx} (x,y)## ), which is one of the required conditions for ##f_{xy} (x,y)## to be equal to ## f_{yx} (x,y)##. However, I can't find a justification for the other necessary condition - that the functions must be continuous.
Finally, I want to make sure this proof is formal (although it is admittedly very trivial in nature), so let me know if there's any step which seems a little hard to digest mathematically.
Any help is appreciated.
Schwart's theorem assumes ##f\in{\cal{C}}^2(U)##, ##U## open set of ##\mathbb{R}^2##.
geoffrey159 said:
U open set of R2\mathbb{R}^2.
Why is this assumption needed? Does the proof in the OP not work if we ignore this? I know counterexamples exist, but I want to know which step in the proof requires us to assume continuity.
It needs to be open because it makes legal such expressions as ##f(x+h,y+h)##, which you use a lot for the demo. That means you are sure that there is an open ball centered in ##(x,y)## that is included in ##U##, and it guarantees that their exist ##h## and ##k## small enough so that ##(x+h,y+k)##, ##(x+h,y)##, and ##(x,y+h)## are in ##U##.
In fact, you can lower the hypothesis to ##f\in{\cal C}^1(U)##, ##f_{xy}## and ##f_{yx}## exist and are continuous.
I've just read the demo, it is more subtle than I thought.
Try to find two distrinct single variable functions ##\phi## and ##\psi## such that
## f(x+h,y+k)-f(x,y+k) - f(x+h,y) + f(x,y) = \phi(1) - \phi(0) = \psi(1) - \psi(0) ##
Then with the mean value theorem, find a way to express these differences as a function of ##f_{xy}## and ##f_{yx}##. Finish with the continuity hypothesis
geoffrey159 said:
It needs to open because it makes legal such expressions as ##f(x+h,y+h)##, which you use a lot for the demo. That means you are sure that there is an open ball centered in ##(x,y)## that is included in ##U##, and it guarantees that their exist ##h## and ##k## small enough so that ##(x+h,y+k)##, ##(x+h,y)##, and ##(x,y+h)## are in ##U##.
This makes sense. What about interchanging the order of the limits though? Under which circumstances is that a legal operation?
This is THE problem in your demo. If it was possible to interchange the limits, the hypothesis of continuity for ##f_{xy}## and ##f_{yx}## would be useless.
Sorry for the late reply. So I've made a little progress:
Let ## ψ(1)= f(x+h,y+k)-f(x,y+k)## and ##ψ(0) =f(x+h,y) - f(x,y)##
Then $$f_{yx} = \lim_{k \rightarrow 0} \left ( \lim_{h \rightarrow 0} \left ( \frac{ψ(1)-ψ(0)}{hk} \right ) \right )$$
Applying the mean value theorem, we get $$f_{yx} = \lim_{k \rightarrow 0} \left ( \lim_{h \rightarrow 0} \left ( \frac{ψ'(u)}{hk} \right ) \right )$$ where ##y<u<y+k##
What now?
It's hardly logical to call these expressions ##\psi(1)## and ##\psi(0)##. Where did you get 1 and 0 from?
The logical would be to call them ##\psi(y+k)## and ##\psi(y)##, viewing ##\psi## as a function of ##y##, right?
Try this and it'll be quite easy...
You're right, I think I got it.
$$f_{yx} = \lim_{k \rightarrow 0} \left ( \lim_{h \rightarrow 0} \left ( \frac{ψ'(u)}{h} \right ) \right ) = \lim_{k \rightarrow 0} \left ( \lim_{h \rightarrow 0} \left ( \frac{\frac{∂f(x+h,u)}{∂y} - \frac{∂f(x,u)}{∂y}}{h} \right ) \right ) = \lim_{k \rightarrow 0} \lim_{h \rightarrow 0} f(g,u)_{xy}$$ where ##x<g<x+h##. Taking the ##h## limit, ##g \rightarrow x##, and taking then taking the ##k## limit, ##u \rightarrow y##, giving ##f(x,y) _{yx} = f(x,y)_{xy}##
Basically correct, PWiz, but the treatment of limits needs to be improved. You're actually taking the ##k##-limit first, when calculating ##\psi'##, so it's not meaningful to have this limit at the outside.
Instead, I would suggest this: For ##h## and ##k## both ##\neq 0## and sufficiently small, begin with ##\frac {f(x+h,y+k) - f(x,y+k) - f(x+h,y) + f(x,y)}{hk}## and rewrite this in essentially the same way you already did, using ##\psi## and two applications of the Mean Value Theorem, but no limits at this stage, to obtain ##f_{yx}(c,d)##, for some ##c## between ##x## and ##x+h## and some ##d## between ##y## and ##y+k##. Taking the limit and using the continuity of ##f_{yx}## at ##(x,y)## we obtain that the first quotient tends to ##f_{yx}(x,y)## as ##(h,k) \to (0,0)##.
By a similar calculation, the first quotient also tends to ##f_{xy}(x,y)##, so the two mixed derivatives are equal at ##(x,y)##.
Erland said:
You're actually taking the kk-limit first, when calculating ψ′\psi', so it's not meaningful to have this limit at the outside.
Um, I'm just using the mean value theorem by stating that ##\frac{ψ(y+k) - ψ(y)}{k} = ψ'(u)## for some ##u## in the open interval ##(y,y+k)##. I'm not taking any limit here.
You're right. I was unclear. What I meant was that the derivative ##\psi'(c)## is itself a limit, of a function of ##y##, and then there is no point in later taking the ##k##-limit, which is associated to the variable ##y##, since the expression to which you apply this limit does not depend upon ##y##.
I know I wrote "no limits at this stage" in my reply, but since I tell you to use the mean value theorem, the same remark applies to this, so I didn't express it in an entirely consistent way. On the other hand, I do tell you not to take a ##k##-limit later.
I'm afraid this no clearer to me than before. Can you explicitly show what you mean?
Sorry PWiz, it seems that I have not been thinking clearly...
From the demo I read :
Set
##\phi(t) = f(x+th,y+k) - f(x+th,y) ##
and
## \psi(t) = f(x+h, y+tk) - f(x,y+tk) ##
Since these two functions are ##{\cal C}^1([0,1])##, the mean value theorem says there exists ##\alpha,\beta\in[0,1]## such that
##\phi(1) - \phi(0)= \phi'(\alpha) ## and ## \psi(1) - \psi(0) = \psi'(\beta) ##.
Adapt this idea to show that there exists two functions ##\tilde \phi## and ##\tilde \psi## and ## \alpha_1,\beta_1 \in [0,1] ## such that
##\phi(1) - \phi(0) = h ( \tilde \phi(1) - \tilde \phi(0) ) = hk f_{xy} (x+\alpha h, y+ \alpha_1 k) ##
and
## \psi(1) - \psi(0) = k ( \tilde \psi(1) - \tilde \psi(0) ) = hk f_{yx} (x+ \beta_1 h, y+\beta k) ##
You can now conclude by continuity of the mixed partial derivatives at ##(x,y)## and uniqueness of the limit.
Related to Proving equality of mixed second order partial derivatives
1. What does it mean to prove equality of mixed second order partial derivatives?
Proving equality of mixed second order partial derivatives involves showing that the second order partial derivatives of a multivariable function are equal regardless of the order in which they are taken. This is important in ensuring that the function's behavior is consistent and can be accurately described by its partial derivatives.
2. Why is it necessary to prove equality of mixed second order partial derivatives?
It is necessary to prove equality of mixed second order partial derivatives because it ensures that the function's second order derivatives are well-defined and that the function is smooth and continuous. This is important in many areas of mathematics and science, such as physics and engineering, where accurate and consistent descriptions of functions are essential.
3. What is the process for proving equality of mixed second order partial derivatives?
The process for proving equality of mixed second order partial derivatives involves taking the partial derivatives of the function with respect to each variable, then comparing the results to ensure that they are equal. This is typically done using mathematical techniques such as the chain rule and the quotient rule, and can involve multiple steps depending on the complexity of the function.
4. Are there any special cases where proving equality of mixed second order partial derivatives is not necessary?
Yes, there are some special cases where proving equality of mixed second order partial derivatives is not necessary. For example, if the function is already known to be smooth and continuous, or if it is a simple polynomial, then the equality of mixed second order partial derivatives can be assumed without the need for proof.
5. How is proving equality of mixed second order partial derivatives used in real-world applications?
Proving equality of mixed second order partial derivatives is used in a variety of real-world applications, particularly in fields such as physics, engineering, and economics. It allows for accurate and consistent descriptions of functions, which are essential in modeling and predicting real-world phenomena. It is also used in optimization problems, where it ensures that the solutions obtained are valid and consistent.
  • Calculus
  • Calculus
