Proving Fermat's last theorem with easy math
  • I
  • Thread starter adolphysics
  • Tags
    Theorem
In summary, the conversation discusses the concept of Fermat's Last Theorem and its proof. It explains that there is no value for a, b, and c that satisfies the equation a^n=b^n+c^n for n>2 and all integers. The conversation uses the cosine theorem and Pythagorean theorem to prove this. However, it is later clarified that this proof is not valid and the general problem remained unsolved until 1995.
adolphysics
It says that there is no value of a,b and c, with n>2 and all integer numbers that satisfies this:
a^n=b^n+c^n
I'm only going to use the cosine theorem.
Let's consider three points A, B and C. They form the three sides of a triangle: a, b and c.
The sides forms three angles, which can go from 0 to 180 degrees.
If one angle, say α , is 180, then the other two are 0, but that doesn't affect the results. Then:
a^2=b^2+c^2-2b*c*cosα => a^2=b^2+c^2-2*b*c*cos180 => a^2=b^2+c^2+2*b*c => a^2=(b+c)^2
a=b+c or a=b-c
These are two basic principles of geometry, if one point is alligned with two others, their distance is the sum or difference between that point with each of the point.
We have just proven the case n=1 for Fermat's last theorem.
With the angle equal to 0 we have the same result.
Let's consider now that the triangle has one right angle. Then:
a^2=b^2+c^2-2*b*c*cos90 => a^2=b^2+c^2
I have just proven the Pythagorean theorem , and the case n=2 for Fermat's last theorem.
Cosα is only and integer number if the angles are 0, 90, 180... , and we have just seen that, if the angle is 180, n=1; and if the angle is 90, n=2. For any other values of n, the angle will be between 90 and 0, so cosα will not be an integer number.
Fermat's last theorem says that there is no value for a, b and c, with n>2 and all of them being integer numbers that makes this possible:
a^n=b^n+c^n
If we consider a, b and c the sides of a triangle, then the cosine theorem must apply. If the cosine isn't an integer number, then you aren't going to end up with a,b and c integer numbers.
I hope this is well explained and that i have not made mistakes(and sorry if i have not written something right, because I'm spanish).
Please say if this could be correct.
Mathematics news on Phys.org
I'm afraid you haven't proven anything. Any proof that involves ##n=2## has to explain Pythagorean triples, cannot be done by the law of cosine, because this only applies to ##n=2## and last but not least, your "proof" would already had fit on the margin of Fermat's book. Furthermore the proof for relatively small primes had been given soon after Fermat's death. The general problem remained unsolved until 1995 and is by far not anywhere near of easy to solve.
Thread closed.
Likes berkeman
Just a small addition: The whole idea does not work. The product of two integers and a non-integer cosine can be an integer. 4*5*cos(60°) = 10.
Likes fresh_42
FAQ: Proving Fermat's last theorem with easy math
What is Fermat's last theorem?
Fermat's last theorem is a mathematical conjecture proposed by French mathematician Pierre de Fermat in the 17th century. It states that no three positive integers a, b, and c can satisfy the equation an + bn = cn for any integer value of n greater than 2.
Why is proving Fermat's last theorem considered a difficult task?
Proving Fermat's last theorem is considered a difficult task because it requires a high level of mathematical knowledge and expertise. It also involves complex mathematical concepts and techniques that are not easily understood by the general public.
How was Fermat's last theorem finally proven?
Fermat's last theorem was finally proven in 1995 by British mathematician Andrew Wiles after almost 350 years of attempts by various mathematicians. Wiles' proof involved a combination of techniques from different areas of mathematics, including elliptic curves, modular forms, and Galois representations.
Can Fermat's last theorem be proven using only simple math?
No, proving Fermat's last theorem requires advanced mathematical concepts and techniques that cannot be easily understood or solved using simple math. However, there are some simplified versions of the theorem that can be proved using easier mathematics.
What are some practical applications of proving Fermat's last theorem?
Proving Fermat's last theorem has not led to any immediate practical applications. However, it has furthered our understanding of advanced mathematical concepts and opened up new research directions in number theory and algebraic geometry. It has also served as a significant achievement in the field of mathematics and inspired other mathematicians to tackle difficult mathematical problems.
