Proving Free-Fall in Rindler Spacetime is Finite
In summary, the professor assumes that free-fall means that the observer moving without any forces acting on it, hence it is moving with constant velocity. However, free-fall in SR means no proper acceleration, so the accelerated motion of the Rindler observer is what defines the Rindler horizon.
Antarres
200
100
Okay, so, while discussing Rindler space with my professor, I was asked to prove that for a free-falling observer, proper time for passing through the Rindler horizon is finite. That is at least how the question is phrased.
So, the professor obviously assumes that it is clear and trivial to me what this means, but I'm having doubts. That is, there was no mention of gravity in the whole discussion(it is just hyperbolic motion standard treatment), so I assumed that free-fall means that the observer moving without any forces acting on it, hence it is moving with constant velocity(this is analogous to how free fall is treated in GR, just with abscence of curvature). In that case it is trivial to show that he will pass the Rindler horizon in finite proper time. However, it makes no sense to me that an observer who is accelerating with acceleration of constant magnitude(assuming this is what free-fall means, something similar to homogeneous gravity field), would pass through the horizon in finite proper time, since his accelerated motion is what defines this horizon.
Am I missing something here? I feel like this should be simple, and maybe I'm overthinking, or maybe what I have to prove makes no sense, since that professor has habit of phrasing questions like that vaguely(it's some sort of homework, but not real homework, since we're not expected to bring it for grades, it's just like a question to think about I guess).
Yes.
Not in the standard Rindler coordinates used for Rindler spacetime, since those coordinates are not inertial. A free-falling object will accelerate "downward" (i.e., towards the Rindler horizon) in these coordinates.
You could, of course, switch to using standard inertial coordinates--indeed, it looks like this is what you have done when you say:
But in that case...
...you are confusing yourself by trying to work in two different coordinate charts at once. A freely falling object is not "accelerating with acceleration of constant magnitude" in standard inertial coordinates. It only is in non-inertial Rindler coordinates.
Further:
No, the accelerated motion of the Rindler observer--the one who has nonzero proper acceleration and follows a hyperbolic trajectory in standard inertial coordinates--is what defines the Rindler horizon (as the asymptotes of the hyperbola).
Only if you do it correctly. See above.
Likes Antarres and vanhees71
Your first guess is correct and your second guess is just wrong. There is no GR here, and free fall in SR means no proper acceleration, i.e. constant velocity in an inertial frame. Note, however, such a free fall motion will not be constant coordinate speed in Rindler coordinates. I assume your professor meant for you to describe inertial motion in Rindler coordinates and then, using the Rindler metric, verify that the horizon is reached in finite proper time. This is reasonably simple, but not trivial.
For the "free-falling observer" there is no Rindler horizon, so the question is confusing. Replace "free-falling observer" with "free-falling clock" to make sense of it.
Likes Antarres
You could also make it clearer by stating "proper time for passing through the Rindler horizon of the accelerating observer is finite".
Likes Antarres
Thank you for the answers. I assumed the first approach makes more sense, but I wasn't sure, so I wanted to see other opinions. I think I'll be able to solve it on my own then. It doesn't look complicated to me, though it's probably a bit technical.
@PAllen I said 'trivial', since that's how I usually call problems which are purely technical and don't require certain non-trivial steps in calculation. So to me anything that is straightforward completely, that you can do without much thinking technically, is trivial. That's what I meant, and I think this exercise will turn into a trivial one now that this has been cleared up. Thank you all very much.
Related to Proving Free-Fall in Rindler Spacetime is Finite
What is Rindler spacetime?
Rindler spacetime is a mathematical model used in physics to describe the behavior of objects in a flat, non-rotating universe. It is often used in the study of gravity and black holes.
What is free-fall in Rindler spacetime?
Free-fall in Rindler spacetime refers to the motion of an object that is only affected by the force of gravity. In this scenario, the object is not experiencing any other external forces, such as friction or air resistance.
Why is proving free-fall in Rindler spacetime finite important?
Proving that free-fall in Rindler spacetime is finite is important because it helps us understand the behavior of objects in a gravity-only scenario. This can have implications for our understanding of gravity and its effects on the universe.
How is free-fall in Rindler spacetime proven to be finite?
Free-fall in Rindler spacetime is proven to be finite using mathematical equations and calculations. These equations take into account the effects of gravity and the properties of Rindler spacetime to show that the motion of an object in free-fall will eventually come to a stop.
What are the potential applications of proving free-fall in Rindler spacetime is finite?
The applications of proving free-fall in Rindler spacetime is finite are wide-ranging and can include advancements in our understanding of gravity, black holes, and the behavior of objects in space. This knowledge can also have practical applications in fields such as engineering and space exploration.
