MHB Proving H is Complete & a Hilbert Space: Analysis of $\|.\|_H$
Impo
Hi,
Let H = \{(x_n)_n \subseteq \mathbb{R} | \sum_{n=1}^{\infty} x_n < \infty \} and for $(x_n)_n \in H$ define
$$\|(x_n)_n\|_H = \sup_{n} \left|\sum_{k=0}^{n} x_k \right|$$
Prove that $H$ is complete. Is $H$ a Hilbert space?
What is the best way to prove $H$ is complete?
To prove it's a Hilbert space, is it enough to prove that $\|.\|_H$ satisfies the parallellogram law?
Thanks in advance!
I have moved this topic from the Calculus sub-forum to our Analysis sub-forum as I feel you are more likely to get help here.
I suppose you should start by checking that $\|\,.\,\|_H$ is indeed a norm. Assuming that has been done, notice next that if $\|(x_n)\|_H < \varepsilon$ then (for each $n$) $$\biggl|\sum_{k=0}^{n} x_k \biggr| < \varepsilon$$ and also $$\biggl|\sum_{k=0}^{n-1} x_k \biggr| < \varepsilon$$. Take the difference and use the triangle inequality to see that $|x_n|<2\varepsilon.$
It follows that if $\{(x^{(m)}_n)\, \mid\, (m=1,2,\ldots\}$ is a Cauchy sequence for the $\|\,.\,\|_H$-norm, then for each fixed $n$ the sequence $(x^{(m)}_n)$ is Cauchy in $\mathbb{R}$ and hence converges to a limit $y_n$ say. In other words, $(x^{(m)}_n)$ converges coordinatewise to a sequence $(y_n).$ That gives you a candidate for the limit of the sequence. You then have to prove (i) that $(y_n)\in H$, and (ii) that $\|(x^{(m)}_n)-(y_n)\|_H \to0.$ (In other words, $(x^{(m)}_n) \to (y_n)$ in the $\|\,.\,\|_H$-norm and not just coordinatewise.)
You should probably model your proof on similar arguments that you may have seen for showing that spaces like $\ell^1(\mathbb{R})$ are complete.
To see whether or not $H$ satisfies the parallelogram law, try it out on some simple sequences, for example $(x_n) = (1,0,0,0,\ldots)$ and $(y_n) = (0,1,0,0,\ldots)$.
Thanks for the help Opalg!1. Let's check (y_n)_n \in H, that is \sum_{n=1}^{\infty} y_n &lt; \infty. We have \sum_{n=1}^{\infty} y_n = \sum_{n=1}^{\infty} \lim_{m \to \infty} x_n^{(m)} = \lim_{m \to \infty} \sum_{n=1}^{\infty} x_n^{(m)} &lt; \infty. The last inequality follows from the fact that x_n^{(m)} \in H ($\forall m$)
2. I'm not quite sure how I can work this out ...
It is indeed sufficient to show that $\left\|\cdot\right\|_H$ satisfies the parallelogram law since we've already shown H to be a Banach (i.e. normed vector-) space. From there, we use the polarization identity to say that
$$\langle x, \ y \rangle = \frac{1}{4} \left(\|x + y \|^2 - \|x-y\|^2 \right)\ \forall \ x,y \in H$$
Gives us a valid inner product.
Try to approach this by extending the finite case. In other words, how would this work for the $\left\|\cdot\right\|_1$ norm over $\mathbb{R}^n$?
Impo said:
1. Let's check (y_n)_n \in H, that is \sum_{n=1}^{\infty} y_n &lt; \infty. We have \sum_{n=1}^{\infty} y_n = \color{red}{\sum_{n=1}^{\infty} \lim_{m \to \infty}} x_n^{(m)} = \color{red}{\lim_{m \to \infty} \sum_{n=1}^{\infty}} x_n^{(m)} &lt; \infty. The last inequality follows from the fact that x_n^{(m)} \in H ($\forall m$)
You're playing with fire when you interchange limits like that! In general it is not legitimate to do so. What you need to do here is to replace the infinite sum by a finite sum so as avoid the interchange of limits. You are given a $\|\,.\,\|_H$-Cauchy sequence $(x^{(m)})$ in $H$, and a Cauchy sequence is necessarily bounded. Therefore there exists $K>0$ such that $\|x^{(m)}\|_H \leqslant K$ for all $m$, which means that $$\biggl|\sum_{k=1}^nx^{(m)}_k\biggr|\leqslant K$$ for all $m$ and all $n$. Now let $m\to\infty$ in that inequality to see that $$\biggl|\sum_{k=1}^ny_k\biggr|\leqslant K$$ (for all $n$). Hence $y\in H$, with $\|y\|_H\leqslant K$.
Since the sequence $(x^{(m)})$ is Cauchy, given $\varepsilon>0$ there exists $M$ such that $\|x^{(m)} - x^{(r)}\|_H < \varepsilon$ whenever $m,r>M$. Thus $$\biggl|\sum_{k=1}^nx^{(m)}_k - x^{(r)}_k\biggr| < \varepsilon$$ for all $n$. This is a finite sum, so we can safely let $r\to\infty$ to see that $$\biggl|\sum_{k=1}^nx^{(m)}_k - y_k\biggr| \leqslant \varepsilon$$ for all $n$ (whenever $m>M$). Thus $\|x^{(m)} - y\|_H \leqslant \varepsilon$ for all $m>M$. That's enough to show that $x^{(m)}\to y$.
[In case it's not obvious, I have been using the abbreviation $x^{(m)}$ to denote the sequence $(x^{(m)}_n)_n$, and similarly $y$ for $(y_n)_n$.]
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
