Proving Limit of Bilinear Function to 0
  • Thread starter yifli
  • Tags
    Function
In summary, the function f is bilinear and has a maxima at (h_1,k_1), (h_2,k_2), (h_3,k_3), (h_4,k_4), (h_5,k_5) and (h_6,k_6). When both hi and ki tend to zero, the numerator gets closer to zero faster than the denominator.
yifli
70
Prove that [tex]\mbox{lim}_{(h,k) \rightarrow 0} \frac{|f(h,k)|}{|(h,k)|} = 0[/tex], where f is a bilinear function from R^n X R^m -> R^p
I don't know where to start only given the information that f is bilinear.
Hi yifli! :smile:
Start by putting
[tex]h=h_1e_1+...+h_ne_n[/tex]
and
[tex]k=k_1e_1+...+k_me_m[/tex]
where the ei form a basis.
Now, how can you write f(h,k) now?
micromass said:
Hi yifli! :smile:
Start by putting
and
so f(h,k) can be written as follows:
[tex]f(h,k)=h_1(k_1f(e_1,\overline{e_1})+\cdots+k_mf(e_1,\overline{e_m}))+h_2(k_1f(e_2,\overline{e_1})+ \cdots +k_mf(e_2,\overline{e_m}))+\cdots+h_n(k_1f(e_n,\overline{e_1})+\cdots+k_mf(e_n,\overline{e_m}))[/tex]
e_i and \bar{e_i} represents the basis of R^n and R^m respectively
when both hi and ki tend to zero, I guess the numerator gets closer to zero faster than denominator because of the product hiki.
but how do you argue this rigorously?
Indeed, let me illustrate this on an example. I hope the general method will be clear from that:
Take
[tex]f:\mathbb{R}\times\mathbb{R}\rightarrow \mathbb{R}:(x,y)\rightarrow xy[/tex]
Then we need to calculate
[tex]\lim_{(h,k)\rightarrow 0}{\frac{|hk|}{|(h,k)|}}[/tex]
The easiest thing to do is pick the norm (it works without this too).
[tex]|(h,k)|=\max\{h,k\}[/tex]
Then we know that [itex]h\leq \max\{h,k\}[/itex], thus
[tex]\frac{|h|}{|(h,k)|}\leq 1[/tex]
Hence
[tex]0\leq \lim_{(h,k)\rightarrow 0}{\frac{|hk|}{|(h,k)|}}\leq \lim_{(h,k)\rightarrow 0}{|k|}=0[/tex]
Try to do this in the general case...
FAQ: Proving Limit of Bilinear Function to 0
What is a bilinear function?
A bilinear function is a mathematical function that takes two variables and outputs a value. It is called "bilinear" because it is linear in both variables, meaning that when one variable is held constant, the function is linear in the other variable.
How is the limit of a bilinear function defined?
The limit of a bilinear function is defined as the value that the function approaches as the two variables approach a specific point. This point is usually denoted as (x0, y0) and the limit is denoted as lim f(x,y) as (x,y) approaches (x0,y0).
Why is proving the limit of a bilinear function to 0 important?
Proving the limit of a bilinear function to 0 is important because it can provide valuable information about the behavior of the function at a specific point. It can also help in determining the continuity and differentiability of the function at that point.
What is the process for proving the limit of a bilinear function to 0?
The process for proving the limit of a bilinear function to 0 involves setting up the definition of the limit and using algebraic manipulation and/or inequalities to show that the function approaches 0 as the two variables approach a specific point.
Can the limit of a bilinear function approach a value other than 0?
Yes, the limit of a bilinear function can approach a value other than 0. This value can be any real number or infinity, depending on the function and the specific point at which the limit is being evaluated.
