Proving limit theorems when limit tends to infinity
In summary, the conversation discusses the different definitions of limits of a function as it approaches a point or infinity, and how these definitions can be used to prove properties such as multiplication and division. It also touches on the importance of understanding sequences and series in proving certain theorems in calculus and analysis.
Alpharup
225
Am using Spivak and he defines limit of a function f
1. As it approaches a point a.
2.As it approaches infinity.
He also defines limit f(x)=∞
x->a
But though in solving exercises, we can see that all the three definitions are consistent with each other, I am not satisfied by the argument that these specially defined limits follow all the property like;
Let lim f(x)=m and lim g(x)=n, then to prove lim f(x)*g(x)= m*n...
x->∞ x->∞ x->∞
Let lim f(x)=m here m is not equal to 0, then to prove lim ( 1/f(x))=(1/m)
x->∞ x→∞In some calculus(like Kuratowski) and analysis books, I could see that they first talk about series, convergence, divergence and so on...Then they talk about epsilon-delta definition of limit and show that this definition is consistent with the one obtained through sequence and series. So, is learning sequences and series(and some concepts like bounded sequence) necessary for proving such and such theorems?
It depends on what you want to prove. If you want to prove properties of a limit for sequences and series, you have to know something about them of course. If you want to study everything with epsilon/delta only, you don't need sequences or series.
Likes Alpharup
I mainly need the proof for epsilon/delta only...
How do you know?
The definitions for limits are different for ##\lim_{x \to a}f(x) = L##, ##\lim_{x \to \infty}f(x) = L##,##\lim_{x \to a}f(x) = \infty##, and ##\lim_{x \to \infty}f(x) = \infty##.
Both ##\epsilon## and ##\delta## appear in the definition of the first limit, ##\delta## (but not ##\epsilon##) appears in the third type, and ##\epsilon## (but not ##\delta##) appears in the second type. Neither one appears in the fourth limit type.
Likes Alpharup
So, do you mean to say that, we can still prove the limit properties(multiplication,division) because all the four definitions involve just slight modification of epsilon and delta?
What I described is not a slight modification of epsilon and delta. In the definitions of these kinds of limits, some of them don't use epsilon or delta (or both) at all. Your book should show each of these limit definitions.
The definitions can be used to prove the multiplication and division properties, but with the usual restrictions. Namely, they shouldn't be any of the indeterminate forms, such as ##[\frac 0 0]##, ##[\frac {\infty}{\infty}]##, or ##[0 \cdot \infty]##.
Likes Alpharup
Thank you...got it
Related to Proving limit theorems when limit tends to infinity
1. What is the definition of a limit theorem when the limit tends to infinity?
A limit theorem when the limit tends to infinity states that as a function's input approaches infinity, its output will approach a specific value or will tend towards infinity.
2. How do you prove a limit theorem when the limit tends to infinity?
To prove a limit theorem when the limit tends to infinity, you must show that as the input of a function approaches infinity, the output also approaches a specific value or tends towards infinity. This can be done through mathematical proof using the definition of a limit and other related theorems.
3. What is the significance of proving limit theorems when the limit tends to infinity?
Proving limit theorems when the limit tends to infinity allows us to understand the behavior of functions as their inputs become increasingly large. This is important in many fields of science, such as physics and economics, where variables can have infinitely large values.
4. What are some common techniques used to prove limit theorems when the limit tends to infinity?
Some common techniques used to prove limit theorems when the limit tends to infinity include using algebraic manipulation, applying the squeeze theorem, or using limit laws and properties.
5. Are there any limitations or conditions for proving limit theorems when the limit tends to infinity?
Yes, there are some limitations and conditions for proving limit theorems when the limit tends to infinity. For example, the function must be defined for all values greater than or equal to a certain number, and the limit must exist and be finite. Additionally, certain functions, such as oscillating or discontinuous functions, may not have limit theorems when the limit tends to infinity.
  • Calculus
  • Calculus
