Proving limits for roots and exponents
In summary, "Proving limits for roots and exponents" involves demonstrating how to evaluate the behavior of functions involving roots and exponents as they approach specific values. Key techniques include applying L'Hôpital's Rule for indeterminate forms, using the properties of logarithms to simplify expressions, and employing the Squeeze Theorem to establish bounds for limits. Understanding these concepts is crucial for analyzing the continuity and differentiability of functions in calculus.
Lambda96
223
75
See post
none
Hi
I have to prove the following three tasks
I now wanted to prove three tasks with a direct proof, e.g. for task a)$$\sqrt[n]{n} = n^{\frac{1}{n}}= e^{ln(n^{\frac{1}{n}})}=e^{\frac{1}{n}ln(n)}$$
$$\displaystyle{\lim_{n \to \infty}} \sqrt[n]{n}= \displaystyle{\lim_{n \to \infty}} e^{\frac{1}{n}ln(n)}$$
I would now argue as follows that x tends to infinity faster than the logarithm and therefore ##\frac{1}{n}## tends to zero and therefore ##e^0=1##.
Would this be a valid proof for task a?
Unfortunately my calculations are not displayed via Latex, does anyone know what the reason for this is? I have tried $$$ $ and ### # but with both the calculations are not displayed.
With overleaf the calculations are displayed
Double-$ is the correct delimiter (before and after) for stand-alone lines of Latex, and double-# is correct for in-line LaTeX.
So far I haven't been able to figure out what is wrong with your LaTeX, so I've reported it to the other Mentors. In the mean time, have you looked through the "LaTeX Guide" link below the Edit window to see if you see any issues?
Likes Lambda96
Here you go:$$\sqrt[n]{n}= n^{\frac{1}{n}}=e^{ln(n^{\frac{1}{n}})}=e^{\frac{1}{n}ln(n)}$$ $$\lim_{n \rightarrow \infty} \sqrt[n]{n}= \lim_{n \rightarrow \infty} e^{\frac{1}{n}ln(n)}$$
  • Love
Likes Lambda96, WWGD and berkeman
The LaTeX is now fixed. You had some obscure LaTeX commands in your expressions that probably aren't part of the MathJax that we use here; namely uproot and leftroot. In addition the lines that wouldn't render correctly were missing a right brace ( } ) at the end.
In any case uproot and leftroot weren't needed for nth roots. Use ##\sqrt[n] {n}## (raw ##\sqrt[n] {n}##) instead.
Likes Lambda96 and berkeman
Lambda96 said:
Homework Statement: See post
Relevant Equations: none
Hi
Basically yes, but I would require an argument for ##\lim_{n \to \infty}\dfrac{\log n}{n}=0## likely with the help of L'Hôpital.
Likes Lambda96 and WWGD
If you've seen this:
For f continuous,
## Lim _{x\rightarrow a} f(x)=f(a) ##
You can use it too.
Edit: It would most likely require L'Hopital too.
Likes Lambda96
Thank you berkeman, Hill, Mark44, fresh_42 and WWGD for your help 👍👍👍👍👍
I then used de L'Hospital's rule to show that the term ##\lim_{n \rightarrow \infty} \frac{\ln(n)}{n}## goes to zero so
$$\lim_{n \rightarrow \infty} \frac{\ln(n)}{n}=\lim_{n \rightarrow \infty} \frac{1}{n}=0$$Fortunately, I didn't have any problems with task b, but I can't make any progress at all with task c.
My lecturer told us the following for the solution$$\lim_{n \rightarrow \infty} n^s = \infty \quad \text{for} \, s \in \mathbb{Q}_{+}$$
$$\lim_{n \rightarrow \infty} a^n = \infty \quad \text{for} \, a > 1$$
Unfortunately, I can't do anything with this because I already knew that the two terms tend to infinity. Would I have to show somehow that ##a^n## tends to infinity faster than ##n^s##?
Likes berkeman
There are a lot of possible cases in part c). Perhaps try ##s \in \mathbb N## first?
Likes Lambda96
Hint to simplify things:$$\lim_{n \rightarrow \infty} c_n = 0 \ \Leftrightarrow \ \lim_{n \rightarrow \infty} |c_n| = 0$$
Likes Lambda96
I haven't done c) so my advice must be taken as an idea. not as a solution path.
I would start (as usual) with what we already know. We have ##s=\dfrac{p}{q}\in \mathbb{Q}## and ##|a|>1## that leads to two cases ##a=1+r## and ##a=-1-r## with ##r>0.##
The first case is thus ##\lim_{n \to \infty}\dfrac{\sqrt[q]{n^p}}{(1+r)^n}## and I would look up the Taylor series for ##\sqrt[q]{\cdot}## at infinity on WA. I'm starting to see what @PeroK meant with a lot of cases ...
Edit: With the hint in post #10, we only have to show the case ##a>1.## This means we need to show that $$\left|\dfrac{\sqrt[q]{n^p}}{(1+r)^n}\right|<\varepsilon $$
Likes Lambda96 and PeroK
I don't know what the purpose of the restriction to [itex]s \in \mathbb{Q}[/itex] in part (c) is, since I think the result is the same for [itex]s \in \mathbb{R} \setminus \mathbb{Q}[/itex]. Possibly the restriction is there because [itex]x^\alpha[/itex] for irrational [itex]\alpha[/itex] and positive [itex]x[/itex] has not yet been defined (as [itex]\exp(\alpha \ln x)[/itex]). If so, the (to me) obvious [tex]
\lim_{n \to \infty} \left|\frac{n^s}{a^n}\right| = \lim_{n \to \infty} \exp( s \ln n - n \ln |a|)[/tex] may not be admissible. But you've already used [itex]n^{1/n} = \exp(n^{-1}\ln n)[/itex] in part (a), so...
I think it has to see with defining a (edit: Continuous)function on a dense subset ( of the Reals), which defines it uniquely.
Likes Lambda96
Thank you PeroK, fresh_42, pasmith and WWGD for your help 👍👍👍👍
Since many other students had problems with the exercise, our lecturer told us to use the epsilon criterion for the proof.
I then used fresh_42's suggestion and estimated the result, hope it was correct, the submission was today 🙃
FAQ: Proving limits for roots and exponents
What is the limit of a function involving a root as x approaches a specific value?
To find the limit of a function involving a root as x approaches a specific value, you often need to apply the limit laws and sometimes manipulate the expression to make it more manageable. For example, if you have a function like √(x), as x approaches a, the limit is √(a). If the expression is more complex, you might need to rationalize the numerator or denominator to simplify the limit calculation.
How do you prove the limit of a function with an exponent?
To prove the limit of a function with an exponent, you can use the properties of limits and continuity. For instance, if you need to find the limit of x^n as x approaches a, and n is a positive integer, you can use the fact that limits can be distributed over continuous functions. Thus, the limit of x^n as x approaches a is simply a^n. More complex cases might require the use of L'Hôpital's rule or other advanced techniques.
What techniques can be used to handle indeterminate forms involving roots and exponents?
When dealing with indeterminate forms involving roots and exponents, techniques like rationalization, L'Hôpital's rule, and algebraic manipulation can be very useful. Rationalizing involves multiplying the numerator and denominator by a conjugate to eliminate roots. L'Hôpital's rule applies to 0/0 and ∞/∞ forms, allowing you to differentiate the numerator and denominator until the limit can be evaluated directly.
Can you use the squeeze theorem to prove limits involving roots and exponents?
Yes, the squeeze theorem can be very effective for proving limits involving roots and exponents, especially when the function is difficult to evaluate directly. If you can find two simpler functions that "squeeze" the given function and have the same limit at a point, then the given function must also have that limit. This is particularly useful for functions that oscillate or have complex behaviors near the point of interest.
How do you handle limits involving roots and exponents at infinity?
To handle limits involving roots and exponents as x approaches infinity, you often need to consider the dominant terms in the expression. For example, if you have a function like √(x^2 + x), as x approaches infinity, the x^2 term will dominate, and the limit will approach √(x^2) = |x|, which simplifies to x for large positive values. For exponents, you might need to compare the growth rates of different terms to determine the behavior as x approaches infinity.
