Proving Limits: How to Show x^x Approaches Infinity as x Approaches Infinity?
  • MHB
  • Thread starter FallArk
  • Tags
    Limits
In summary: That idea works (your inequality is valid for $x > 1$), but that's not what I meant. What I meant is the following. Suppose $L = \lim\limits_{x\to \infty} x^x$. Then $\ln L = \lim\limits_{x\to \infty} \ln(x^x) = \lim\limits_{x\to \infty} x\ln x$. Prove $\lim\limits_{x\to \infty} x\ln x = \infty$. Then $L = \infty$.
FallArk
127
\(\displaystyle \log_{e}\left({x}\right)\to-\infty\) as \(\displaystyle x\to{0}^{+}\)
2.
\(\displaystyle {x}^{x}\to\infty\) as \(\displaystyle x\to\infty\)
I know how to prove that \(\displaystyle \log_{e}\left({x}\right)\) approaches \(\displaystyle \infty\) as x approaches \(\displaystyle \infty\) by using the definition given in the book, not sure how to use that to prove the first problem.
Hi FallArk,
In the first problem, set $y = 1/x$. Then $y \to \infty$ as $x \to 0+$, and $\log_e x = -\log_e y$. So it suffices to compute $\lim\limits_{y\to \infty} -\log y$. For the second problem, compute the limit of $\ln(x^x) = x\ln x$ first.
Euge said:
Hi FallArk,
I'm still a bit confused about the second problem. is it using the idea that \(\displaystyle {x}^{x}\) > xlnx and by limit comparison \(\displaystyle {x}^{x} \implies \infty\)
Perhaps we can simplify it a bit.
For $x>1$ we have that $x^x >x$.
So if $x\to\infty$ so does $x^x\to\infty$.
FAQ: Proving Limits: How to Show x^x Approaches Infinity as x Approaches Infinity?
How do I prove the limit of a function?
The most common way to prove the limit of a function is by using the epsilon-delta definition of a limit. This involves showing that for any small value of epsilon, there exists a corresponding value of delta such that the function's output is within epsilon distance of the limit for all input values within delta distance from the limit point.
Can I use algebraic manipulation to prove a limit?
Yes, algebraic manipulation can be used to prove a limit. This method involves manipulating the function algebraically until it is in a form that is easier to evaluate the limit. This can include factoring, simplifying, or using known limit rules.
Is it necessary to use the squeeze theorem to prove a limit?
No, the squeeze theorem is not always necessary to prove a limit. However, it can be a useful tool for proving limits that are difficult to evaluate directly or when other methods do not work.
What is the difference between a one-sided and two-sided limit?
A one-sided limit only considers the behavior of the function as it approaches the limit point from one side, either from the left or the right. A two-sided limit looks at the behavior of the function from both sides and requires the function to approach the same limit value from both directions.
Can I use a graph to prove a limit?
While a graph can provide visual evidence for a limit, it is not considered a formal proof. A graph can help in understanding the behavior of a function near a limit point, but to prove the limit, other methods such as the epsilon-delta definition must be used.
