MHB Proving Linear Independence of Eigenfunctions of a Hermitian Operator
  • Thread starter Thread starter ognik
    Proof
The discussion focuses on proving the linear independence of eigenfunctions \( u_1 \) and \( u_2 \) of a Hermitian operator with distinct eigenvalues \( \lambda_1 \) and \( \lambda_2 \). The argument begins with the assumption that a linear combination \( \alpha_1 u_1 + \alpha_2 u_2 = 0 \) holds, leading to the conclusion that both coefficients must be zero. Concerns are raised about the clarity and validity of the steps taken, particularly regarding the manipulation of eigenvalues and the assumptions about linearity. The suggestion is made to utilize inner products to demonstrate orthogonality, which would directly imply linear independence. Ultimately, the proof hinges on the distinctness of the eigenvalues and the properties of linear operators.
ognik
Given $ u_1, u_2 $ are eigenfunctions of the same Hermitian operator, with distinct eigenfunctions $ \lambda_1, \lambda_2 $, show $ u_1, u_2 $ linearly independent.
If they are LI, then $ \alpha_1u_1+\alpha_2u_2=0 $ (1)
Now $ Hu_1=\lambda_1u_1, Hu_2=\lambda_2, \therefore H(\alpha_1u_1+\alpha_2u_2)=0,$
$ \therefore \alpha_1 \lambda_1 u_1+\alpha_2 \lambda_2 u_2=0$ (2)
$ (1)*\lambda_1 = \alpha_1 \lambda_1 u_1+\alpha_2 \lambda_1 u_2=0 $ (3)
$ (2) - (3): \alpha_2 u_2 (\lambda_2 - \lambda_1) = 0 $
Eigenfunctions cannot be 0, and $\lambda_1 \ne \lambda_2, \therefore \alpha_2 = 0 $
We can similarly show that for the linear combination to = 0, $\alpha_1 = 0 $
I based this on "If linear combo of vectors = 0 and the only solution is all coefficients = 0, then the vectors are LI"
I just feel vaguely hesitant about this,as it seems slightly circular logic?
You should assume your equation (1). That is, you're trying to show that $\alpha_1 u_1+\alpha_2 u_2=0$ forces or implies that $\alpha_1=\alpha_2=0$. So if you assume (1) holds, and show that the alphas must vanish, you're done. I'm not sure the rest of your logic holds, though. In particular, right around (1), it seems to be a bit shaky. I would recommend using inner products, and your knowledge of how Hermitian operators behave.
The only Hermitian property that seemed potentially useful was orthogonality - and the previous exercise had already asked to prove orthogonal eigenvectors were linearly independent (multiply my (1) by each of the vectors in turn also proves the coefficients are 0, $u_1.u_2 = 0 $ etc) , so it seemed they wanted a different approach ...
Could you be more specific where you think the logic is shaky please?
Try showing that the eigenvectors corresponding to distinct eigenvalues are orthogonal. Then you can use your previous result.
So far, so good.
It's not at all clear what you mean here. The eigenvalue $\lambda_1$ does not equal $\alpha_1 \lambda_1 u_1+\alpha_2 \lambda_1 u_2$. Moreover, why the eigenvalue changed subscripts in the second term is unclear as well. What property are you using to change that subscript?
In general, your mindset should be this: every single symbol on one line must survive to the next line, unless you invoke a particular property to change it. In fact, there's got to be some sort of "Conservation of Symbols" law in algebra. I just need to formulate it correctly.
This sort of idea is what you need, but I would go with inner products to show orthogonality of eigenfunctions. Then they must be linearly independent.
I think the idea of your proof is OK, the exposition is a bit off.
Suppose $\alpha_1u_1 + \alpha_2u_2 = 0$.
Since $H$ is LINEAR, it follows that $H(\alpha_1u_1 + \alpha_2u_2) = H(0) = 0$.
However, since $u_1,u_2$ are eigenfunctions with eigenvalues $\lambda_1,\lambda_2$ we have:
$H(\alpha_1u_1 + \alpha_2u_2) = \lambda_1\alpha_1u_1 + \lambda_2\alpha_2u_2 = 0$ ($\ast$)
(note we used the linearity of $H$ implicitly, without explanation).
Now $\lambda_1\alpha_1u_1 + \lambda_1\alpha_2u_2 = \lambda_1(\alpha_1u_1 + \alpha_2u_2) = \lambda_1 0 = 0$ ($\ast\ast$).
Subtracting ($\ast$) from ($\ast\ast)$ yields:
$(\lambda_1 - \lambda_2)\alpha_2u_2 = 0$.
Since $u_2$ is an eigenfunction, $u_2$ is not the $0$-function, by definition.
Therefore $(\lambda_1 - \lambda_2)\alpha_2 = 0$ (this is a scalar). Since we are in a FIELD:
either $\lambda_1 - \lambda_2 = 0$, or $\alpha_2 = 0$.
But $\lambda_1 - \lambda_2 = 0 \implies \lambda_1 = \lambda_2$.
As these eigenvalues were assumed distinct, it must be that $\alpha_2 = 0$.
Now we have that $\alpha_1u_1 + \alpha_2u_2 = 0$ becomes:
$\alpha_1u_1 = 0$, from which it is immediate that $\alpha_1 = 0$, as well, and LI is established.
It appears to me that this is what you MEANT to express, but taking care with the details is important (for CLARITY's sake).
Sorry, I multiplied my eqtn (1) by $\lambda_1$ precisely to get that change of subscript in the resulting eqtn (3); then (2)-(3) lead to one coefficient =0 ...
Aren't all operators linear? Either way, I don't get why H(some linear combo) = 0?
Later you justify $\alpha_1 (\lambda_2 - \lambda_1) $ as scalar(s) because we're in a field - do we need that field justification? The $\lambda's$ are always scalar (real) for an Hermitian operator? And the constants are also real, scalar - my book defines a linear combo of vectors as a real scalar * each vector.
For a linear operator $L$, we have:
$L(u+v) = L(u) + L(v)$ for any vectors (functions), $u,v$.
In particular, $L(0) = L(0) + L(0)$, so subtracting $L(0)$ from both sides gives $0 = L(0)$.
Since our original linear combination is assumed = to 0, it follows that $H$ of the linear combination is likewise 0.
The property that $ab = 0 \implies a = 0$ or $b = 0$, actually holds for a wider class of algebraic structures called an *integral domain*, which every field happens to be. There ARE structures for which this is NOT true, and it is possible to have "vector-space-like" structures (called MODULES) with non-integral-domains as the "scalars".
Vector spaces occur "over" an underlying field of scalars. It is not a "given" that this field is the field of real numbers. While eigenvalues of a Hermitian operator are always real (see here), there is no reason to so restrict linear combinations a priori, and in quantum mechanics, for example, the wave-functions are often complex-valued, with only their MAGNITUDES being real.
