Proving Maximal Ideal of $\mathbb{C}[X,Y]$
  • MHB
  • Thread starter evinda
In summary, the ideal $I=<X-1,Y+X^2-1>$ is a maximal ideal of $\mathbb{C}[X,Y]$ and this can be shown by proving that $\frac{\mathbb{C}[X,Y]}{(X-1,Y+X^2-1)}$ is isomorphic to $\mathbb{C}$. This can be done by defining a mapping $\phi: \mathbb{C}[X,Y] \to \mathbb{C}$ and showing that it is surjective. We can also view $\frac{\mathbb{C}[X,Y]}{(X-1,Y+X^2-1)}$ as the set of polynomials in $\math
evinda
MHB
3,836
Hello! (Wave)
How can I show that the ideal $I=<X-1,Y+X^2-1>$ is a maximal ideal of $\mathbb{C}[X,Y]$ ? (Thinking)
Perhaps you can use the equivalence:
$$\frac{\mathbb{C}[X,Y]}{(X-1,Y+X^2-1) }\ \mbox{is a field} \ \Leftrightarrow (X-1,Y+X^2-1) \ \mbox{is a maximal ideal in} \ \mathbb{C}[X,Y]$$
That means if you can show that $\frac{\mathbb{C}[X,Y]}{(X-1,Y+X^2-1)}$ is isomorphic to a field, you're done.
Adding to Siron's point, consider what the elements of $\Bbb C_1 := \Bbb C[X,Y]/<X-1,Y+X^2-1>$ look like. You can view $\Bbb C_1$ as the set of polynomials in $\Bbb C[X,Y]$ subject to the relations $X -1 = 0$ and $Y + X^2 - 1 = 0$. Those relations are equivalent to $X = 1$ and $Y = 0$. Thus, $\Bbb C_1$ can be identified with the set of all constant polynomials over $\Bbb C$, i.e., $\Bbb C_1$ can be identified with $\Bbb C$.
To be more rigorous, define a mapping $\phi: \Bbb C[X,Y] \to \Bbb C$ by setting $\phi(f(x,y)) = f(1,0)$. Show that $\phi$ is a $\Bbb C$-linear map. The kernel $\text{ker}(\phi)$ contains $I$ since $X - 1$ and $Y + X^2 - 1$ map to zero under $\phi$. On the other hand, if $f\in \text{ker}(\phi)$, then since $X - 1$ and $Y$ belong to $I$ ($Y\in I$ since $Y = (Y + X^2 - 1) + (1 - X)(Y - 1)$),
\(\displaystyle f(X,Y) = \sum_{1\, \le i + j\, \le \deg(f)} \frac{\partial^{i+j}(f)}{\partial X^i\, \partial Y^j}(1,0)\, (X - 1)^i Y^j \in I.\)
Thus $\text{ker}(\phi) = I$. Now you just have to show that $\phi$ is surjective. Then you can claim that $\Bbb C_1$ is isomorphic to $\Bbb C$. Since $\Bbb C$ is a field, it follows from Siron's comment that $I$ is maximal in $\Bbb C[X,Y]$.
Could you explain me further the definition of:
$$\mathbb{C}[X,Y]/<X-1, Y+X^2-1>$$
? (Thinking)
? (Thinking)
It's the quotient of $\Bbb C[X,Y]$ by the ideal $<X-1, Y+X^2-1>$. It consists of all cosets $p(X,Y) + <X - 1, Y + X^2 - 1>$ where $p(X,Y) \in \Bbb C[X,Y]$.
A ok.. (Nod) How could I continue, in order to show that $\Bbb C[X,Y]/<X-1, Y+X^2-1>$ is isomorphic to $\mathbb{C}$ ? (Thinking)
Please refer back to post #3. :D
Could you explain me why we view $\Bbb C_1$ as the set of polynomials in $\Bbb C[X,Y]$ subject to the relations $X -1 = 0$ and $Y + X^2 - 1 = 0$? (Worried)
Let $\overline{g(X,Y)} \in \Bbb C_1$ denote the equivalence class of a complex polynomial $g(X,Y)$. Given $f(X,Y) = \sum_{i,j} a_{ij} X^i Y^j \in \Bbb C[X,Y]$, we have $\overline{f(X,Y)} = \sum_{i,j} a_{ij}\overline{X}^i \overline{Y}^j$. In addition, $\overline{X - 1} = 0$ and $\overline{Y + X^2 - 1} = 0$, i.e., $\overline{X} - \overline{1} = 0$ and $\overline{Y} + \overline{X}^2 - \overline{1} = 0$. If we associate $X$ with $\overline{X}$ and $Y$ with $\overline{Y}$, then we may view $\Bbb C_1$ as the set polynomials subject to the relations $X - 1 = 0$ and $Y + X^2 - 1 = 0$.
Is this the only way to show that $\mathbb{C}[X,Y]/<X-1,Y+X^2-1>$ is isomorphic to $\mathbb{C}$ ? (Thinking)
No, follow the steps in the second paragraph of post #3.
Could we do it like that?
Since $\langle x-1,y+x^2-1\rangle =\langle x-1, y\rangle$ we have to show that $\mathbb{C}/\langle x-1,y\rangle$ is isomorphic to $\mathbb{C}$.
We define the homomorphism $\phi(z)=z, \forall z\in \mathbb{C} , \phi(x)=1, \phi(y)=0$.
A polynomial in $\mathbb{C}$ is of the form $$\sum a_{mn} x^m y^n=\sum a_{mn} (x-1+1)^my^n=\sum a_{mn}\binom{m}{k} (x-1)^ky^n$$
Let $p(x)=q(x)+\sum a_{mn} \binom{m}{k} (x-1)^ky^n$
$$\phi(p(x))=q(x)\Rightarrow \phi(p(x))=0 \Leftrightarrow x-1 \mid p(x) \text{ and } y\mid p(x)$$ $$\Rightarrow ker \phi=\langle x-1,y\rangle$$
From the theorem :
Let $R,S$ rings and $\phi :R\to S$ homomorphism. There exists an isomirphism between the rings $R/ker \phi $ and $S$.
we have that $\mathbb{C}[x,y]/\langle x-1, y+x^2-1\rangle $ is isomorphic to $\mathbb{C}$.
Is it right? Or have I done something wrong? (Thinking)
A polynomial in $\mathbb{C}$ is of the form $$\sum a_{mn} x^m y^n=\sum a_{mn} (x-1+1)^my^n=\sum a_{mn}\binom{m}{k} (x-1)^ky^n$$ I think you are using Binomial theorem. In that case shouldn't there be one more summation appearing in the last term? I may have missed something.
From the theorem :
Now. Here's another way of doing it.
Define homomorpsim $\phi:\mathbf C[x,y]\to \mathbf C[y]$ which sends $x$ to $1$, $y$ to $y$ ans preserves each element of $\mathbf C$. (There is a unique homomorphism with this property.)
Since $\phi$ is surjective, by the First Isomorphism Theorem, we have
$$\mathbf C[x,y]/\langle x-1\rangle\cong \mathbf C[y]$$.
Now define $I=\langle x-1,y\rangle$.
Note that $I$ contains $\ker\phi$ and thus by the lattice theorem we have
$$\mathbf C[x,y]/I\cong C[y]/\phi(I)$$
Now $\phi(I)=\langle y\rangle$. Can you finish?
FAQ: Proving Maximal Ideal of $\mathbb{C}[X,Y]$
What is a maximal ideal?
A maximal ideal is an ideal in a ring that is not contained in any other ideal, except for the ring itself. In other words, it is an ideal that cannot be properly extended.
How is a maximal ideal proven in $\mathbb{C}[X,Y]$?
To prove a maximal ideal in $\mathbb{C}[X,Y]$, one must show that the ideal is proper (not equal to the whole ring), and that it is not contained in any other ideal. This can be done by showing that the ideal cannot be generated by any single element.
What are some common methods for proving maximal ideals?
Some common methods for proving maximal ideals include showing that the ideal is generated by irreducible elements, using the quotient ring to show that the ideal is maximal, and using the Zorn's lemma to show that the ideal is maximal.
Can a maximal ideal be prime?
Yes, a maximal ideal can also be prime. In fact, all maximal ideals in a commutative ring are prime. This means that if a maximal ideal contains both $ab$ and $a$, then it must also contain $b$.
What is the importance of proving maximal ideals?
Proving maximal ideals is important in the study of ring theory, as it helps to understand the structure and properties of rings. In particular, maximal ideals are useful in the study of quotient rings, which are important in areas such as algebraic geometry and algebraic number theory.
