MHB Proving Modular Arithmetic for x^2 = 0 or 1 (mod 4)
  • Thread starter Thread starter cocoabeens
    Arithmetic Proof
The discussion centers on proving that for all integers x, x^2 is congruent to either 0 or 1 modulo 4. The initial approach involved creating a table of cases based on whether x is even or odd, leading to the conclusion that even integers yield 0 and odd integers yield 1 when squared modulo 4. The second part of the discussion addresses proving that the equation x^2 + y^2 = 5003 has no integer solutions by analyzing the possible sums of x^2 and y^2 modulo 4, which can only result in 0, 1, or 2, but never 3, aligning with 5003 modulo 4. Participants emphasize the need for a formal proof rather than a simple case table, suggesting that a concise explanation of the cases suffices for clarity. Overall, the conversation highlights the importance of rigorous proof structure in modular arithmetic discussions.
cocoabeens
Hello, new to the forums here.
I need to prove that for all integers x, x^2 = 0(mod4) or x^2 = 1(mod4).
I started out by making a table of different cases.
case 1: y=0 ->0mod4
case 2: y=1 ->1mod4
case 3: y=2 ->0mod4
case odd: y=2n ->0mod4
case even: y=2n+1 ->1mod4
From here, I'm not quite sure how to say in words the rest of the proof.
In the next part, I use what's proved above to prove that x^2 + y^2 = 5003 doesn't have any integer solutions. I wasn't quite sure how to start this one.
Do I need to solve for two cases, where I assume x is odd in the first, and even in the second? I'm not sure how to use the Y^2 value at all.
I'd appreciate how to get the ball rolling on this one. Thanks so much in advance!
Hi and welcome to the forum!
cocoabeens said:
case 1: y=0 ->0mod4
case 2: y=1 ->1mod4
case 3: y=2 ->0mod4
Each integers is either even or odd, and in both cases you proved the statement. This concludes the proof. If you've covered residue classes, then you can work within $\Bbb Z_4$. Each integer is in one of the classes 0, 1, 2 or 3 modulo 4, so it is enough to check the claim only for these four values.
Consider $x^2 + y^2$ modulo 4. It is the sum of $x^2$ modulo 4 and $y^2$ modulo 4. Each of these values is either 0 or 1, so $x^2 + y^2$ modulo 4 equals 0, 1 or 2, but not 3, which is 5003 modulo 4.
Thanks for the response!
So for the first part, I was told that I need to deliver a formal proof, and that a table going over the cases was an insufficient proof. Would a formal proof be something like this-
"Based on the table (of cases), we have shown that for all integers x,if x is even, it will always be 0mod4, and if x is odd, it will always be 1mod4." Or is that not a sufficient enough statement?For the second part, I'm still a little confused- do I start out saying that x^2+y^2 modulo 4 =5003mod4, the left side being the sum of x^2mod4 and y^2mod4, and I can assume that y will also always be either 1mod4 or 0mod4 as well because it is also an integer? And then because x^2 and y^2 are both equal to 0 or 1, it will never be 3 = 5003mod4?
It is $x^2$ that will be 0 mod 4 if $x$ is even. This is because any even number squared is a multiple of 4:
$(2k)^2 = 4k^2$.
On the other hand, it is easy to see that:
$(2k+1)^2 = 4k^2 + 4k + 1 = 4(k^2 + k) + 1$
which is clearly 1 mod 4, for $x$ odd. So the only possibilities are:
$x^2 + y^2 = 0 + 0 = 0$ mod 4,
$x^2 + y^2 = 0 + 1 = 1$ mod 4,
$x^2 + y^2 = 1 + 0 = 1$ mod 4,
$x^2 + y^2 = 1 + 1 = 2$ mod 4.
You could expand this to (for example, in the second case):
$x$ even, $y$ odd means that:
$x = 2k, y = 2m+1$, so that:
$x^2 + y^2 = 4k^2 + 4m^2 + 4m + 1 = 4(k^2 + m^2 + m) + 1$.
Clearly $k^2 + m^2 + m$ is an integer if $k,m$ are. So if:
$x^2 + y^2 = 5003$, in the case that $x$ is even, and $y$ is odd, we have:
$x^2 + y^2 = 4t + 1 = 5003$, for some integer $t$.
Now 5003 = 4*1250 + 3, so if:
$4t + 1 = 4(1250) + 3$ we have:
$4(t - 1250) = 2$, which implies 2 is a multiple of 4, a contradiction
(equivalently, we have that the integer $t - 1250 = \dfrac{1}{2}$).
Personally, I take issue with the notion that a "proof by cases" is not "formal enough", an idea I find absurd.
For this proof, you only need to consider the cases where x is even and x is odd. You don't have to consider separately x = 0, x = 1 and x = 2, which you did in post #1. Correspondingly, you don't really build a table of cases, but consider two possible options.
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
