Proving Negative Infinity Divergence of (5-n^2)/(3n+1)
In summary: Alternatively, you could list (see again the empty section 2) which rules about limits you know yet, in order to solve...The first one isn't technically needed here but is nice to have. The second one is the generator of the exercise. If you need to prove those statements then that is one thing. If you can assume them to be true, then I'd set up a sandwich here and pass limits.
Mathematicsresear
66
prove (5-n^2)/(3n+1) diverges to negative infinity as n approaches infinity
For all M>0 there exists an N in the natural numbers such that for all n >= N, x_n <= -M
Let M be an element of the field of the real numbers. Let N in the natural numbers be such that N is less than or equal to M/2. Thus for all n greater than or equal to N, (5-n^2)/(3n+1) ... less than or equal to 2N which is less than or equal to M.
Is this proof correct?
(I left ... as an exercise to the reader, if my proof is correct, is my choice of N correct?)
Do you have any relevant equations here? e.g. do you know ##\frac{5}{n} \to 0## as n grows large? What about a simple linear relation say ##\frac{-n}{3}\to -\infty## as n grows large?
The first one isn't technically needed here but is nice to have. The second one is the generator of the exercise. If you need to prove those statements then that is one thing. If you can assume them to be true, then I'd set up a sandwich here and pass limits. (Technically you can get by with an 'open faced sandwich' here but nothing wrong with a regular one here... I assume that sandwich arguments are allowed at this point.)
I thought this was classic by the way though I suspect your grader may feel differently and in fact showing that these inequalities hold seems to be the point of the exercise.
I'd say that this is highly suspect. Suppose I select ##M:=-33.1##. Tell me what ##N## is less than or equal to half of this? (Answer: such N does not exist and your argument breaks)
Why doesn't such a N exist, if its less than or equal to? I didn't say equal to I added the or.
Natural numbers are non-negative...
What if I defined M to be greater than or equal to 0 in the proof? I can do that since that's an alternative definition for the divergence to negative infinity, right?
why don't you try writing this out in full and see what that gets you? As it reads now, I see this at best proving the obvious that for ##n\geq 3## the quantity is ##\lt 0##. To answer this problem you need to write these things out in full and the results should almost speak for themselves.
let me repeat this:
Do you have any relevant equations here? ... What about a simple linear relation say ##\frac{-n}{3}\to -\infty## as n grows large?
if there is an easy way to linearize the relationship via inequality manipulation (there is) then that seems to be the most direct way of proving the result. You should always have an eye open for linear relationships as they are so easy to work with.
let me repeat this:
I chose N to be the maximum of 3 and 21M/5
It's eye catching that the answers you get are given with more care and effort than the solutions you propose. How about to start with a definition (see the empty space above in section 2 of the template) and write down, what it means, that a sequence tends to minus infinity? Then try to prove exactly this definition, step by step, instead of throwing some bits into the discussion like
Alternatively, you could list (see again the empty section 2) which rules about limits you know yet, in order to solve the problem by previously proven statements. You have even explicitly been asked
Do you have any relevant equations here? e.g. do you know ##\frac{5}{n} \to 0## as ##n## grows large? What about a simple linear relation say ##\frac{-n}{3}\to -\infty## as ##n## grows large?
but I haven't seen an answer to the question.
If you just came to ask, whether your fractions of a proof somehow fit together to prove the statement, then the answer is: maybe, probably not.
Yes, I am aware of these relations, however, I'm trying to prove that the sequence diverges from the definition.
The definition I have in mind is as follows: For all M>0 there exists an N in the natural numbers such that for all n >= N, x_n <= -M
I am aware that I can say that a sequence of the form (-n)/c where c is a positive integer tends to negative infinity as n grows larger, by dividing the top and bottom of the fraction by n. So I can say that
since 5/n tends to 0 and 1/n tends to 0 (as n tends to infinity), we have (-n)/3 and so that diverges to negative infinity because
If I let M>0 and choose an N such that N>=3M , then for all n>=N, (-n)/3 <= -N/3<=-MWould that be correct?
Being an engineer rather than a mathematician I would proceed as follows...
If n is large n^2 is much larger than 5 so the numerator can be reduced to -n^2.
Likewise 3n is much larger than 1 so the denominator can be reduced to 3n.
So we now have -n^2/3n.
That further reduces to -(2/3)n
So as n approaches infinity (5-n^2)/(3n+1) approaches minus infinity slightly slower.
Have I missed something?
That's the heart of the matter. You just need to dot a few mathematical i's and cross a few analytical t's to get a formal proof.
Related to Proving Negative Infinity Divergence of (5-n^2)/(3n+1)
1. What is negative infinity divergence?
Negative infinity divergence is a concept in mathematics that describes a function or sequence whose values decrease without bound as its input or index approaches negative infinity.
2. How do you prove negative infinity divergence?
To prove negative infinity divergence, you need to show that the function or sequence in question approaches negative infinity as its input or index approaches negative infinity. This can be done using various techniques such as using limits, inequalities, or series tests.
3. What is the formula for proving negative infinity divergence?
The formula for proving negative infinity divergence depends on the specific function or sequence being analyzed. In general, it involves showing that the numerator of the function or the terms of the sequence grow at a faster rate than the denominator or the index as they approach negative infinity.
4. How do you apply negative infinity divergence in real-life scenarios?
Negative infinity divergence is commonly used in mathematics and physics to analyze the behavior of functions or sequences in various situations. For example, it can be used to model the spread of a disease over time, the growth of a population, or the decay of radioactive materials.
5. Can you provide an example of a function that exhibits negative infinity divergence?
One example of a function that exhibits negative infinity divergence is (5-n^2)/(3n+1). As n approaches negative infinity, the numerator decreases at a faster rate than the denominator, causing the function to approach negative infinity. This can be shown using the limit definition of negative infinity divergence.
