Proving No Simple Pole at 0 for $f'$ on $\mathbb{D} - \{0\}$
  • MHB
  • Thread starter Dustinsfl
  • Tags
    Pole
In summary, the theorem states that there is no function f(*) in analytic in the punctured disk $\mathbb{D}-\{0\}$, $\{0\}$ is not a brantch point, and f'(*) has a simple pole at $\{0\}$.
Dustinsfl
2,281
Prove that there is no function $f$ such that $f$ is analytic on the punctured unit disc $\mathbb{D} - \{0\}$, and $f'$ has a simple pole at 0.
Let $f$ be analytic on the punctured disc $\mathbb{D} - \{0\}$.
f(z) = \frac{g(z)}{h(z)}
such that $h(z)\neq 0$.
Then
f'(z) = \frac{g'(z)h(z) - g(z)h'(z)}{(h(z))^2}
So $f'(z)$ has only poles of order 2. Therefore, $f'$ can't have a simple pole at 0.
How is this?
Counterexample: $\displaystyle f(z)=\ln z$ is analytic in $\mathbb{D}-\{0\}$ and is $\displaystyle f'(z)=\frac{1}{z}$...
... the exact formulation of the theorem should be: prove that there is no function f(*) so that f(*) in analytic in the punctured disk $\mathbb{D}-\{0\}$, $\{0\}$ is not a brantch point, and f'(*) has a simple pole at $\{0\}$...
Kind regards
$\chi$ $\sigma$
Kind regards
$\chi$ $\sigma$
Giving that caveat. Would I be correct then?
chisigma said:
The existence of singularities called brantch points is too often forgotten. For more information see...
http://mathworld.wolfram.com/BranchPoint.html
Kind regards
$\chi$ $\sigma$
Is what I have correct if I add the branch put argument in then?
If $\{0\}$ is not a brantch point, then f(*) can be written as Laurent series 'centered' in $z=0$...
$\displaystyle f(z)= \sum_{n=- \infty}^{+ \infty} a_{n}\ z^{n}$ (1)
Now if we derive (1) we obtain in any case a Laurent series in which is $a_{-1}=0$ so that f'(*) has no single pole in $\{0\}$...
Kind regards
$\chi$ $\sigma$
Kind regards
$\chi$ $\sigma$
So we can assume the series is uniformly convergent?
Kind regards
$\chi$ $\sigma$
But the theorem says f has to be analytic on the punctured disc isn't ln z not analytic on it. So the branch point part would be irrelevant.
FAQ: Proving No Simple Pole at 0 for $f'$ on $\mathbb{D} - \{0\}$
What does it mean for a function to have no simple pole at 0?
Having no simple pole at 0 means that the function has a removable singularity at 0, where it can be defined as continuous and have a finite value at that point. In other words, the function approaches a finite value as it gets closer to 0.
Why is it important to prove that a function has no simple pole at 0?
It is important to prove this because it ensures that the function is well-behaved and does not have any singularities or discontinuities at 0. This allows for a more accurate analysis of the function and its behavior.
How can we prove that a function has no simple pole at 0?
One way to prove this is by using the Cauchy-Riemann equations, which state that for a function to be differentiable at a point, it must satisfy certain conditions. If these conditions are not met, then the function cannot have a simple pole at that point.
What is the significance of the restriction on the domain in this statement?
The restriction on the domain, which is $\mathbb{D} - \{0\}$, means that we are considering the function on a domain that excludes the point 0. This allows us to focus on the behavior of the function around 0 and determine if it has a simple pole at that point.
Can a function have a pole at 0 but not a simple pole?
Yes, a function can have a pole at 0 that is not a simple pole. This means that the function has an essential singularity at 0, where it cannot be defined as continuous and has an infinite limit at that point.
