Proving Non-Negative Numbers in a^2+b^2=1
  • Thread starter armolinasf
  • Tags
    Numbers
In summary, if there are two non-negative numbers, a and b, such that a^2 + b^2 = 1, then there exists an angle theta such that sin(theta) = a and cos(theta) = b. This relationship also holds true for negative numbers, as it can be seen on the unit circle.
armolinasf
196
We that if there are two non negative numbers, a and b, such that a^2+b^2=1 then there exists an angle theta such that sin(theta)=a and cos(theta)=b. If I wanted to show that this is true even for negative numbers, would it be enough to say that if either a or b were negative it wouldn't matter since it would removed when we square the numbers in a^2+b^2=1 and the relationship would hold true? Thanks for the help.
Look at this in terms of the unit circle, x2 + y2 = 1. If x and y are nonnegative, we're working with the upper right quadrant of this circle, so 0 <= θ <= π/2. For any point (a, b) on this quadrant of the circle, cos(θ) = a and sin(θ) = b.
Now look at things on the entire circle to see how it works with a or b being negative.
FAQ: Proving Non-Negative Numbers in a^2+b^2=1
1. What does the equation a^2+b^2=1 mean?
The equation a^2+b^2=1 represents a circle with radius 1 centered at the origin on a Cartesian plane. It is also known as the unit circle.
2. How do you prove that a and b are non-negative numbers in this equation?
To prove that a and b are non-negative numbers, we must show that both a^2 and b^2 are greater than or equal to 0. This can be done by using the properties of real numbers and the fact that any number squared is always non-negative.
3. Why is it important to prove that a and b are non-negative numbers in this equation?
Proving that a and b are non-negative numbers in this equation is important because it ensures that the points (a,b) lie on the unit circle, which is necessary for the equation to hold true. It also allows us to accurately plot points on the unit circle and make calculations based on this equation.
4. Can the equation a^2+b^2=1 have non-real solutions?
No, the equation a^2+b^2=1 only has real solutions. This is because the square of any real number is always non-negative, and the sum of two non-negative numbers can only equal 1 if both numbers are 0 or positive.
5. How does proving non-negative numbers in this equation relate to the Pythagorean Theorem?
The Pythagorean Theorem states that in a right triangle, the sum of the squares of the two shorter sides is equal to the square of the longest side (hypotenuse). This is essentially the same concept as the equation a^2+b^2=1, where a and b represent the shorter sides and 1 represents the longest side (hypotenuse). Therefore, proving non-negative numbers in this equation is necessary to ensure the validity of the Pythagorean Theorem and its applications.
