MHB Proving Orthogonal Polynomials: A Weighted Integral
Amer
Let \{ \phi_0,\phi_1,...,\phi_n\} othogonal set of polynomials on [a,b] n>0, with a weight function w(x) prove that
\int_{a}^b w(x)\phi_n Q_k (x) \; dx = 0
for any polynomail Q_k(x) of degree k<n ?
My work :
I think there is a problem in the question since if we take x^2,x^3 on the interval [-1,1] they are orthogonal
but if we take x
\int_{-1}^{1} x(x^3 ) \; dx \neq 0
you haven't defined your weight function w(x), but let's assume it is the constant function 1. clearly $1,x$ are orthogonal, so we can start with a basis:
$B = \{1,x,\dots \}$
now let's look at what our third basis element $ax^2 + bx + c$ might be:
being orthogonal to 1 requires that $\int_{-1}^1ax^2 + bx + c\ dx = 0$. evaluating the integral, we find that:
$\frac{a}{3} + c - (\frac{-a}{3} + (-c)) = \frac{2a}{3} + 2c = 0$, and simplifying we get: $c = \frac{-a}{3}$.
so our second degree polynomial is of the form: $ax^2 + bx - \frac{a}{3}$.
since we must also have our second-degree polynomial orthogonal to x, this means that:
$\int_{-1}^1 ax^3 + bx^2 - \frac{ax}{3}\ dx = 0$, and evaluating THAT interval leads to $b = 0$.
traditionally, these polynomials are "normalized" so that $\phi_k(1) = 1$, doing so for:
$\phi_2(x) = ax^2 - \frac{a}{3}$ leads to: $a = \frac{3}{2}$, so that we get: $\phi_2(x) = \frac{1}{2}(3x^2 - 1)$.
the point is, there is no reason to assume that the "standard" basis: $\{1,x,x^2,x^3,\dots \}$ will be orthogonal with respect to the inner product defined by:
$\langle f,g \rangle = \int_{-1}^1 f(x)g(x)\ dx$ or the "weighted inner product" $\langle f,g \rangle = \int_{-1}^1 w(x)f(x)g(x)\ dx$
if you continue the process i started above (or by using gram-schmidt), you will get:
$\phi_3(x) = \frac{1}{2}(5x^3 - 3x)$ which can be verified to be orthogonal to $\phi_0, \phi_1,\phi_2$.
thanks, I edited my post
can you check it again ?
My work :
but if we take x
Then why do you assert that they are orthogonal. In particular, what is your definition of "orthogonal"?
My work :
but if we take x
There is something missing from this, there seems to be an implicit assumption that \( \phi_k(x) \) is of degree \( k \) (or rather that \( \phi_n(x) \) is of degree \(n\) and every degree less than \(n\) is represented by one of the other \(\phi\)s ). If this is not the case then the result can fail.
CB
CB
it is true, our instructor fixed the question as what you said (\phi_k is of order k )and i solved it
The world of 2\times 2 complex matrices is very colorful. They form a Banach-algebra, they act on spinors, they contain the quaternions, SU(2), su(2), SL(2,\mathbb C), sl(2,\mathbb C). Furthermore, with the determinant as Euclidean or pseudo-Euclidean norm, isu(2) is a 3-dimensional Euclidean space, \mathbb RI\oplus isu(2) is a Minkowski space with signature (1,3), i\mathbb RI\oplus su(2) is a Minkowski space with signature (3,1), SU(2) is the double cover of SO(3), sl(2,\mathbb C) is the...
