MHB Proving Perpendicular Motion: 2 Masses Colliding Obliquely
In the discussion on proving perpendicular motion during the oblique collision of two spheres, the conservation of momentum is applied to establish the relationship between their velocities before impact. The equations derived include 4x + 2y = 4p, where x and y represent the initial velocities of the 2kg and 4kg masses, respectively, and p is the velocity of the 4kg mass after impact. The coefficient of restitution, set at 1/2, is used to relate the velocities before and after the collision through Newton's experimental law. Participants express confusion about how to proceed once the velocities are expressed in terms of unknown variables. The discussion emphasizes the importance of understanding the momentum conservation principle in analyzing the collision dynamics.
markosheehan
two smooth spheres of masses 2kg and 4kg collide obliquely . the 2 kg mass is brought to rest. the coefficient of restitution is 1/2
prove before the impact the spheres were moving in perpendicular directions to each other.
using conservation of momentum. 4x+2y=4p+2(0) where x and y are velocities before impact. p is velocity after impact of 4kg
Newtons experimental law p-0/x-y =-1/2
once i get there velocities in terms of the variables i don't know what to do
Mathematics news on Phys.org
anyone?
the velocity in the j direction does not change as its along the i axis
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
