Proving piece-wise function is one-to-one?
In summary, the function f: Z -> Z is defined by f(x) = x/2 if x is even, (x-1)/2 if x is odd. The given proof shows that if x is even, then the function is one-to-one. However, it is unclear if the same proof can be used for the case when x is odd. It is also mentioned that for piecewise functions, it is sufficient to show that all derivatives are either positive or negative. It is also noted that in linear algebra, showing that only the zero vector is mapped into the null space is sufficient to prove one-to-one.
Norm850
f: Z -> Z defined by f(x) = x/2 if x is even, (x-1)/2 if x is odd.
Proof: If x is even:
x1 = 2k1
x2 = 2k2
Suppose f(x1) = f(x2), then
2k1/2 = 2k2/2
k1 = k2
So if x is even, the function is one to one? Is this an okay proof for the first half of if x is even, then I just do the same for if x is odd correct?
Not sure if you can use a function to define the independent variable to prove if it's one-to-one or not.
I'm not sure I follow the above. If a function is piecewise it's sufficient to show that all derivatives are positive or all are negative. Actually, this should be true for all analytic one to one functions. In linear algebra its sufficient to show that only the zero vector is mapped into the null space.
FAQ: Proving piece-wise function is one-to-one?
What is a piece-wise function?
A piece-wise function is a mathematical function that is defined by different equations on different intervals of its domain. It may have different rules for calculating the output depending on the input value.
What does it mean for a piece-wise function to be one-to-one?
A one-to-one function is a function where each input value (x) has a unique output value (y). In other words, no two different input values will result in the same output value.
How can you prove that a piece-wise function is one-to-one?
To prove that a piece-wise function is one-to-one, you must show that for any two different input values (x1 and x2), the corresponding output values (y1 and y2) are also different. This can be done by plugging in the input values into the function and showing that the resulting output values are not equal.
What is the importance of proving that a piece-wise function is one-to-one?
Proving that a piece-wise function is one-to-one is important because it ensures that the function has a unique inverse and can be easily solved for any input value. It also allows for easier analysis and manipulation of the function.
Are there any specific techniques for proving that a piece-wise function is one-to-one?
Yes, there are several techniques that can be used to prove that a piece-wise function is one-to-one. These include using the horizontal line test, showing that the function is strictly increasing or decreasing on each interval, and using algebraic methods such as the definition of one-to-one functions.
