Proving |PR|=3|RQ|: Two Particles Collide
  • MHB
  • Thread starter markosheehan
  • Tags
    Particles
In summary, using the given information and applying the laws of motion, it can be proven that the distance between point $p$ and the point of collision $r$ is three times the distance between the point of collision $r$ and point $q$. This is represented by the equation $\overline{pr}=3\overline{rq}$.
markosheehan
136
a particle is projected vertically upwards from a point P. at the same instant a second particle is let fall from rest vertically at q. q is directly above p. the 2 particles collide at a point r after t seconds . when the 2 particles collide they are traveling at equal speeds. prove that |pr|=3|rq|
i am trying to solve this with uvast equations for the first particle i have v=v s=r a=-g t=t for the second particle i have v=v s=p-r a=g t=t don't know where to go from here
Mathematics news on Phys.org
I would begin by orienting the vertical axis of motion such that point $p$ is at the origin. The first particle's position is then given by:
\(\displaystyle x_1=-\frac{a}{2}t^2+v_0t\)
And the second particle's position is:
\(\displaystyle x_2=-\frac{a}{2}t^2+q\)
Now, when the two particles meet, we have:
\(\displaystyle x_1=x_2\implies t=\frac{q}{v_0}\)
At this time, their speeds are equal, hence:
\(\displaystyle -at+v_0=at\implies v_0=2at\)
Hence:
\(\displaystyle t^2=\frac{q}{2a}\)
And so we find:
\(\displaystyle r=-\frac{a}{2}\cdot\frac{q}{2a}+q=\frac{3}{4}q\)
And this implies:
\(\displaystyle \overline{pr}=3\overline{rq}\)
FAQ: Proving |PR|=3|RQ|: Two Particles Collide
1. What does it mean to prove |PR|=3|RQ| in a particle collision?
Proving |PR|=3|RQ| in a particle collision means that the distance between particle P and particle R is three times the distance between particle R and particle Q. This can provide information about the velocity and energy of the particles before and after the collision.
2. How is the equation |PR|=3|RQ| used in particle collision experiments?
The equation |PR|=3|RQ| is used to calculate the momentum and kinetic energy of the particles before and after they collide. It can also be used to determine the angle of collision and the type of collision (elastic or inelastic).
3. What factors can affect the validity of proving |PR|=3|RQ| in a particle collision?
Some factors that can affect the validity of proving |PR|=3|RQ| in a particle collision include external forces, such as friction, and the accuracy of the equipment used to measure the distances between the particles.
4. How can scientists ensure the accuracy of their results when proving |PR|=3|RQ|?
To ensure the accuracy of their results when proving |PR|=3|RQ|, scientists can repeat the experiment multiple times and take the average of their measurements. They can also use more precise equipment and carefully control external factors that may affect the collision.
5. What are the implications of proving |PR|=3|RQ| in the field of physics?
Proving |PR|=3|RQ| in a particle collision can have significant implications in the field of physics. It can validate existing theories and provide new insights into the behavior of particles during collisions. It can also have practical applications in fields such as engineering and medicine.
