MHB Proving Properties of Multiplication for Natural Numbers
The discussion focuses on proving properties of multiplication for natural numbers defined through specific functions. Key properties to be demonstrated include commutativity, associativity, distributivity, and the identity property of multiplication. The proofs utilize mathematical induction, starting with base cases and applying inductive hypotheses to establish the required equalities. The participants clarify the steps and reasoning behind each proof, ensuring the definitions and previous results are consistently applied. Overall, the thread emphasizes the logical structure necessary for proving these foundational properties of multiplication.
evinda
MHB
Hello! (Wave)
For each pair of natural numbers $m \in \omega, n \in \omega$ we define the multiplication between $m,n$ (as a function $\cdot: \omega \times \omega \to \omega $) like that:
$$m \cdot 0=0$$
$$m \cdot n'=m \cdot n+m$$
I want to show that for each $m \in \omega, n \in \omega, k \in \omega$ the following properties are satisfied:
  • $m \cdot n=n \cdot m$
  • $(m \cdot n) \cdot k=m \cdot (n \cdot k)$
  • $(m+n) \cdot k=m\cdot k+n \cdot k$
  • $1 \cdot n=n$
  • If $k \neq 0$ and $n \cdot k=m \cdot k$ then $n=m$.
In order to prove the first sentence we have to show that $0 \cdot m=0$, $n' \cdot m=m \cdot n'$ and that $m \cdot n=n \cdot m$, right?In order to prove that $0 \cdot m=0$ I tried the following:
For $m=0: 0 \cdot 0=0 \checkmark$
We suppose a $m$ such that $0 \cdot m=0$.
We want to show that $0 \cdot m'=0$.
$0 \cdot m'=0 \cdot m+0 \overset{\text{induction hypothesis}}{=}0$.
Therefore, $0 \cdot m=0$, for any $m \in \omega$.Then we want to show that $n' \cdot m=m \cdot n'$.
For $m=0$: $n' \cdot 0 \overset{\text{definition}}{=}0 \overset{\text{previous sentence}}{=}0 \cdot n' \checkmark$We suppose a $m$ such that $n' \cdot m=m \cdot n'$ for all $n \in \omega$.We want to show that $n' \cdot m'=m' \cdot n'$.
$n' \cdot m'=n' \cdot m+n'=m \cdot n'+n'$How could we continue? (Thinking)
I would prove $0 \cdot m=0$ and
n'm=nm+m\qquad(*)
by induction on $m$. The equality (*) is used in the inductive step of proving $mn=nm$ by induction on $n$. Indeed,
mn'\overset{\text{def}}{=}mn+m\overset{\text{IH}}{=}nm+m\overset{(*)}{=}n'm.
Is it right like that?
We will show that $0 \cdot m=0$.
For $m=0: 0 \cdot 0 \overset{\text{definition}}{=}0$
We will show that $0 \cdot m'=0$.
$0 \cdot m'=0 \cdot m+0 \overset{\text{ind. hypothesis}}{=}0+0=0$
We will prove that $m \cdot n=n \cdot m$.
For $m=0: 0 \cdot n=0=n \cdot 0 \checkmark$
We suppose a $m$ such that $\forall n \in \omega: m \cdot n=n \cdot m$.
We will show $m' \cdot n=n \cdot m', \forall n \in \omega$
For $n=0: m' \cdot 0 \overset{\text{definition}}{=} 0 \overset{\text{above proposition}}{=} 0 \cdot m'$
Let $n$ such that $m' \cdot n=n \cdot m'$.
We will show that $m' \cdot n'=n' \cdot m'$.
$$m' \cdot n'=m' \cdot n+m' \overset{\text{ind. hypothesis}}{=}n \cdot m'+m'=n \cdot m+n+m' \overset{\star \star }{=} n \cdot m+n'+m \\ =(n \cdot m+m)+n'=n' \cdot m+n'=n' \cdot m'$$$$\star \star: $$
We will show that $n+m'=n'+m$.
For $m=0$: $n+m'=n+0'=(n+0)'=n'=n'+0=n'+m$
Let $m$ such that $n+m'=n'+m$.
We will show that $n+m''=n'+m'$.
$n+m''=(n+m')' \overset{\text{ind. hypothesis}}{=} (n'+m)' \overset{\text{definition}}{=} n'+m'$
Note that $nm+m=n'm$ (second last equality) is not an instance of definition. You could justify it as follows.
\begin{align}
nm+m&=mn+m&&\text{external induction hypothesis (on }m)\\
&=mn'&&\text{definition}\\
&=n'm&&\text{external induction hypothesis}.
\end{align}
You used other properties of addition, including commutativity and associativity. It is not clear why you are proving this particular fact and not others.
\begin{align}
\end{align}
I see... (Nod)
I didn't prove the other properties because they are given at the proposition of my other thread about addition. (Blush) I tried to show like that that $(m \cdot n) \cdot k=m \cdot (n \cdot k)$:
For $k=0: (m \cdot n) \cdot 0 \overset{definition}{=}0=m \cdot (n \cdot 0)=m \cdot 0=0$
Let $k$ such that $(m \cdot n) \cdot k=m \cdot (n \cdot k)$.We will show that $(m \cdot n) \cdot k'=m \cdot (n \cdot k')$.
$(m \cdot n) \cdot k' \overset{definition}{=} (m \cdot n)k +(m \cdot n) \overset{ind. hypothesis}{=} m \cdot (n \cdot k)+(m \cdot n) \overset{\star}{=} m \cdot (n \cdot k+n)\\=m \cdot (n \cdot k')$$$\star:$$
We will show that $m \cdot (n \cdot k)+(m \cdot n)=m \cdot (n \cdot k+n)$For $m=0: 0 \cdot (n \cdot k)+(0 \cdot n)=0= 0 \cdot (n \cdot k+n) \checkmark$Let $m$ such that $m \cdot (n \cdot k)+(m \cdot n)=m \cdot (n \cdot k+n), \forall n,k \in \omega$
We will show that $m' \cdot (n \cdot k)+(m' \cdot n)=m' \cdot (n \cdot k+n)$$m' \cdot (n \cdot k)+(m' \cdot n)=m \cdot (n \cdot k)+(n \cdot k)+m \cdot n+n=m \cdot (n \cdot k)+m \cdot n+(n \cdot k)+n \overset{ind. hypothesis}{=} m \cdot (n \cdot k+n)+(n \cdot k)+n=m' \cdot (n \cdot k+n)$
Am I right? (Smile)
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
