Proving - properties of quadratic roots
In summary, when the discriminant is negative, the equation has two imaginary solutions. When the discriminant is zero, the equation has one real solution.
Drain Brain
144
This is one of my weakness in Math, to prove an existing fact. please Tell how to go about doing these problem.
1. Prove that when the discriminant of a quadratic equation with
real coefficients is negative, the equation has two imaginary
solutions.
2. Prove that when the discriminant of a quadratic equation with
real coefficients is zero, the equation has one real solution.
regards!:)
Mathematics news on Phys.org
Re: Proving
Here again, you want to look at the quadratic formula, particularly the discriminant. Answering this question will help you answer your other question. Tell me what you see when you look at the quadratic formula...
Re: Proving
when the $b^2-4ac<0$
the roots are
$x=\frac{-b+\sqrt{b^-4ac}i}{2a}$ and $x=\frac{-b-\sqrt{b^-4ac}i}{2a}$ they are both imaginary.
for the 2nd question
when $b^2-4ac=0$
the roots are
$x=\frac{-b}{2a}$ and $x=\frac{-b}{2a}$
root of multiplicity two(double root)
Your reasoning is sound, but for the imaginary case, you want to express the roots as:
\(\displaystyle x=\frac{-b\pm i\sqrt{4ac-b^2}}{2a}\)
Do you see how we negated the discriminant to pull $i$ out front?
do you mean $\sqrt{-(4ac-b^2)}=i\sqrt{4ac-b^2}$
but why do we have to negate the discriminant if it is assumed to be $b^2-4ac<0$ already?
We want what's under the radical to be positive, so if it is initially negative, we pull $i$ out, and then negate the radicand so that it is now positive.
Thanks! now it's clear!
FAQ: Proving - properties of quadratic roots
How can I prove the properties of quadratic roots?
There are several approaches to proving the properties of quadratic roots. One way is to use the quadratic formula, which provides a direct method for finding the roots of a quadratic equation. Another approach is to use the discriminant, which is the expression inside the square root in the quadratic formula. The value of the discriminant can give information about the number and nature of the roots.
What are the properties of quadratic roots?
The main properties of quadratic roots are that they are always in a pair (except for complex roots), and they have a sum and product that can be determined by the coefficients of the quadratic equation. Additionally, the roots can be found by using the quadratic formula or by factoring the equation.
How do I know if a quadratic equation has real or complex roots?
You can determine if a quadratic equation has real or complex roots by looking at the discriminant. If the discriminant is positive, the equation will have two distinct real roots. If the discriminant is zero, the equation will have one real root. And if the discriminant is negative, the equation will have two complex roots.
Can a quadratic equation have more than two roots?
No, a quadratic equation can only have a maximum of two roots. This is because a quadratic equation is a second-degree polynomial, which means its highest exponent is 2. Therefore, it can only have two solutions at most.
How can I use the properties of quadratic roots to solve real-world problems?
The properties of quadratic roots can be applied to various real-world problems, such as finding the maximum or minimum value of a quadratic function, determining the time and distance of an object in motion, or finding the dimensions of a rectangle with a given perimeter and area. By understanding the properties of quadratic roots, you can use them to solve a wide range of real-world problems involving quadratic equations.
