Proving Residue Sum of f(z)=z^100/(z^102+1) is 0 with Contour Integral
  • MHB
  • Thread starter Poirot1
  • Tags
    Residue
In summary, to prove that the sum of the residues of $f(z)$ is 0, we can consider integrating $f(z)$ around a circular contour centered at zero with a large radius $R$. By the residue theorem, we can conclude that the sum of the residues is 0 by showing that the integral of $f(z)$ around the contour goes to 0 as $R$ approaches infinity.
Poirot1
245
Let $f(z)=\frac{z^{100}}{z^{102}+1}$. Prove that the sum of the residues of f is 0. (hint: consider the integral of f around a circular contour centrered at zero)
Informally, the idea is that if you integrate $f(z)$ around a circle of large radius $R$, then $|f(z)|$ will be approximately $1/R^2$, and the length of the contour will be $2\pi R$. So $\left|\oint f(z)\,dz\right|$ will be approximately $2\pi/R$, which you can make arbitrarily small by taking $R$ large enough. Now use the residue theorem to conclude that the sum of the residues is 0.
Great method thanks
FAQ: Proving Residue Sum of f(z)=z^100/(z^102+1) is 0 with Contour Integral
What is the purpose of proving the residue sum of f(z)?
The purpose of proving the residue sum of f(z) is to determine if the function has any singularities (points where the function is not defined) within a given contour or closed curve. This information can then be used to evaluate the contour integral of the function.
How do you calculate the residue sum of f(z)?
The residue sum of f(z) is calculated by finding the poles of the function (points where the denominator is equal to 0) within the given contour. The residue at each pole is then calculated using the formula Res(f(z), z0) = lim(z→z0) [(z-z0)f(z)]. The residue sum is then the sum of all the individual residues.
What is the significance of the residue sum being 0?
If the residue sum of f(z) is 0, it means that there are no poles within the given contour. This can be interpreted as the function being analytical (continuous and differentiable) within the contour, which makes the evaluation of the contour integral much simpler.
Can the residue sum of f(z) ever be a non-zero value?
Yes, the residue sum of f(z) can be a non-zero value if there are poles within the given contour. In this case, the function is not analytical within the contour and the evaluation of the contour integral becomes more complex.
How is the residue sum of f(z) used in real-world applications?
The residue sum of f(z) is commonly used in the field of complex analysis, which has applications in various fields of science and engineering such as physics, electrical engineering, and fluid mechanics. It is also used in the study of differential equations and in the development of numerical methods for solving mathematical problems.
