MHB Proving $\sin\left(10^{\circ}\right)$ is Rational or Irrational
The discussion centers on proving whether $\sin(10^{\circ})$ is rational or irrational. It utilizes the relation $\sin \alpha = 3\ \sin \frac{\alpha}{3} - 4\ \sin^{3} \frac{\alpha}{3}$, leading to the cubic equation $8\ x^{3} - 6\ x + 1 =0$. The argument posits that if $x$ were rational, it could be expressed as a fraction of integers, but this leads to a contradiction involving the square root of a non-integer. Consequently, the conclusion drawn is that $\sin(10^{\circ})$ is irrational. The discussion is supported by mathematical reasoning and a shared solution approach.
Fallen Angel
Is $\sin\left(10^{\circ}\right)$ rational or not? Prove it.
Mathematics news on Phys.org
[sp]From the relation...
$\displaystyle \sin \alpha = 3\ \sin \frac{\alpha}{3} - 4\ \sin^{3} \frac{\alpha}{3}\ (1)$
... it follows that $\displaystyle x= \sin \frac{\pi}{18}$ must be root of the cubic equation...
$\displaystyle 8\ x^{3} - 6\ x + 1 =0\ (2)$
If x is rational, then You can write $\displaystyle x = \frac{a}{b}$, being a and b integers... but in this case for (2) it must be...
$\displaystyle b = 4\ \sqrt{3\ a - \frac{1}{2}}\ (3)$
... and that's impossible for a and b integers... the conclusion is that x isn't rational...[/sp]
Kind regards
$\chi$ $\sigma$
Good work chisigma, my solution was almost the same.
From $8x^3-6x+1=0$, let $y=2 sin \ 10º$, then $y^3-3y+1=0$ and this polynomial has no rational roots (because of Gauss Lemma).
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
