MHB Proving Solution of Triangles with Tan Function
  • Thread starter Thread starter DrunkenOldFool
    Triangles
The discussion focuses on proving the identity involving the tangent function for half-angles in a triangle. It starts with the expression relating the tangents of half-angles to the triangle's sides and area, using the half-angle identity, the area formula, and the law of sines. The proof involves manipulating the expression through multiplication and substitution, ultimately leading to a simplified form. The law of cosines is applied to express cosine terms in a suitable format for verification. The conclusion indicates that the identity holds true, inviting others to verify the proof.
DrunkenOldFool
In a triangle $ABC$, the sides opposite to vertices $A,B,C$ are $a,b,c$ respectively. I have to prove
$$ \frac{\tan\left( \frac{A}{2}\right)}{(a-b)(a-c)}+\frac{\tan\left( \frac{B}{2}\right)}{(b-c)(b-a)}+\frac{\tan\left( \frac{C}{2}\right)}{(c-a)(c-b)} = \frac{1}{\Delta}$$
$\Delta$ denotes the area of the triangle.
Mathematics news on Phys.org
I would consider the half-angle identity for tangent:
$\displaystyle \tan\left(\frac{\theta}{2} \right)=\frac{1-\cos(\theta)}{\sin(\theta)}$
and the formula:
$\displaystyle \Delta=\frac{1}{2}bc\sin(A)$
and the law of sines:
$\displaystyle \frac{\sin(A)}{a}=\frac{\sin(B)}{b}=\frac{\sin(C)}{c}$
to write the expression as:
$\displaystyle \frac{1-\cos(A)}{\sin(A)(a-b)(a-c)}+\frac{a(1-\cos(B))}{b\sin(A)(b-c)(b-a)}+\frac{a(1-\cos(C))}{c\sin(A)(c-a)(c-b)}=\frac{2}{bc\sin(A)}$
Multiply through by $\displaystyle bc\sin(A)$
$\displaystyle \frac{bc(1-\cos(A))}{(a-b)(a-c)}+\frac{ac(1-\cos(B))}{(b-c)(b-a)}+\frac{ab(1-\cos(C))}{(c-a)(c-b)}=2$
Multiply through by $\displaystyle (a-b)(a-c)(b-c)$:
$\displaystyle bc(b-c)(1-\cos(A))+ac(c-a)(1-\cos(B))+ab(a-b)(1-\cos(C))=2(a-b)(a-c)(b-c)$
Using the law of cosines, we may write:
$\displaystyle 1-\cos(A)=1-\frac{b^2+c^2-a^2}{2bc}=\frac{a^2-(b-c)^2}{2bc}$
$\displaystyle 1-\cos(B)=1-\frac{a^2+c^2-b^2}{2ac}=\frac{b^2-(a-c)^2}{2ac}$
$\displaystyle 1-\cos(C)=1-\frac{a^2+b^2-c^2}{2ab}=\frac{c^2-(a-b)^2}{2ab}$
and we have:
$\displaystyle (b-c)(a^2-(b-c)^2)+(c-a)(b^2-(a-c)^2)+(a-b)(c^2-(a-b)^2)=4(a-b)(a-c)(b-c)$
I shall leave you now to verify (as I have), that this is an identity.(Mmm)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
