I Proving that fractions are the same as division
The discussion explores the relationship between fractions and division through the multiplicative inverse axiom, stating that multiplying by the inverse of a number is equivalent to division. It questions why mathematicians define the multiplicative inverse of a number x as the fraction 1/x. The conversation highlights that introducing rational numbers allows for solving equations like a × c = b for integers a and b. The definition of rational numbers as quotients of integers is established, leading to the conclusion that c = b/a can be expressed as c = a^-1 when b equals 1. The thread also mentions the concept of embedding integral domains into fields of fractions, emphasizing the broader mathematical context.
logicgate
TL;DR Summary
I'm trying to prove that fractions are the same as division using the axiom of multiplicative inverse.
So using the multiplicative inverse axiom we have :
1) x . x^-1 = 1
2) x . (1/x) = 1
I have no idea why do mathematicians define the multiplicative inverse of a number x to be the "fraction" 1/x.
But I know for sure that multiplying any number a for example by the multiplicative inverse of x is the same as "a divided by x"
Mathematics news on Phys.org
logicgate said:
TL;DR Summary: I'm trying to prove that fractions are the same as division using the axiom of multiplicative inverse.
1) x . x^-1 = 1
2) x . (1/x) = 1
If we start with the integers, and assume we can add and multiple them, we can ask:
Given two integers ##a## and ##b##, is there a number ##c## such that ##a \times c = b##?
Sometimes there is a suitable integer and sometimes there isn't. If we want that equation to be solvable for all non-zero ##a##, then we have to introduce some new numbers that aren't integers. So, by definition, we say:
##c \equiv \frac b a## is the number such that ##a \times c = b##.
And that effectively defines the rational numbers, as quotients of integers.
Then we have a special case where ##b = 1##, hence ##c = \frac 1 a## and ##c \times a = 1##. In this case, we call ##c## the multiplicative inverse of ##a## and we also write ##c = a^{-1}##.
That leads more generally to the equation: ##\frac b a = ba^{-1}##.
Likes pinball1970 and Lnewqban
This may be of interest:
https://en.m.wikipedia.org/wiki/Field_of_fractions
Every integral domain, i.e., a ring R in which a.b=0 implies a=0 or b=0, may be embedded in a field, called the Field of Fractions, through a specific process , described in the link.In your case, the Integral Domain of the Integers, can be embeded in the field of Rationals. In this case, if r is an element of said integral domain, the element (1/r) is used to denote it's multiplicative inverse in the associated field of fractions. Notice other examples like that of the Integral Domain ##\{ a+ib: a,b \in \mathbb Z \}##, has ##\{c+id: c,d \in \mathbb Q \}## as its field of fractions.
Maybe @fresh_42 can elaborate.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
