Bashyboy
- 1,421
- 5
Hello everyone,
I am suppose to show that all the Dihedral groups (##D_n##, for ##n >2##) are noncyclic. I know that every cyclic group must be abelian. So, what I intended on showing was that at least two elements in ##D_n## are not commutative. Here are my thoughts:
Because we are dealing with rigid transformations of an n-gon, any transformations must preserve the distance between any two points on the n-gon. We are particularly interested in the preservation of the distances between the vertices. In our book we are told that every transformation on a n-gon takes that n-gon to itself as a rigid object either by a rotation or reflection.
Having already worked with ##D_3## and ##D_4##, I know that, in general, the transformation of flip and rotation are not commutative. So, I was going to try and determine an arbitrary rotation and flip and show that they are not commutative.
If we label the vertices with the numbers ##1,2,3...,n##, then we can represent the initial configuration of the n-gon as a n-tuple: ##(1,2,3,...,n)##.
Whenever I perform a rotation of any sort, every one of the vertices must move. To put it another way, if ##i## and ##j## are neighboring vertices, and a rotation causes ##i## to move to the vertex position ##i+1##, then ##j \rightarrow j+1##.
Here is something else I noticed when working with ##D_4##. There is a "basic angle" through which the polygon can rotate. In the case of ##D_4##, the "basic angle" was ##R_{90}##; and all of the other rotations were built off of this “basic angle, for instance, ##R_{180}## and ##R_{270}##. This “basic angle” always moved the position of an element in the tuple by one position.
This brings up another observation: the only permitted rotations are those which are some multiple of the interior angle (in the case of ##D_4##, this would be ##\frac{\pi}{2}##). If this generalizes to any n-gon, then the “basic angle” through which you could rotate it would be ##\frac{(n-2) \pi}{2n}##. We could denote this as ##R_{\frac{(n-2) \pi}{2n}}##.
Now, when I rotate the n-gon by an angle of ##\frac{(n-2) \pi}{2n}##, every vertex would move over one position; that is,
##R_{\frac{(n-2) \pi}{2n}} ~:~ (1,2,3,...,n) \rightarrow (n,1,2,3,…,n-1)##,
where ##(1,2,3,…,n)## is the initial configuration of the n-gon. Now, here is the trouble emerges: what would a flip look like, in terms of n-tuples?
Sorry that these thoughts are scattered all about. Hopefully my thoughts make some sense.
