MHB Proving that the sum of 2 measurable functions is measurable
oblixps
I know there are many proofs for this but I am having trouble proving this fact using my book's definition.
My book defines first a non negative measurable function f as a function that can be written as the limit of a non decreasing sequence of non-negative simple functions.
Then my book defines that a function (taking on both positive and negative values) is measurable if both its positive part and negative part are measurable.
Let f and g be 2 measurable functions. Show that f + g is meaasurable as well.
If f and g are both non-negative, then it is clear that if $s_n$ is a nondecreasing sequence converging to f and $t_n$ is a nondecreasing sequence converging to g, then $s_n + t_n$ is a nondecreasing sequence converging to f + g.
However, I am having trouble with the more general case where f and g can take both positive and negative values. I am trying to show that the positive part of (f + g) is measurable, which means there exists a nondecreasing sequence of non-negative simple functions converging to $(f + g)^+$.
If I choose an x where f(x) and g(x) are non-negative, then it is clear how to construct such a sequence.
However, if I choose an x where f(x) > 0 and g(x) < 0 and f(x) + g(x) > 0, then I can represent this as $f^+ - g^-$. but i can't seem to come up with a sequence of functions converging to $f^+ - g^-$ AND is non decreasing. If $s_n$ is a nondecreasing sequence converging to $f^+$ and $t_n$ is a nondecreasing sequence converging to $g^-$, $s_n - t_n$ converges to $f^+ - g^-$ but it may not be a non decreasing sequence.
Can someone help me with this problem?
To make sure we have a non decreasing sequence
we will abandon some terms to make sure
s_n - t_n is a non decreasing
f(x) - g(x) &gt; 0
take \epsilon &lt; \frac{f(x) - g(x) }{2}
from the convergence we will have n_o \in \mathbb{N}
and m_o \in \mathbb{N}
such that \mid f_n - f(x) \mid &lt; \epsilon for all n &gt; n_o
and \mid g_n - g(x) \mid &lt; \epsilon for all n &gt;m_o
let r = max( n_o , m_o )
s_n - t_n is non decreasing for all n &gt; r
Let f and g be 2 measurable functions. Show that f + g is measurable as well.
That is a terrible way to define a measurable function. The usual approach is to define measurable functions in terms of measurable sets. Then a function $f$ is said to be measurable if for every real number $\alpha$ the set $\{x:f(x)>\alpha\}$ is measurable. In that case, if $f$ and $g$ are measurable functions then the set $\{x:f(x) + g(x)>\alpha\}$ is the union of the sets $\{x:f(x)>r\}\cap \{x:g(x)>\alpha - r\}$ as $r$ runs through the rational numbers. That is a countable union of measurable sets and is therefore measurable.
Starting from your book's definition of measurability, it does not even seem easy to show that the sum of a measurable function and a constant function is measurable.
Amer, could you explain a little more why $s_n - t_n$ must be non decreasing for n > r?
I don't really see how that follows from knowing $|s_n(x) - f(x)| < \epsilon$ and $|t_n(x) - f(x)| < \epsilon$. These expressions tell us how to bound $s_n - t_n$ for each n, but doesn't seem to give us a relationship between the nth and (n+1)th term.
Opalg, I agree that the more standard definition of a measurable function makes this problem much easier to prove.
thank you for both of your answers!
f(x) > g(x)
f(x) - g(x) &gt; 2\epsilon
since t_n is non decreasing, so t_n \leq f(x)
and s_n is non decreasing so s_n \leq g(x)
for n>r
\mid f(x) - t_n \mid &lt; \frac{f(x) - g(x) }{2}
we can take it without the absolute value since f(x) > tn
f(x) - t_n &lt; \frac{f(x) - g(x) }{2} &lt; f(x) - g(x)
f(x) - t_n &lt; f(x) - g(x)
0 &lt; t_n - g(x) for n>r
but g(x) &gt; s_n
0 &lt; t_n - g(x) &lt; t_n - s_n , for n>r
t_n \leq t_{n+1} \Rightarrow 0 \leq t_{n+1} -t_n + s_{n+1} - s_{n+1} \leq t_{n+1} - s_{n+1} - t_n + s_n since s_n \leq s_{n+1}
This
0 \leq t_{n+1} - s_{n+1} - ( t_n - s_n ) so t_n - s_n is non decreasing
Here is a picture for what I did and the epsilon I took
I hope of solution is clear now
Edited: :(
I made a mistake sorry, if we have t_{n+1} = t_n
and s_{n+1} &gt; s_n
we get t_{n+1} - s_{n+1} &lt; t_n - s_n
Thinking of something else
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
