Proving that treatment is statistically effective - paired t, P value, CI?
In summary: So, if you have a lot of patients with this before/after data, you can show that the population is unlikely to have a mean of 0. In summary, the conversation discusses the struggle of analyzing data from a medical treatment with a small sample size. The speaker uses Microsoft Excel to do a t-Test Paired Two Sample for Means, but questions the significance of the results due to the small sample size. They also consider the possibility of using a two-tail test instead of a one-tail test. The conversation also touches on calculating sample size and the interpretation of the descriptive statistics. The speaker also mentions the difficulty in proving the effectiveness of a treatment for a population with this type of data.
MBCT
Hi,
I'm really struggling with a statistical problem:
5 people had a medical treatment, they were tested before and after using a questionnaire which recorded some numerical data. I want to analyse the before and after results to see whether there was any change, whether it is statistically significant and then write this up correctly.
I don't have SPSS so I have been using the Data Analysis functions of Microsoft Excel as described here:http://www.stattutorials.com/EXCEL/EXCEL_TTEST2.html
So (before score 1-5, after score 1-5)
Person 1 - 2.75, 3.65
Person 2 - 1.75, 3.25
Person 3 - 3.75, 3.50
Person 4 - 1.75, 2.50
Person 5 - 2.75, 4.00
So first I did a t-Test Paired Two Sample for Means which gave me the following:
Mean 2.55, 3.384
Variance 0.7, 0.31853
Observations 5
Pearson Correlation 0.600384
Hypothesized Mean Difference 0
df 4
t Stat -2.77529
P(T<=t) one-tail 0.02503
t Critical one-tail 2.131847
P(T<=t) two-tail 0.050059
t Critical two-tail 2.776445
So, the important information seems to be that on a one tail P I have got 0.02 which is less than 0.05 and therefore I could reject the null hypothesis and say that the change is not due to chance and the treatment is statistically significant.
But, I only have a sample of 5 and therefore can't really say that can I? What sample size would I need to reject the null hypothesis and how can I calculate this?
Also, as tempting as it is to use one-tail, actually the treatment might be ineffective or make things worse and so maybe I should use two-tail, in which case is 0.050059 enough above 0.05 to make rejecting the null hypothesis impossible even if the sample size was much higher?
I then worked out the difference between the two sets of data by doing "after minus before" treatment giving me:
Person 1 - 0.92
Person 2 - 1.50
Person 3 - -0.25
Person 4 - 0.75
Person 5 - 1.25
Using Excel's Descriptive Statistics gave me this information:
Mean 0.834
Standard Error 0.30051
Median 0.92
Mode #NA
Standard Deviation 0.67196
Sample Variance 0.45153
Kurtosis 1.856022
Skewness -1.24463
Range 1.75
Minimum -0.25
Maximum 1.5
Sum 4.17
Count 5
Confidence Level (95%) 0.834348
Confidence Interval -0.00035, 1.668348
Now, as far as I can tell all I really need to know is that the Mean change is +0.834, the Standard Deviation is 0.67 and the Confidence Level is 0.834.
But, I don't really understand what this tells me about the treatment, was it effective? Was its effectiveness only held back by the small sample size?
As an added complication, I also have some data where I would expect the scores to get worse, where the treatment is the same but what I'm looking at is something like tumour size where I expect the treatment to reduce it. When I am looking at the difference between the before and after scores, do I do "after minus before" the same as above? If so then I would be happier with minus differences rather than plus... or is it just a case of how you then describe the data?
I hope that this makes any sense at all, and someone can help me in a jargon free way.
Thanks.
MBCT
Significance levels are just conventions and refereed journals often set their own rules. The "usual" two sided [itex]P\leq 0.05[/itex] is often set aside for stricter levels. Even a "significant" t test for only 5 subjects would probably not get published anywhere except maybe as a letter in Lancet if the subject was of broad interest. Your example falls just short of "significance" for the two sided test, The 95% confidence intervals for a significant difference in the means includes 0 which corresponds to your p value just over 0.05 for the two sided test.
Your data also shows that one patient responded minimally in the wrong direction to the intervention. Reviewers would look at this as a negative as much as they would the p value.
If you have specific questions about the outputs, could you list them?
EDIT: You don't "prove" a treatment is effective except in individual cases. For populations, you only meet some artificial criterion that is accepted as a sufficient demonstration of effectiveness.
Related to Proving that treatment is statistically effective - paired t, P value, CI?
1. What is the purpose of conducting a paired t-test?
The purpose of conducting a paired t-test is to determine whether there is a statistically significant difference between two sets of paired data. This test is often used to compare the means of two related groups, such as before and after measurements on the same individuals or measurements on paired subjects.
2. How is the p-value interpreted in a paired t-test?
The p-value in a paired t-test represents the probability of obtaining the observed results if the null hypothesis (no difference between the two groups) is true. A small p-value (typically < 0.05) indicates that there is a significant difference between the two groups and the null hypothesis can be rejected. A larger p-value suggests that there is not enough evidence to reject the null hypothesis.
3. Can a confidence interval be used to determine the effectiveness of a treatment?
Yes, a confidence interval can be used to determine the effectiveness of a treatment. A confidence interval provides a range of values within which the true mean of the population is likely to fall. If the confidence interval does not include the null hypothesis value, it can be concluded that there is a statistically significant difference between the two groups and the treatment is likely effective.
4. How does the sample size affect the results of a paired t-test?
The sample size can greatly affect the results of a paired t-test. A larger sample size increases the power of the test, making it more likely to detect a significant difference between the two groups. However, a small sample size may not accurately represent the population and can lead to inaccurate conclusions.
5. Is a paired t-test the only way to determine the effectiveness of a treatment?
No, a paired t-test is not the only way to determine the effectiveness of a treatment. Other statistical tests, such as ANOVA or chi-square, can also be used depending on the type of data and research question. Additionally, other factors such as clinical significance and practicality should also be considered when determining the effectiveness of a treatment.
