MHB Proving the Equality of A and B: A+B=0 or A=B
  • Thread starter Thread starter solakis1
The discussion focuses on proving that if AA equals BB, then either A plus B equals zero or A equals B. It begins by establishing basic algebraic properties such as commutativity, associativity, and the existence of additive and multiplicative identities. The proof utilizes these properties to manipulate the equation AA=BB, ultimately leading to the conclusion that if A plus B is not zero, then A must equal B. The proof is structured logically, relying on axioms and established mathematical principles to reach the final statement. Thus, the conclusion is that the relationship between A and B is defined by either their sum being zero or them being equal.
solakis1
Given for all A,B,C...
1) A+B=B+A......AB=BA
2) A+(B+C)=(A+B)+C.......A(BC)=(AB)C
3) A+0=A..........1A=A
4) $$\forall A\exists B(A+B=0)$$.....$$\forall A(\neg(A=0)\Longrightarrow\exists B(AB=1))$$
5) A(B+C)= AB+AC
Then prove: $$AA=BB\Longrightarrow (A+B)=0\vee A=B$$
Note: AB means A.B ...e.t.c ,e.t.c
Mathematics news on Phys.org
5) A(B+C)= AB+AC
Please post the solution you have ready. :)
5) A(B+C)= AB+AC
[sp] Proof:
1) AA=BB................Given
2) AA+AB=BB+AB..........additive property of equality
3) A(A+B)=B(B+A)............by axiom 5
4) A(A+B)=B(A+B)............by axiom 1
5) $$A+B\neq 0$$................assumption
6)$$\exists C[C(A+B)=1]$$..............by axiom 4
7) [C(A+B)]=1......................fix C
8) C[A(A+B)]= C[B(A+B)].................by the multiplicative property of equality
9) C[(A+B)A]=C[(A+B)B]..................by axiom 1
10) [C(A+B)]A= [C(A+B)]B..................by axiom 2
11) 1.A= 1.B......................by substituting 7 into 10
12) A=B........................by axiom 3
13) $$A+B\neq 0\Longrightarrow A=B$$..........Closing the assumption that we started at step 5
14) A+B=0 V A=B................This is equivalent to formula (13)Hence: If AA=BB ,then A+B=0 or A=B [/sp]
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
