Proving the Relation between $a,\,b,\,c$ and $x,\,y,\z$
  • MHB
  • Thread starter anemone
  • Tags
    Relation
In summary, we are given the conditions $a+x=b+y=c+z=1$ and we need to prove that $\left(abc+xyz\right)\left(\frac{1}{ay}+\frac{1}{bz}+\frac{1}{cx}\right)\ge 3$. The solution provided by Albert is a possible approach, but it may not be completely certain. It would be helpful to have another expert's opinion on this problem.
anemone
MHB
POTW Director
3,883
115
Given the positive real numbers $a,\,b,\,c$ and $x,\,y,\,z$ satisfy the condition
$a+x=b+y=c+z=1$
Prove that \(\displaystyle \left(abc+xyz\right)\left(\frac{1}{ay}+\frac{1}{bz}+\frac{1}{cx}\right)\ge 3\).
Mathematics news on Phys.org
$a+x=b+y=c+z=1---(1)$
Prove that \(\displaystyle \left(abc+xyz\right)\left(\frac{1}{ay}+\frac{1}{bz}+\frac{1}{cx}\right)\ge 3--(2)\).
my solution
expansion of $(2)$ we have :
$\dfrac{xz}{a}+\dfrac{xy}{b}+\dfrac{yz}{c}+\dfrac{ab}{x}+\dfrac{bc}{y}+\dfrac{ac}{z}\\
\geq 6\sqrt[6]{abcxyz}---(3)$
using $AP\geq GP$ on $ (1)(3)$
equality will happen when $a=b=c=x=y=z=0.5$
and $(3)\geq 6\times 0.5=3$
you may check another point with $a=b=c=\dfrac {1}{3} ,x=y=z=\dfrac {2}{3}$
and get $(3)=4.5>3$
Albert said:
my solution
and get $(3)=4.5>3$
Thanks for participating, Albert...I guess your solution works, but I am not that certain, I would be happy and grateful if someone who is more expert can give their two cents here...(Mmm)
My solution:
Rewrite the intended LHS of the inequality strictly in terms of a, b and c, we have:
$x=1-a,\,y=1-b,\,z=1-c$
\(\displaystyle \left(abc+xyz\right)\left(\frac{1}{ay}+\frac{1}{bz}+\frac{1}{cx}\right)\)
\(\displaystyle =\left(abc+(1-a)(1-b)(1-c)\right)\left(\frac{1}{a(1-b)}+\frac{1}{b(1-c)}+\frac{1}{c(1-a)}\right)\)
\(\displaystyle =\left(abc+1+ab+bc+ca-(a+b+c)-abc\right)\left(\frac{1}{a(1-b)}+\frac{1}{b(1-c)}+\frac{1}{c(1-a)}\right)\)
\(\displaystyle =\left(1+ab+bc+ca-(a+b+c)\right)\left(\frac{1}{a(1-b)}+\frac{1}{b(1-c)}+\frac{1}{c(1-a)}\right)\)
\(\displaystyle =\left(1-a(1-b)-b(1-c)-c(1-a)\right)\left(\frac{1}{a(1-b)}+\frac{1}{b(1-c)}+\frac{1}{c(1-a)}\right)\)
\(\displaystyle =\frac{1}{a(1-b)}+\frac{1}{b(1-c)}+\frac{1}{c(1-a)}-1-a(1-b)\left(\frac{1}{b(1-c)}+\frac{1}{c(1-a)}\right)\)
\(\displaystyle \,\,\,\,\,\,-1-b(1-c)\left(\frac{1}{a(1-b)}+\frac{1}{c(1-a)}\right)-1-c(1-a)\left(\frac{1}{a(1-b)}+\frac{1}{b(1-c)}\right)\)
\(\displaystyle =\frac{1-b(1-c)-c(1-a)}{a(1-b)}+\frac{1-a(1-b)-c(1-a)}{b(1-c)}+\frac{1-a(1-b)-b(1-c)}{c(1-a)}-3\)
\(\displaystyle =\frac{1-b+bc-c+ca}{a(1-b)}+\frac{1-a+ab-c+ac}{b(1-c)}+\frac{1-a+ab-b+bc}{c(1-a)}-3\)
\(\displaystyle =\frac{1-b-c(1-b)+ca}{a(1-b)}+\frac{1-c-a(1-c)+ab}{b(1-c)}+\frac{1-a-b(1-a)+bc}{c(1-a)}-3\)
\(\displaystyle =\frac{(1-b)(1-c)+ca}{a(1-b)}+\frac{(1-a)(1-c)+ab}{b(1-c)}+\frac{(1-b)(1-a)+bc}{c(1-a)}-3\)
\(\displaystyle =\frac{1-c}{a}+\frac{c}{1-b}+\frac{1-a}{b}+\frac{a}{1-c}+\frac{1-b}{c}+\frac{b}{1-a}-3\)
\(\displaystyle \ge 6\sqrt[6]{\frac{1-c}{a}\cdot \frac{c}{1-b}\cdot\frac{1-a}{b}\cdot\frac{a}{1-c}\cdot\frac{1-b}{c}\cdot\frac{b}{1-a}}-3\) (By the AM-GM inequality, with $1-a,\,1-b,\,1-c$ are all positive)
\(\displaystyle = 6-3\)
\(\displaystyle = 3\) (Q.E.D.)
Equality occurs when \(\displaystyle \frac{1-c}{a}=\frac{c}{1-b}=\frac{1-a}{b}=\frac{a}{1-c}=\frac{1-b}{c}=\frac{b}{1-a}.\)
FAQ: Proving the Relation between $a,\,b,\,c$ and $x,\,y,\z$
What is the relation between $a,\,b,\,c$ and $x,\,y,\,z$?
The relation between $a,\,b,\,c$ and $x,\,y,\,z$ is that they are all variables in a mathematical equation or problem. They may represent different quantities or values, but they are connected in some way.
How do you prove the relation between $a,\,b,\,c$ and $x,\,y,\,z$?
Proving the relation between $a,\,b,\,c$ and $x,\,y,\,z$ requires analyzing the given equation or problem and using mathematical operations to manipulate the variables and show how they are connected. This may involve substitution, elimination, or other techniques.
Why is it important to prove the relation between $a,\,b,\,c$ and $x,\,y,\,z$?
Proving the relation between $a,\,b,\,c$ and $x,\,y,\,z$ is important because it helps to understand the underlying principles and patterns in a mathematical problem. It also allows for the solution to be validated and checked for accuracy.
Are there any common mistakes when proving the relation between $a,\,b,\,c$ and $x,\,y,\,z$?
Yes, common mistakes when proving the relation between $a,\,b,\,c$ and $x,\,y,\,z$ include errors in algebraic manipulation, forgetting to consider all variables, and making incorrect assumptions about the problem. It is important to double check all steps and assumptions to avoid these mistakes.
Can the relation between $a,\,b,\,c$ and $x,\,y,\,z$ ever be disproven?
Yes, it is possible for the relation between $a,\,b,\,c$ and $x,\,y,\,z$ to be disproven if there is a logical or mathematical error in the proof. Additionally, if new information or evidence is discovered, it may change the relation between the variables and therefore disprove the previous relation.
