MHB Proving the Solution of a Recurrence Relation Using Induction
  • Thread starter Thread starter mathmari
The discussion focuses on proving the solution of the recurrence relation defined by X(1)=1 and X(n)=∑(i=1 to n-1)X(i)X(n-i) for n>1, with the proposed solution X(n+1)=1/(n+1) * C(2n, n). The user has successfully verified the base case and made an induction assumption for k values up to n. They are now attempting to show the case for n+1, involving complex summations and factorials. The user is considering whether to apply combinatorial formulas, specifically C(2n, n)=∑(k=0 to n)C(n, m)^2, to help in their proof. The discussion highlights the challenges in continuing the proof and the potential need for combinatorial insights.
mathmari
MHB
Hey! :o
I have to show that the solution of the recurrence $$X(1)=1, X(n)=\sum_{i=1}^{n-1}X(i)X(n-i), \text{ for } n>1$$
is $$X(n+1)=\frac{1}{n+1} \binom{2n}{n}$$
I used induction to show that.
I have done the following:
For $n=0$ : $X(1)=1 \checkmark $
We assume that it stands for each $1 \leq k \leq n$:
$$X(k)=\frac{1}{k}\binom{2(k-1)}{k-1} \ \ \ \ \ (*)$$
We want to show that it stands for $n+1$:
$$X(n+1)=\sum_{i=1}^{n} X(i)X(n+1-i)=\sum_{i=1}^{n} \frac{1}{i}\binom{2(i-1)}{i-1}\frac{1}{n+1-i}\binom{2(n-i)}{n-i}=\sum_{i=1}^{n}\frac{1}{i}\frac{(2(i-1))!}{(i-1)!(2(i-1)-(i-1))!}\frac{1}{n+1-i}\binom{(2(n-i))!}{(n-1)!(2(n-i)-(n-i))!}=\sum_{i=1}^{n}\frac{(2(i-1))!}{i!(i-1)!}\frac{(2(n-i))!}{(n-i+1)!(n-i)!}$$
How could I continue?? (Wondering)
Do we have to use maybe a formula from combinatorics, for example $$\binom{2n}{n}=\sum_{k=0}^{n}\binom{n}{m}^2$$ ?? (Wondering)
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
