Proving the Uniqueness of Center of Momentum Frame
In summary, the center-of-momentum frame is unique, in that the velocities of the masses can only be re-arranged summing up to 0-momentum if two distinct transformations are used.
haruna
Hello again,
Two days ago, I started a thread asking about the same question more or less, and I was thinking that the matter was clear now in my mind, because I had made an error in my calculations...
Before I begin, I want to admit that my English is not very good, and my exposition to physics is an elementary one, that's what I've learned from high school and one or two courses at the university.
Wikipedia, http://en.wikipedia.org/wiki/Center-of-momentum_frame says that:
"In physics, the center-of-momentum frame (zero-momentum frame, or COM frame) of a system is the unique inertial frame in which the center of mass of the system is at rest."
Unique inertial frame in which the center of mass of the system is at rest, in my mind translates (please correct me if I am wrong) as:
the constituent velocities of the individual masses of the system, vectorially summing up to the 0-total momentum of the system cannot be re-arranged by not any Lorentzian transformation (rotations of the Minkowski plane) thus resulting in 0-total momentum again, other than the identity transformation.
I think, this is always true for Galilean transformations.
I am aware that for the relativistic case, finding the center of momentum is no different than Newtonian mechanics, that is just use the transformation with v=P/E (in geometric units).
The pesky question which is troubling me is: is this center unique? That is, is there only one inertial frame where the velocities of the masses can be re-arranged (transformed) summing up to 0-momentum?
For any given system of free moving masses, if we can find any two distinct transformations (other than trivial rotations of the axes with no velocity), both giving us a 0-momentum frame, then this frame is not unique.
If in relativity this frame by definition, is taken to be the one with the v=P/E transformation, not taking into account any other 0-momentum frames that may exist, or if I have made any mistake in what I have assumed before, then I think there is no point in bothering you and trying to read the rest of my calculations, but if I am not so wrong, would you care to point out any errors in them that I might have done?
So, I assume geometric units throughout, and start with two masses, one is m moving at speed u in the x-positive direction, the other is M at speed v in the y-positive direction.
I am trying to find two clearly distinct composite Lorentz transformations, both leading into two-clearly distinct 0-momentum frames.
First, use the transformation with u. Mass m gets immediately at rest in new frame, M has velocity x-direction component to be -u and y-component to be: v[itex]\sqrt{1-u^{2}}[/itex]. Calculate new total P and E as if the two masses were lying on the line:y=tanθx=-[itex]\frac{v\sqrt{1-u^{2}}}{u}[/itex]x and find the center of momentum. Clearly, the two equal opposite velocities in this 0-momentum frame are tilted at angle θ to the horizontal.
Second, use transformation with v. Mass M gets immediately at rest in new frame, m has velocity x-direction component to be: u[itex]\sqrt{1-v^{2}}[/itex] and y-component to be: -v.
Similarly, we can find a new center of momentum and now the two equal opposite velocities are tilted at a different angle φ to the horizontal with tanφ=-[itex]\frac{v}{u\sqrt{1-v^{2}}}[/itex].
1. The CoM frame is unique up to rotations. I am still free to rotate my x, y, z, axes as I wish.
2. Do not forget that the way you've constructed the CoM frame requires two Lorentz boosts in two different directions, first to the rest frame of one particle, and then to the CoM frame itself. Now the tricky part is to remember that two Lorentz boosts in different directions will no longer be a pure Lorentz boost (this is why the boosts don't form a group). The product of two Lorentz boosts not in the same direction is the product of a Lorentz boost plus a rotation. If you take this rotation into account, you will see that you get the same CoM frame (but they might be rotated with respect to each other).
Likes 1 person
Thanks a million! This is it!
Related to Proving the Uniqueness of Center of Momentum Frame
What is the Center of Momentum Frame?
The Center of Momentum Frame (COM frame) is a reference frame in which the total momentum of a system is zero. In other words, the center of mass of the system appears to be stationary in this frame.
Why is it important to prove the uniqueness of the COM frame?
The uniqueness of the COM frame is important in understanding the dynamics of a system. It allows us to study the system from a reference frame that simplifies the equations of motion and makes it easier to analyze the system's behavior.
How is the uniqueness of the COM frame proven?
The uniqueness of the COM frame is proven by using the principles of conservation of momentum and energy. By applying these principles, we can show that there is only one frame in which the total momentum of a system is zero.
What are some practical applications of the uniqueness of the COM frame?
The uniqueness of the COM frame is used in various fields such as particle physics, astrophysics, and engineering. It is used to study collisions, calculate trajectories, and analyze the behavior of complex systems.
Can the COM frame be used in any system?
The COM frame can be used in any system where the principles of conservation of momentum and energy hold. However, in some systems, such as those with external forces acting on them, the COM frame may not be as useful in simplifying the equations of motion.
