Proving trigonometry identities
chwala
see attached
trigonometry concept
I was just looking at the problem below: there may be several ways to prove the identity:
question:
Mark scheme solution:
My take:
we may also use ##sin^{2}x+cos^{2}x≡(sin x+ cos x)(sin x-cosx)##...
we end up with(##\frac 2 {\sqrt{2}}##cos ∅)(##\frac 2 {\sqrt{2}}##sin ∅)=##2 sin ∅ cos ∅ ##= ##sin 2∅##
The formula
cos(\alpha+\beta)=\cos\alpha cos\beta - \sin \alpha \sin \beta
is helpful.
anuttarasammyak said:
The formula
is helpful.
True, that's what I used...together with the one for sine...
chwala said:
My take:
No, that's incorrect.
##\sin^2(x) + \cos^2(x) = 1##, for all x.
If you meant ##\sin^2(x) - \cos^2{x}##, that that does factor as you show above.
yeah, true...i made a slight mistake there...it should be the difference of two squares, thanks mark...i.e
##[sin(∅+45)+cos(∅+45)]⋅[sin(∅+45)-cos(∅+45)]##
##[(sin ∅cos 45+cos ∅sin 45)+(cos ∅cos 45-sin ∅sin 45)]⋅
[(sin ∅cos 45+cos ∅sin 45)-(cos ∅cos 45-sin ∅sin 45)]##
thanks Mark cheers.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
