MHB Proving ||u||_d = 0 and u=0 in Metric Spaces
  • Thread starter Thread starter Linux
    Norm
Linux
Let $$(X, d)$$ be a metric space, $$AE_0(X) = \{ u : X \rightarrow \mathbb{R} \ : \ u^{-1} (\mathbb{R} \setminus \{0 \} ) \ \ \text{is finite}, \ \sum_{x \in X} u(x)=0 \}$$,
for $$x,y \in X, \ x \neq y, \ m_{xy} \in AE_0(X), \ \ m_{xy} (x)=1, \ m_{xy}(y)=-1, \ m_{xy}(z)=0$$ for $$z \neq x, y$$ and $$m_{xx} \equiv 0$$
for $$u \in AE_0(X), \ ||u||_d = \inf \{ \sum_{k=1}^n |a_k| d(x_k, y_k) \ : \ u= \sum_{k=1}^n a_km_{x_k, y_k}, a_k \in \mathbb{R}, x_k, y_k \in X, n \ge 1 \}$$
How to prove that $$||u||_d = 0 \ \iff \ u=0$$?
I know it is not so obvious that then all terms in the sum $$\sum_{k=1}^n |a_k| d(x_k, y_k)$$ must be zero.
Could you help me out a bit?
Thank you.
Thank you.
Hi Linux, and welcome to MHB!
The problem of showing that $\|u\|_d = 0$ implies $u=0$ seems difficult, and I have not been able to solve it. See http://mathhelpboards.com/analysis-50/could-you-check-my-solution-13108.html.
Hi,
I have not much time so I may be wrong but doing it fast I think that the set $\{(a_{k},x_{k},y_{k}) \ : \ u=\displaystyle\sum_{k=1}^{n}a_{k}m_{x_{k},y_{k}}\}$ is finite, so the infimum is always reched (i.e., it's a minimum) and your norm is given by series of positive terms, si the minimum being zero implies that all terms are zero.
I will think on it with caution later.
Fallen Angel said:
I have not much time so I may be wrong but doing it fast I think that the set $\{(a_{k},x_{k},y_{k}) \ : \ u=\displaystyle\sum_{k=1}^{n}a_{k}m_{x_{k},y_{k}}\}$ is finite, so the infimum is always reached (i.e., it's a minimum) and your norm is given by series of positive terms, so the minimum being zero implies that all terms are zero.
The problem is that there may be different representations of $u$ using points other than those at which $u$ is nonzero.
Suppose for example that the underlying metric space is the real line, and that $u = m_{0,1}$ (so that $u(0) = 1$, $u(1) = -1$ and $u$ is zero at all other points). Then $u$ can also be expressed as $u = m_{0,1/2} + m_{1/2,1}$, or as $$u = \sum_{k=0}^{999}m_{k/1000,(k+1)/1000}.$$ It is intuitively clear that $\|u\|_d$ cannot be decreased by such procedures, but a formal proof seems very elusive.
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
