MHB Proving Vector Subspace $U \notin R^3$
  • Thread starter Thread starter bbelson01
    Subspaces Vector
bbelson01
Hi All,
How do I prove that $U=\{(x,y,z)|x \mbox{ is an integer}\}$ is not a subspace of $R^3$?
I understand that I have to show $U$ is closed or not closed under vector addition and scalar multiplication but I'm unsure how I represent $x$ as an integer.
I would say:
let $V=\{v=(x,y,z) \in R^3\}$ a set of vectors in $R^3$.
$v_1 = (x_1, y_1, z_1)$ and $v_2=(x_2, y_2, z_2)$ then $v_1 + v_2=(x_1+x_2, y_1+y_2, z_1+z_2)$ a vector in $U$. $U$ is closed under vector addition.
Now let $c$ be an element of the set of real numbers. Then $cv=c(x,y,z) =(cx, cy, cz)$ which is an element of $U$. So $U$ is closed under scalar multiplication.
This is clearly not right as the question says to show it is NOT a subspace. Where am I going wrong?
Thanks
bbelson01 said:
Hi All,
How do I prove that U={(x,y,z)|x is an integer} is not a subspace of R^3?
I understand that I have to show U is closed or not closed under vector addition and scalar multiplication but I'm unsure how I represent x as an integer.
I would say:
let V={v=(x,y,z) \epsilon R^3} a set of vectors in R^3.
v1 = (x1, y1, z1) and v2=(x2, y2, z2) then v1 + v2=(x1+x2, y1+y2, z1+z2) a vector in U. U is closed under vector addition.
Now let c be an element of the set of real numbers. Then cv=c(x,y,z) =(cx, cy, cz) which is an element of U. So U is closed under scalar multiplication.
Thanks
Think more carefully about the paragraph in red. For (cx,cy,cz) to be an element of U, its first coordinate cx must be an integer. Does that have to be the case?
Thank you for your response. That was pretty obvious wasn't it? Ooops.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
