Proving x^2 + x is integrable.
  • Thread starter STEMucator
In summary: I did. So J = 25/2 = IIn summary, the conversation discusses the process of proving a function, specifically f(x) = x^2 + x, is integrable on a given interval [2,5] by showing that the upper and lower sums are equal. The conversation also includes a discussion on the correct way to calculate the upper and lower sums and the use of partitioning to find the limit as the maximum size of the sub-intervals approaches 0.
STEMucator
2,076
140
I'm curious about how to do something like this. My professor gave us a very simple example of how to prove f(x) = k is integrable on [1,3] for k in ℝ.
I'm trying to apply the same logic to any function so I can see how it works. So I guess I could state the problem as :
Suppose [itex]f(x) = x^2 + x[/itex], prove f is integrable on [2,5] by showing I = sup{sp} = inf{Sp} = J.
sp is my underestimate and Sp is my overestimate.
So first off we note :
mi = inf{ f(x) | x in [2,5] } = 6
Mi = sup{ f(x) | x in [2,5] } = 30
Forming our upper and lower sums and then calculating them :
[itex]s_p = \sum_{i=1}^{n} m_i Δx_i = 6(3) = 18[/itex]
[itex]S_p = \sum_{i=1}^{n} M_i Δx_i = 30(3) = 90[/itex]
This is definitely not what's supposed to happen I think as we all intuitively know that f(x) is integrable in this case. Showing it is a bit difficult for me though. Could someone point out what I may have done wrong?
Thanks in advance.
Thanks in advance.
These are NOT what are meant by S_p and s_p. You need to use
[tex] m_i = \inf_{x_i \leq x \leq x_i + \Delta x_i} f(x) ,\;\;\;\;\;
M_i = \sup_{x_i \leq x \leq x_i + \Delta x_i} f(x), \; i = 1,2 \ldots, n . [/tex]
This is your error.
Let [itex]P[/itex] be a partition of [2,5] with points of division [itex]2 = x_0 < x_1 < \dots < x_{n-1} < x_n = 5[/itex], and let [itex]\delta_i = x_i - x_{i-1}[/itex] for [itex]1 \leq i \leq n[/itex]. Then you should have
[tex]
m_i = \inf \{x^2 + x : x \in [x_{i-1},x_i] \} = x_{i-1}^2 + x_{i-1} \\
M_i = \sup \{x^2 + x : x \in [x_{i-1},x_i] \} = x_i^2 + x_i
[/tex]
since [itex]x^2 + x[/itex] is strictly increasing on [2,5].
Now
[tex]x_{i-1}(x_i-x_{i-1}) < \frac12(x_i+x_{i-1})(x_i-x_{i-1})
= \frac12 (x_i^2 - x_{i-1}^2) \\
x_{i-1}^2(x_i- x_{i-1}) < \frac13(x_i^2 + x_i x_{i-1} + x_{i-1}^2)(x_i - x_{i-1})
= \frac13 (x_i^3 - x_{i-1}^3)
[/tex]
and in the other direction
[tex]x_{i}(x_i-x_{i-1}) > \frac12(x_i+x_{i-1})(x_i-x_{i-1})
x_{i}^2(x_i- x_{i-1}) > \frac13(x_i^2 + x_i x_{i-1} + x_{i-1}^2)(x_i - x_{i-1})
[/tex]
so
[tex]
s(P) = \sum m_i \delta_i =
\sum x_{i-1}^2(x_i- x_{i-1}) + \sum x_{i-1}(x_i-x_{i-1}) < \sum \frac13 (x_i^3 - x_{i-1}^3) + \sum \frac12 (x_i^2 - x_{i-1}^2)\\ = \frac13(5^3 - 2^3) + \frac12 (5^2 - 2^2)
[/tex]
by telescoping and similarly [itex]S(P) = \sum M_i \delta_i > \frac13(5^3 - 2^3) + \frac12 (5^2 - 2^2)[/itex].
Since these limits are independent of [itex]\max \delta_i[/itex], we must have
[tex]
\sup s(P) \leq \frac13(5^3 - 2^3) + \frac12 (5^2 - 2^2) \leq \inf S(P)
[/tex]
Now one just has to prove equality.
It's slightly easier to prove for the Riemann integral: [itex]x^2 + x[/itex] is continuous, so by the intermediate value theorem there exists [itex]z_i \in [x_i,x_{i-1}][/itex] such that
[tex]z_i^2 + z_i = \frac13(x_i^2 + x_ix_{i-1} + x_{i-1}^2) + \frac12(x_i + x_{i-1})[/tex].
Then
[tex]\sum_{i} (z_i^2 + z_i)(x_i - x_{r-1}) = \sum_{i} \frac13(x_i^3-x_{i-1}^3)
+ \frac12 (x_i^2 - x_{i-1}^2) = \frac13(5^3 - 2^3) + \frac12(5^2 - 2^2)[/tex]
and since the result is independent of [itex]\max \delta_i[/itex] it must be the limit as [itex]\max \delta_i \to 0[/itex].
Of course I'd never have come up with those inequalities if I didn't already know the answer.
Ahhh that was the trick. I completely forgot to partition my interval into n equal sub intervals ( Derp moment ).
Then [itex]x_i = 5i/n[/itex] and [itex]x_{i-1} = 5(i-1)/n[/itex] so that [itex]m_i = x_{i-1} = 5(i-1)/n[/itex] and [itex]M_i = x_i = 5i/n[/itex]
Thus :
[itex]S_p = \sum_{i=1}^{n} M_i Δx_i = 25/n^2 \sum_{i=1}^{n} i[/itex]
( We do a similar case for the lower sum ).
After evaluating and simplifying that, we get J = inf{ Sp } ≤ Sp and since inf{ Sp } does not rely on n, we can observe what happens as n→∞ which will yield our result for J. We can do the same thing for I and the lower sum.
Since I = J, we deduce that f is integrable on [2,5] and its common value is 99/2.
EDIT : Hmmm after writing this out I get I = 25/2 = J which is sort of what I wanted to happen, except I want 99/2, not 25/2.
Did i partition incorrectly?
[tex]
[/tex]
I'll just do this for [itex]f(x) = x[/itex] on [itex][a,b][/itex] with [itex]a \geq 0[/itex]; the same idea should work for [itex]f(x) = x^2[/itex].
For the upper sum, I want to show that for all [itex]\epsilon > 0[/itex] there exists a paritition [itex]P[/itex] such that
[tex]\frac 12(b^2 - a^2) < S(P) < \frac 12(b^2 - a^2) + \epsilon[/tex]
So I have
[tex]S(P) = \sum_i x_i (x_i - x_{i-1})
= \sum_i \frac{x_i + x_{i-1} + x_i - x_{i-1}}{2}(x_i - x_{i-1})
= \sum_i \frac12 (x_i^2 - x_{i-1}^2) + \sum_i \frac12 (x_i - x_{i-1})^2 \\
= \frac12 (b^2 - a^2) + \frac12 \sum_i \delta_i^2
\leq \frac12 (b^2 - a^2) + n (\max \delta_i)^2
[/tex]
So I need [itex]\max \delta_i < \sqrt{\epsilon/n}[/itex]. If I take an equally spaced partition, then [itex]\max\delta_i = (b-a)/n[/itex] and so I need [itex]n > (b-a)^2/\epsilon[/itex], which I can certainly do. This proves that [itex]\inf S(P) = \frac12 (b^2 - a^2)[/itex].
FAQ: Proving x^2 + x is integrable.
What does it mean for a function to be integrable?
Integrability refers to the property of a function to have a definite integral, which is a mathematical concept that represents the area under the curve of the function on a given interval. A function is considered integrable if its integral exists and can be calculated.
How do you prove that x^2 + x is integrable?
To prove that x^2 + x is integrable, we can use the fundamental theorem of calculus, which states that if a function is continuous on a closed interval [a, b], then its integral can be calculated as the difference between the antiderivative of the function evaluated at the upper and lower limits of integration. In this case, the antiderivative of x^2 + x is (1/3)x^3 + (1/2)x^2, so we can calculate its integral over any interval [a, b] by taking the difference between its antiderivative evaluated at b and a.
Is x^2 + x integrable on any interval?
Yes, x^2 + x is integrable on any interval [a, b] where a and b are real numbers. This is because x^2 + x is a continuous function, which satisfies the conditions of the fundamental theorem of calculus.
How can we visually see that x^2 + x is integrable?
To visually see that x^2 + x is integrable, we can plot the graph of the function and observe that it is a smooth curve without any discontinuities. We can also visualize the area under the curve by using geometric shapes, such as rectangles, to approximate the integral.
Can you prove that x^2 + x is integrable using other methods?
Yes, there are other methods to prove that x^2 + x is integrable, such as the Riemann sum method or the Lebesgue integral. These methods involve breaking down the integral into smaller parts and using mathematical techniques to evaluate each part, ultimately proving the integrability of the function.
