<\psi_b | z \dot{x} | \psi_a> (magnetic dipole & quadrupole transitions)
In summary, the problem asks to deduce equation [4.106] from [4.105] by using commutation relations. The attempt at a solution involves manipulating the expressions and using the fact that [z,p_z]=0. However, the last equation could not be proven without further assistance.
andresordonez
68
This is part 2 of problem 4.8 from "Physics of Atoms and Molecules - Bransden, Joachain"
Deduce [4.106] from [4.105]
[tex] \tilde{M}_{ba} = - \frac{m\omega_{ba}}{\hbar c} \langle \psi _b \vert z \dot{x} \vert \psi _a \rangle [/tex] [4.105]
[tex] \tilde{M}_{ba} = -\frac{\omega_{ba}}{2\hbar c} \langle \psi_b \vert L_y \vert \psi_a \rangle - \frac{i m \omega_{ba}^2}{2\hbar c} \langle \psi_b \vert zx \vert \psi_a \rangle [/tex] [4.106]
[tex] -\frac{m\omega_{ba}}{\hbar c}\left\langle \psi_{b}\vert z\dot{x}\vert\psi_{a}\right\rangle =-\frac{m\omega_{ba}}{i\hbar^{2}c}\left\langle \psi_{b}\vert z\left[x,H_{0}\right]\vert\psi_{a}\right\rangle =i\frac{m\omega_{ba}}{\hbar^{2}c}\left\langle \psi_{b}\vert\left(\left[zx,H_{0}\right]-\left[z,H_{0}\right]x\right)\vert\psi_{a}\right\rangle =i\frac{m\omega_{ba}}{\hbar^{2}c}\left\langle \psi_{b}\vert\left(\left[zx,H_{0}\right]-i\hbar\dot{z}x\right)\vert\psi_{a}\right\rangle [/tex]
[tex] =-i\frac{m\omega_{ba}^{2}}{\hbar c}\left\langle \psi_{b}\vert zx\vert\psi_{a}\right\rangle +\frac{\omega_{ba}}{\hbar c}\left\langle \psi_{b}\vert p_{z}x\vert\psi_{a}\right\rangle =-\frac{\omega_{ba}}{\hbar c}\left\langle \psi_{b}\vert\left(L_{y}-zp_{x}\right)\vert\psi_{a}\right\rangle -i\frac{m\omega_{ba}^{2}}{\hbar c}\left\langle \psi_{b}\vert zx\vert\psi_{a}\right\rangle [/tex]
[tex] =-\frac{\omega_{ba}}{2\hbar c}\left\langle \psi_{b}\vert L_{y}\vert\psi_{a}\right\rangle -i\frac{m\omega_{ba}^{2}}{2\hbar c}\left\langle \psi_{b}\vert zx\vert\psi_{a}\right\rangle +\left[-\frac{\omega_{ba}}{2\hbar c}\left\langle \psi_{b}\vert L_{y}\vert\psi_{a}\right\rangle -i\frac{m\omega_{ba}^{2}}{2\hbar c}\left\langle \psi_{b}\vert zx\vert\psi_{a}\right\rangle +\frac{\omega_{ba}}{\hbar c}\left\langle \psi_{b}\vert zp_{x}\vert\psi_{a}\right\rangle \right] [/tex]
But then:
[tex] -\frac{\omega_{ba}}{2\hbar c}\left\langle \psi_{b}\vert L_{y}\vert\psi_{a}\right\rangle -i\frac{m\omega_{ba}^{2}}{2\hbar c}\left\langle \psi_{b}\vert zx\vert\psi_{a}\right\rangle +\frac{\omega_{ba}}{\hbar c}\left\langle \psi_{b}\vert zp_{x}\vert\psi_{a}\right\rangle =0? [/tex]
I tried to prove the last equation without success. Any help would be much appreciated.
Care to explain where the two 2's in the denominator came from ? I think you need to use that [z,p_z]=0 on commutator's domain.
I guess you mean the 2's in this expression
[tex]
[/tex]
I was just trying to get [4.106]
[tex]
a = \frac{a}{2} +\frac{a}{2}
[/tex]
I think you mean [tex] [z,p_z]=i\hbar [/tex] or [tex] [z,p_x]=0 [/tex]. Anyway I don't see how that would help
FAQ: <\psi_b | z \dot{x} | \psi_a> (magnetic dipole & quadrupole transitions)
What is the significance of magnetic dipole and quadrupole transitions in physics?
Magnetic dipole and quadrupole transitions refer to the phenomenon where an atom or molecule changes its energy state by emitting or absorbing electromagnetic radiation. This process plays a crucial role in understanding the properties of atoms and molecules, and is used in various fields such as spectroscopy, quantum mechanics, and nuclear physics.
How do magnetic dipole and quadrupole transitions differ from each other?
Magnetic dipole transitions involve the emission or absorption of photons due to changes in an atom's spin orientation, while quadrupole transitions involve changes in the atom's shape. In magnetic dipole transitions, the emitted or absorbed photons have a magnetic dipole moment, while in quadrupole transitions, the photons have an electric quadrupole moment.
What factors determine the strength of a magnetic dipole or quadrupole transition?
The strength of a magnetic dipole or quadrupole transition depends on the selection rules, which are the allowed changes in the quantum numbers of the atom or molecule involved in the transition. It also depends on the transition probability, which is determined by the overlap between the initial and final states of the system.
How do magnetic dipole and quadrupole transitions contribute to the study of atomic and molecular structures?
By studying the energies and intensities of magnetic dipole and quadrupole transitions, scientists can determine the energy levels and spatial distribution of electrons in atoms and molecules. This information is crucial in understanding the electronic and geometric structures of these systems.
Can magnetic dipole and quadrupole transitions be manipulated or controlled?
Yes, magnetic dipole and quadrupole transitions can be manipulated or controlled by applying external electromagnetic fields. This is the basis of techniques such as nuclear magnetic resonance (NMR) and electron paramagnetic resonance (EPR), which are used in various fields including chemistry, biology, and medicine.
