Psychrometrics - Pure Humidification Process
In summary: But if we...In summary, the idea would work if the temperature of both the dry air and water vapor were the same.However, since the temperature of water vapor is lower than the temperature of dry air, the water vapor would be compressed.
Soumalya
183
In psychrometrics it is outlined time and again that we cannot achieve a pure humidification process i.e, add only moisture to unsaturated air without a change in its Dry Bulb Temperature(DBT).While pondering over the idea I came up with a possible way of doing it (if it is correct at all) and is explained below:
Let us take liquid water in a piston cylinder device at 25°C under 1atm or 101.325KPa pressure.We gradually reduce the pressure to 3.17KPa which is the saturation pressure of water at 25°C so that the water is now saturated liquid under prevailing conditions.Now keeping pressure constant at current value we heat the water until it is transformed to saturated vapor at 25°C under 3.17KPa.Now we take an adiabatic chamber with two compartments one filled with unsaturated air at 25°C and 1 atm pressure and the other with this saturated vapor at 25°C and 3.17KPa.Next we remove the partition separating the compartments so that the unsaturated air and saturated water vapor undergo direct mixing.
Since both air and water vapor are at same temperatures there is no space for sensible heat transfer between them and ideally the temperature of the resulting mixture should be at the same temperature of 25°C.
A point to be noted lies in the fact that there could be a drop in temperature due to inter molecular Van Der Walls forces but again dry air and water vapor both behave as ideal gases in the range of temperatures in most air conditioning applications(-10°C to 50°C) and the effect of Van Der Walls forces should be negligible.
So would the idea work as anticipated?
No. You are expanding dry air at 1 atm. against water vapor at lower pressure (cooling), and compressing water vapor at low pressure (heating).
Likes Soumalya
After some real brainstorming I feel the need to clarify the following points:
1. When you say dry air at 1 atm is expanded against water vapor at lower pressure I assume you are neglecting the contribution of the vapor pressure in the air and thus taking the partial pressure of dry air to be 1 atm.
2. Again when you say dry air at 1atm when expanded against water vapor at a lower pressure results in cooling of dry air,are you assuming dry air undergoing an adiabatic expansion against water vapor?
In reality as soon as the temperature of dry air would tend to fall a heat transfer from water vapor to dry air would tend to increase its temperature.
3. When you say water vapor is compressed you are certainly assuming that the specific volume of water vapor decreases.If the moist air was initially unsaturated at the temperature of the water vapor in the other compartment the specific volume of water vapor after mixing should actually increase.It would remain the same if the moist air was saturated at the temperature of the water vapor in the other compartment.Thinking in a practical way the water vapor at the other compartment would combine with the water vapor present in moist air after the partition is removed to occupy the entire volume of the chamber.Since for unsaturated air the specific volume of water vapor in the air is larger than the specific volume of water vapor at the other compartment(before mixing) the specific volume of water vapor after mixing should be larger than the initial specific volume of saturated water vapor existing alone at one of the compartments.Thus, water vapor would actually expand in such a case.
Then how is water vapor compressed after mixing has been achieved?
You've established a volume at a pressure of
Soumalya said:
3.17KPa
and a second volume of air. When the partition is removed, the air expands into the low pressure volume; the two volumes are at thermal, but not mechanical equilibrium at the initiation of the "mixing" process you're describing. The gas/vapor in the lower pressure volume/chamber is compressed.
Likes Soumalya
Bystander said:
You've established a volume at a pressure of 3.17KPa
Well I am still confused about this.Let's say if there was a movable piston as the partition with stops initially and the stops are removed the vapor at one of the compartments(P=3.17KPa) would get compressed and the piston would move to decrease the specific volume of the vapor as air at a higher pressure(P= 1 atm) expands against the vapor at a lower pressure.
But if we have direct mixing instead wouldn't the vapor at 3.17Kpa rush to fill the entire volume of the chamber?If it were compressed then its specific volume would have decreased but after the partition is removed vapor should fill the entire volume of the chamber i.e, now vapor is occupying a greater volume and hence specific volume should increase.Of course both dry air and water vapor at the other compartment also fills the chamber and expands likewise.So if the vapor occupies a greater volume after mixing is completed (so that its specific volume increases) how could we say it was compressed in this case?
Is it going to diffuse as rapidly as dry air expands? I'm hoping to avoid us having to go through construction and evaluation of the whole process step by painful thermodynamic step.
Likes Soumalya
Related to Psychrometrics - Pure Humidification Process
What is psychrometrics?
Psychrometrics is the study of the physical and thermodynamic properties of air and water vapor mixture. It involves the analysis of the relationship between temperature, humidity, and other properties of air.
What is the pure humidification process?
The pure humidification process involves adding water vapor to air without changing the air temperature. This can be achieved through processes such as atomization, spraying, or evaporation.
What is the purpose of psychrometrics in pure humidification?
Psychrometrics helps in understanding and predicting how air and water vapor will behave during the pure humidification process. It allows for the calculation of important parameters such as relative humidity, dew point, and specific humidity.
What is the difference between relative humidity and specific humidity?
Relative humidity is the ratio of the partial pressure of water vapor in the air to the saturation vapor pressure at a given temperature. Specific humidity, on the other hand, is the ratio of the mass of water vapor to the total mass of air in a mixture. While both are measures of humidity, they differ in the units of measurement and the information they provide.
How does temperature affect the pure humidification process?
Temperature plays a crucial role in the pure humidification process as it affects the capacity of air to hold water vapor. Warmer air can hold more water vapor, while colder air has a lower capacity. This means that the amount of water vapor that can be added to air during the pure humidification process is influenced by temperature.
  • Classical Physics
9K
