Psychrometry -- Ethanol in dry air
In summary, Ethanol evaporates in a 10 x 20 x 50 ft3 room. Air is initially dry at a temperature of 30 °C and 765 mmHg of pressure. If the partial pressure of ethanol after vaporization is 40 mmHg, how many pounds of ethanol evaporated? The same air is compressed until it reaches a pressure of 25 atm and then cools down to 20 °C. What percentage of ethanol condensed? Assume ideal behavior. Homework Equations PV = nRT Pi = PYi; where Yi is the mole fraction of component "i"
MexChemE
237
55
a) If the partial pressure of ethanol after vaporization is 40 mmHg, how many pounds of ethanol evaporated?
b) The same air is compressed until it reaches a pressure of 25 atm and then cools down to 20 °C. What percentage of ethanol condensed?
PV = nRT
The procedure for part a) is pretty straight-forward. We know the partial pressure of ethanol, which is the pressure ethanol would have if it ocuppied the 10,000 ft3 room by itself. We also have temperature so we can clear "n" from the Ideal Gas Law and get n = 1.32 lb mol of ethanol. We multiply this value times the molar mass of ethanol in lb/lb-mol and get 60.72 lb, which is the amount of ethanol that evaporated in the room.
Now, part b) is where I'm having trouble. I can either assume a constant volume or not and calculate a new partial pressure for ethanol using either Gay-Lussac's Law or the Combined Gas Law, but these calculations assume we still have 1.32 lb mol of ethanol, which is not the case. How do I actually account for the moles of condensed ethanol?
Thanks in advance for any input!
What's the vapor pressure of ethanol at 20 C?
0.05861 bar or ≈ 44 mmHg. The partial pressure of ethanol must be higher than its vapor pressure in order for it to condense, as far as I know.
And final pressure of air plus ethanol vapor pressure is 25 atm. (surprised they didn't throw gauge pressure at you --- this is a mixed unit sorting problem). How much air did they start with?
Are you suggesting using the vapor pressure of ethanol as its partial pressure? Makes sense, if ethanol is condensing it is at least at saturation pressure. After ethanol evaporated we have 1.32 lb mol of ethanol vapor and 23.943 lb mol of dry air, for a total of 25.263 lb mol.
If I use 44 mmHg as ethanol's partial pressure I can calculate a new number of moles, should I make the assumption of constant volume? I think I should, because I can't calculate a new total volume because we don't have 25.263 lb mol of mixture.
If I calculate the number of moles of ethanol using 44 mmHg of partial pressure, 10,000 ft3 of volume and 20 °C of temperature I get 0.0601 lb mol. Which make up for 2.76 lb. That means 95% of ethanol condensed. Are these assumptions and calculations correct?
There are enough missing steps that it's tough to tell where/when the assumptions were applied, and I see no calculations.
Sounds about right.
Likes MexChemE
Sorry, I was in a hurry. The assuptions I made were for the partial pressure of ethanol and the volume being kept constant. And the only calculations I made were to get the number of moles from the Ideal Gas Law. I will try to post all the details tomorrow.
I realized today I made a mistake in my assuptions and calculations (which I didn't post), but coincidentally arrived at the correct percentage of condensed ethanol. Using the vapor pressure of ethanol as its partial pressure in the room is right, but assuming the air keeps the same volume is wrong. You can't compress the air up to 25 atm and also cool it down to 20 °C while keeping the same original volume. But we don't need to include the volume in the calculations. I accidentally got the 0.0601 lb mol of ethanol (which coincidentally is a very close result to the one you get by following the correct procedure) using the Ideal Gas Law, keeping the 10,000 ft3 of volume, but instead of using the partial pressure of ethanol (44 mmHg), I used its mole fraction (calculated from 44 mmHg / 19,000 mmHg). Here's the right procedure:
We know from part a) that we have 23.943 lb mol of dry air. Now, we have the partial pressure of ethanol and the total pressure of the mix. We calculate:
[tex]Y_{C_2H_6O} = \frac{44 \ mmHg}{19000 \ mmHg} = 2.3158 \times 10^{-3}[/tex]
Now we can also get the mole fraction of dry air, which is YAir = 0.9976842. We know the moles of dry air and know we know its mole fraction so we can calculate the amount of moles in the mix:
[tex]n_T = \frac{n_{Air}}{Y_{Air}} = \frac{23.943 \ lbmol}{0.9976842} = 23.99858 \ lbmol[/tex]
Total moles times the mole fraction of ethanol result in 0.05558 lb mol of ethanol (close to the 0.0601 I calculated before), which make up for 2.557 lb of ethanol. Finally, we calculate the percentage of condensed ethanol:
[tex]\% \ Condensation = \frac{60.72 \ lbmol - 2.557 \ lbmol}{60.72 \ lbmol} \times 100\% = 95.8\%[/tex]
Thanks, Bystander!
Related to Psychrometry -- Ethanol in dry air
1. What is psychrometry?
Psychrometry is the study of the physical and thermodynamic properties of air and water vapor mixtures. It is used to understand and predict how humidity, temperature, and other factors affect the behavior of air and water vapor.
2. How does ethanol affect dry air?
Ethanol, when present in dry air, can act as a hygroscopic substance, meaning it has the ability to attract and hold onto water molecules. This means that the air will have a higher relative humidity and a lower dew point temperature, making the air feel more humid.
3. What is the significance of ethanol in psychrometry?
Ethanol is commonly used as a solvent in various industries and can be found in many consumer products. Understanding how it behaves in dry air is important in controlling humidity levels and predicting the behavior of air and water vapor mixtures in these industries.
4. How is the presence of ethanol in dry air measured?
The presence of ethanol in dry air can be measured using a hygrometer, which is an instrument that measures the relative humidity of the air. The reading on the hygrometer will be higher when ethanol is present, indicating a higher relative humidity in the air.
5. Are there any safety concerns related to ethanol in dry air?
Yes, there are safety concerns related to ethanol in dry air. Since ethanol is a flammable substance, it can increase the risk of fire or explosion in certain industrial settings. It can also cause irritation to the respiratory system if inhaled in high concentrations. Proper handling and ventilation should be practiced when working with ethanol in dry air.
  • Mechanical Engineering
  • Materials and Chemical Engineering
