Pulley problem, acceleration, angular velocity, inertia
In summary, the conversation discusses a problem involving two blocks with different masses connected by a pulley on a frictionless horizontal axle. The question asks for the magnitude of acceleration of the blocks, the tensions on each block, the pulley's angular acceleration and rotational inertia. Different solutions are proposed, including using Newton's second law and finding the function for velocity. It is determined that the final velocity is needed to find the acceleration, and that the pulley's mass needs to be known for an accurate solution.
  • #36
Noctisdark said:
X = at2/2 + v0t + x0, to be more precise, so Δx = at2/2 + v0t, if you know that acceleration is constant !
yes I am a noob acceleration must be constant.
  • #37
No, just keep it up !
  • #38
ok part e is getting me now. I am not sure what formula to use for rotational inertial here. assuming the mass of the pulley is 0. I=Σmr2 where m is the mass of blocks and r is the radius of the pulley.
edit; i also tried the equation for a hoop I=1/2 MR2
  • #39
The value of acceleration a tells us that the mass of the pully isn't 0, remember the 0.8002 you got before, that is only true when the mass is 0, so you need a another method, what about setting a relation btw α and a ?,
  • #40
i know that tangential acceleration is = rotational acceleration times radius of the pulley then just solve for α=a/r = (.0568/.053)=1.072 rad/s/s. this is incorrect, now I am trying to relate the gravitational potential energy and angular velocity and using eq K=1/2 Iω2 then solve for I. kinda like my last thread.
is radial acceleration the same as angular acceleration? it must not be
  • #41
I don't see why this doesn't work: ar=v2r = 0.3805rad/s/s
  • #42
You would need to divide by r, not multiply by r, but that's just the magnitude of the radial acceleration of the cord where it's in contact with the pulley.
Moreover, it's entirely irrelevant for this problem.
  • #43
rotational inertial will have something to do with the Mass of the system and the radius of the pulley. is finding gravitational potential energy on the right track?
  • #44
Two problems with this. (Well, zeroth, it applies to a disc not a hoop.) First, it assumes the density of the disc is uniform, which is not given. Second, you don't know the mass of the pulley.
Okay, now what is the torque on the pulley?
It's possible to solve the problem with energy considerations, (consider the change in energy after a time dt) but I would suggest you just consider the torque, instead.
  • #45
Nathanael said:
Two problems with this. (Well, zeroth, it applies to a disc not a hoop.) First, it assumes the density of the disc is uniform, which is not given. Second, you don't know the mass of the pulley.Okay, now what is the torque on the pulley?It's possible to solve the problem with energy considerations, (consider the change in energy after a time dt) but I would suggest you just consider the torque, instead.
ok torque=Fd
the forces acting on the pulley should be the difference of the tensions (T2-T1) multiplied by distance to axis of rotation (0.053m) look right?
edit; rotational torque T=Iα I don't know T or α , but i suspect i can find α if i knew what it was beyond it being called rotational acceleration.
  • #46
J-dizzal said:
ok torque=Fd
Yep
  • #47
Nathanael said:
Yep
rotation torque is relate to torque how?
edit: ok here is where I am stuck, net torque = T1-T2=(.23261382-.273967388)=-.041353568 but the correct answer is -0.038644208, i don't know how they got that, I've double checked my forces using 9.81m/s/s...
  • #48
edit: ok here is where I am stuck, T=Iα, I=T/α =(.041354/1.072)=.385760896 kg m2
You miscalculated. It should be 0.03(...) not 0.3(...)
Anyway your answer is a bit off from rounding errors... If you were to solve it with symbols (:devil:) you would get ##I=R^2\big(\frac{g}{a}(m_2-m_1)-(m_1+m_2)\big)## which is approximately 0.036 not 0.038
  • #49
I did get a value of .036048701 for I but that is incorrect. Edit, nevermind i had it negative which is incorrect. 0.36048701 is correct.
  • #50
I solved the problem with a completely different method (the energy one) and got the same answer. I even just double checked right now by solving it with Newton's laws and I get the exact same expression ##I=R^2\big(\frac{g}{a}(m_2-m_1)-(m_1+m_2)\big)##. I strongly doubt that it's incorrect.
If they want 3 significant figures then it should be 0.0361 (but I doubt they want 3 sig.figs., because the information was given only to 2 sig.figs.)
edit:
I wish I saw your edit... solved it twice for no reason :oldtongue:
